Author Topic: [IC] Flatline Black and Cyan SA profile keyset (on hold see OP)  (Read 431333 times)
Offline Lepidus
Re: [IC] Flatline Black and Cyan SA profile keyset (renders posted)
« Reply #350 on: Sun, 24 January 2016, 15:02:53 »
Nice name   :D
Why are there two escapes tho? Also, F and J wih deep dish or nipples?
« Reply #351 on: Sun, 24 January 2016, 15:04:30 »
Nice name   :D
Probably dish since people like scoops but I'm not sure what the consensus is for SA profile.
The 2nd Escape is Row 2 for JD40 users :)
This is how the rows are laid out.
Offline dgneo
  • Supervillain
« Reply #352 on: Sun, 24 January 2016, 15:05:18 »
Nice name   :D
Digging it a lot!
Scoops ftw
« Reply #353 on: Sun, 24 January 2016, 15:16:56 »
Just realized I'm missing the short enter for jd40. I'm going to be checking multiple quotes from SP by removing a few keys here and there. Personally I use caps lock as Ctrl as well but I don't think it's THAT important to have the correct legend in the set... and I'm not sure how popular JD40 even is :(
This SHOULD support UK Iso, tenkey, tsangan, as well as 1800 users. Split backspace will stay.
Offline xondat
  • i'm not a star
« Reply #354 on: Sun, 24 January 2016, 15:18:14 »
Nice name   :D
tyvm for iso
Offline E3E
Re: [IC] Black and Cyan SA profile keyset (renders posted)
« Reply #355 on: Sun, 24 January 2016, 15:53:42 »
I don't think super will fit on the 1x keys and not sure if people want win on the 1.25x
I will also add a row 2 1x backspace for jd40 and I think that covers that layout?
Just wanted to chime in and say that SUPER does fit on 1u keys in SA profile. At least it does on Jukebox. I've got some 1u SUPER going on with my Octagon's bottom row. :D
« Reply #356 on: Sun, 24 January 2016, 15:57:51 »
ooo.. well I guess I'll consider it
Offline user 18
« Reply #357 on: Sun, 24 January 2016, 16:41:19 »
If we're considering keys, a lot of people prefer a row 2 up arrow instead of row 4. Probably low on the priority list though.
Don't feel a need to add it for me, I think I'll be skipping this one regardless.
Avatar by ashdenej
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #358 on: Sun, 24 January 2016, 17:11:08 »
Looks pretty nice, but will there be an option to fit WKL boards?
« Reply #359 on: Sun, 24 January 2016, 17:22:07 »
yes there is a tsangan kit at the bottom
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #360 on: Sun, 24 January 2016, 17:55:31 »
Fresh ass set
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #361 on: Sun, 24 January 2016, 18:51:25 »
Please don't get rid of JD40 compatibility.  With SP's schedule listed in a previous post, this probably won't ship until the Smallfry boards do.  Don't want to go into that, but when those ship, there will be some people looking for JD40 compatible keys.  i think this will look great on them.
« Reply #362 on: Sun, 24 January 2016, 19:15:36 »
You might want to keep the 2x 1.75u blank row 4 keys, as well. Preorders for the JD45 will be starting really soon now, and it uses the same key sizes for mods as the JD40. After that, JD40s will probably be stocked at a few places.
Offline bocahgundul
  • a seal
« Reply #363 on: Sun, 24 January 2016, 19:40:50 »
This gon be a gud keycaps
Make some flatline novelty bro  :p
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #364 on: Sun, 24 January 2016, 19:48:15 »
Spread the word! I know it's nothing out of this world, but I think it's serious and straight to the point. Just a true blue GB, just the way we want it done. :thumb:
Put this is your sig yall! ;D
Code: [Select]
[url=https://geekhack.org/index.php?topic=78847.msg2015334#msg2015334][img]http://i.imgur.com/tuyOtAd.png[/img][/url]
PS: I hope you didn't mind I used the renders for this quick little image. :))
Offline Jedi
« Reply #365 on: Sun, 24 January 2016, 19:50:51 »
Guess I'm just gonna have to do Flatline since I have no Pulse.
Offline skycrimes
« Reply #366 on: Sun, 24 January 2016, 19:51:17 »
what color blue is used on the pulse and whats the link to see the swatches?
Offline Melvang
« Reply #367 on: Sun, 24 January 2016, 19:54:20 »
Any chance we can get a blue version of the black and orange for a GH theme?
Offline LXXXIX
« Reply #368 on: Sun, 24 January 2016, 19:59:22 »
http://www.keycapsdirect.com/abscolors.php
BBJ under Blues and NN under Blacks and Browns.
Offline skycrimes
« Reply #369 on: Sun, 24 January 2016, 20:00:47 »
awesome thanks and bbj is the same blue that was on the pulse keyset and will now be on flatline?
Offline swimmingbird
  • keyset hoarder
« Reply #370 on: Sun, 24 January 2016, 20:01:37 »
Code: [Select]
nice artwork
reminds me of medical drama shows
« Reply #371 on: Sun, 24 January 2016, 20:03:41 »
pulse uses bbq I think, this one is bbj. jd I'll pm you about input on keys to add later tonight. thank you everyone for the support I'm blown away really
Offline LXXXIX
« Reply #372 on: Sun, 24 January 2016, 20:07:15 »
Code: [Select]
nice artwork
I was kind of going for that vibe.I'm glad it panned out.
