Author Topic: Is this a Customizer?  (Read 3924 times)
Offline pseudolobster
« on: Tue, 24 November 2009, 20:46:54 »
I can't whether or not this is a unicomp with a card reader slapped on, or if it's just a similar shaped keyboard...
http://cgi.ebay.com/Affirmative-Computer-Products-Keyboard-Terminal-Model-M_W0QQitemZ300370303794QQcmdZViewItemQQptZCOMP_EN_Workstations?hash=item45ef771b32
I'd like to bid, but I'm afraid to get stuck with some rubber dome POS.. Also, they only ship within the US.... I can arrange for someone to reship to me, but the cost is prohibitive.
« Reply #1 on: Tue, 24 November 2009, 20:57:02 »
Quote from: kishy;136108
...It does say "Model:M" in the listing so it's definitely related...
Wellll... To be fair, this gumball machine also says model m in its title...
I'm not sure it's buckling spring either.
Offline rdjack21
« Reply #2 on: Tue, 24 November 2009, 21:09:49 »
Quote from: pseudolobster;136107
Other than the CC reader it looks just like the two I have. Even down to the black keys under the key caps. If you didn't notice it is missing the key cap from the ./del key on the number pad. It should be noted that only IBM Model M's had the two piece keys like this one has as shown by the missing key cap on the number pad. I think you are fairly safe in bidding on it but like all things ebay you really will not know for sure until you get it.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Wed, 25 November 2009, 17:06:17 »
That keyboard says Unicomp all over it. What else explains the funny color scheme and the ugly logo?
  • Live long and prosper
« Reply #4 on: Wed, 25 November 2009, 17:39:37 »
I would say it is a Unicomp, but it may be a rubber dome, the Unicomp I bought, the seller said it was clicky, but it turned out to be a rubber dome.
tp thread is tp thread
Offline ch_123
« Reply #5 on: Wed, 25 November 2009, 17:51:03 »
Most Unicomp On-The-Balls out there are rubber dome ones. Customizers are more likely to be BS because there's nothing going for them other than Buckling Springs.
« Reply #6 on: Wed, 25 November 2009, 21:02:51 »
Quote from: kishy;136113
[...]the case shape and removable keycaps (see numpad period) definitely say Unicomp to me.
Good eye!
I missed that, but yeah, it sure looks like a keycap is missing... I never knew unicomp used black keystems on their customizers... That could be useful for my black M13 where I have a couple clear keycaps I use for winkeys etc... Right now I have them sharpied black, but an actual black keystem would be much classier.
« Reply #7 on: Fri, 27 November 2009, 06:24:41 »
It's also got the exact same font as the IBM keyboards. But I think it might still be a rubber dome though.
Offline ch_123
« Reply #8 on: Fri, 27 November 2009, 06:36:32 »
Is that black Numpad period key the underside of a double part keycap? If so, it's more than likely a BS board, as I'm almost certain they never made double part rubber dome keys.
« Reply #9 on: Fri, 27 November 2009, 06:43:26 »
I never knew that. I do know that Unicomp's rubber dome keycaps are differently built than the buckling spring ones however. If only my camera worked I'd get you all a few pictures.
