Author Topic: Trackpoint: Ergodox vs. Infinity Ergodox  (Read 2396 times)
Offline v6ak
    • v6ak
« on: Wed, 20 January 2016, 02:47:27 »
I'd like to have an Ergodox keyboard. I'd like to
  • add trackpoint
  • be able to tune it in ways that I don't know now. (Maybe I'll find trackpoint not comfortable or I'll change my preferences in future.)
I can buy parts for the old one at Falbatech (and I can print some other parts). I can buy the Infinity Ergodox on Massdrop. And I'd like to decide which one would be better. It does not seem I need any improvement introduced in Infinity Ergodox. I don't need the LED display. I don't care about cable that connects the halves. I don't care about internals until it affects opportunities for tuning. And I don't care about USB 3 for keyboards. Which seems to be the main point there.
For the old Ergodox, there is a TMK firmware which seems to support trackpoint. The Infinity Ergodox, however, uses different firmware (because of significantly different CPU architecture). Although TMK has been ported for Infinity Ergodox, there might be some practical issues with trackpoint. For example, I am not sure if it will be easy to wire it to the CPU. This suggests buying the old Ergodox.
However, Infinity Ergodox might be the future for tuning. That is, I am afraid that new tuning opportunities will there be for Infinity Ergodox rather that for the old Ergodox. This suggests me buying the new Ergodox.
What are your opinions? Do I miss something? Do I miss some potential issues or potential advantages of one of variants?
Offline jacobolus
Re: Trackpoint: Ergodox vs. Infinity Ergodox
« Reply #1 on: Wed, 20 January 2016, 02:54:15 »
I’m sure you can get either one working with a trackpoint. Both hasu (author of the tmk_keyboard firmware) and HaaTa (author of the kiibohd firmware used on the Infinity board) are active on this forum and in the #geekhack channel on the freenode IRC network, if you have questions.
You probably want to move this to the "making stuff together" subforum at the point where you’re actually building stuff.
Offline v6ak
    • v6ak
« Reply #2 on: Sat, 30 January 2016, 06:14:27 »
Thank for the opinion. If both seems to have active community, I'll prefer the old one, since it seems to be considerably cheaper for me.