  • keyset hoarder
« Reply #373 on: Sun, 24 January 2016, 20:08:56 »
Code: [Select]
nice artwork
yep definitely got that childrens hospital vibe lol
Offline LXXXIX
« Reply #374 on: Sun, 24 January 2016, 20:12:51 »
Code: [Select]
nice artwork
I'm not sure if that's an insult to me or if we're poking fun at someone else. :confused:
  • keyset hoarder
« Reply #375 on: Sun, 24 January 2016, 20:15:01 »
Code: [Select]
nice artwork
no it was a compliment making a reference to a tv show
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #376 on: Sun, 24 January 2016, 20:21:23 »
Nice name   :D
The classic question: are the all the shifts going to be row 4?
« Reply #377 on: Sun, 24 January 2016, 20:22:05 »
Nice name   :D
Yes with the new mold.
« Reply #378 on: Sun, 24 January 2016, 20:23:39 »
Nice name   :D
Awesome, I just needed that verification before I start to generate funds for this!  :thumb:
Offline radio_killah
  • Chinchillin'
« Reply #379 on: Sun, 24 January 2016, 22:20:01 »
How much longer until you know the exact price? Do we have an approximate price already?
Renders look great and so do the keys included.
« Reply #380 on: Sun, 24 January 2016, 22:21:43 »
Hack'd By Geeks was $120, so my guess would be close to that, depending on home many more/fewer keys Sifo goes for.
« Reply #381 on: Sun, 24 January 2016, 22:23:33 »
We're looking to get this under $100 for each set. We will be buying up a certain amount of sets to help reach MOQ faster. The GB will only be open for maybe 2 weeks before closing, and it will start ASAP, maybe no later than the start of February depending on how fast SP can work with me.
Check out the sweet new banner btw in the OP :)
Signature one here, although feel free to use LXXXIX's as well as he did a great job.
« Last Edit: Sun, 24 January 2016, 22:26:20 by Sifo »
Offline fabian101
  • Cardbox
« Reply #382 on: Sun, 24 January 2016, 22:26:48 »
Would it be possible to include a 1.25 FN key?
I like that it was included in Hack'd By Geeks.
[WTB] Nothing For Now
Ducky Legend + Invisible FC660C
  • Chinchillin'
« Reply #383 on: Sun, 24 January 2016, 22:27:15 »
Sweet baby jesus.  :-*
  • keyset hoarder
« Reply #384 on: Sun, 24 January 2016, 22:28:39 »
sifo don't **** around when it comes to IC>GB
Offline Melvang
« Reply #385 on: Sun, 24 January 2016, 22:29:13 »
And here I was hoping this would be open for a bit longer given SPs current schedule with SA caps.
Offline LXXXIX
« Reply #386 on: Sun, 24 January 2016, 22:29:54 »
I was probably l originally going to use a pulse but... Anyways this is way better than mine. :(
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #387 on: Sun, 24 January 2016, 22:30:18 »
This is perfect!
If you're going to do any custom legends at all, may I suggest doing a FLATLINE key for either backspace or enter. Would really add a nice touch to the whole set.
« Reply #388 on: Sun, 24 January 2016, 22:32:40 »
Well, the quicker we get orders in, the earlier in the queue we get. If they are backed up through April, and you wait until April to place the order, they will be backed up to July at that point.
Offline Melvang
« Reply #389 on: Sun, 24 January 2016, 22:34:06 »
This is perfect!
Double shot flat line legend for spacebar.
True.  Will do everything in my power to pick up this set.  Really like the colors.  Would look great with blue CCFL under the desk shining on the keyboard tray with a Ti smallfry board.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #390 on: Sun, 24 January 2016, 22:38:30 »
Can someone get some sound effects to go along with the banner? It'll be very dramatic :D
Offline FrostyToast
  • Litshoard
« Reply #391 on: Sun, 24 January 2016, 22:42:17 »
I would rather have this open for a month, but do whatever you want. I'll try and make my budget work with this.
Quote from: elton5354
Offline mun2912
« Reply #392 on: Sun, 24 January 2016, 22:46:29 »
i will wait for the price..... :-[
Offline Den441
« Reply #393 on: Sun, 24 January 2016, 22:49:05 »
Any Panthers fans here? I am declaring this set the set to own if you are a panthers fan! BBQ is a bit too light to match with our Carolina blue, but BBJ is perfect for that.
Custom Wrist Rests, Artisan Keycaps, and more - http://battlestation.io
Sales Thread - https://geekhack.org/index.php?topic=74835.0
Offline Atredl
« Reply #394 on: Sun, 24 January 2016, 23:10:06 »
BBQ had just a bit too much green for my liking. Its a tiny difference but it makes a difference. Glad this set will be using BBJ.
I like blue, like a lot. I'm just VERY picky with the shade  :p
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #395 on: Sun, 24 January 2016, 23:25:10 »
Not Bad at all.
So Sifo old skunk, when are you going to release this onto MassDrop?
« Reply #396 on: Sun, 24 January 2016, 23:30:48 »
Not Bad at all.
I'm not :P
Offline whmeltonjr
« Reply #397 on: Sun, 24 January 2016, 23:37:15 »
Under $100 with all of those caps? Shut up and take my money.
Offline SixtyLife
« Reply #398 on: Sun, 24 January 2016, 23:38:30 »
sick renders.
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline ccarlitos2
« Reply #399 on: Mon, 25 January 2016, 00:18:48 »
This and Hack'd By Geeks make me wish I love SA profile. Aesthetically, SA looks the best to me. Good luck Sifo with this GB!
