Author Topic: Light-on-dark caps on Model M?  (Read 3453 times)
Offline ander
  • I type, therefore I am
« on: Wed, 20 January 2016, 21:12:18 »
Hi guys,
I understand that dye-sublimation can't be used to print light legends on dark caps. So how did Lexmark provide caps like these?:
(Thanks to ClickyKeyboards.com for photos)
They'd have to be double-shot, wouldn't they? (They don't look pad-printed.) So they would've had to acquire them elsewhere, right? Or maybe an OEM bought these boards with standard caps and substituted some of their own?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Light-on-dark caps on Model M?
« Reply #1 on: Thu, 21 January 2016, 02:24:19 »
I think it's probably pad printed, some manufacturers did this to pretty high standards. I'm pretty sure it's not doubleshot. You can also use lasering and infilling but I'd be surprised at that too.
« Reply #2 on: Thu, 21 January 2016, 02:30:38 »
Probably pad. Unicomp did white on blue pad print for the wildcats board.
Offline fanpeople
« Reply #3 on: Thu, 21 January 2016, 02:33:24 »
There are also the white on black keycaps of the M-13 I think it is called which are pad printed.
I vote pad printed also
Offline ander
« Reply #4 on: Thu, 21 January 2016, 02:35:28 »
All good points... You're probably right. They didn't seem pad-printed to me, as I'd expect to see more noticeable coating outlines around the text, esp. with the light shining on them like that. But they're not the clearest photos, either.
« Reply #5 on: Thu, 21 January 2016, 02:44:08 »
Honestly from what I've seen, pad print bs caps are pretty damn clean. Can't vouch for wear though.
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Thu, 21 January 2016, 03:21:20 »
No, quite the opposite, some pad printing is absolutely rimless and can look verysharp! :)
Offline jamster
« Reply #7 on: Thu, 21 January 2016, 03:30:04 »
They can't be doubleshot- Model Ms keys have the lettered part as a really thin 'cap' that goes over a big blank key (sorry, that's a crap description but the best I can think of). The cap is too thin to allow the usual structure that you find on the underneath of a normal doubleshot key cap.
Offline SamirD
« Reply #8 on: Thu, 21 January 2016, 09:59:02 »
Very interesting!  I bet we could solve the mystery if we could pop the caps off and check. ;)
Offline Touch_It
« Reply #9 on: Thu, 21 January 2016, 12:47:25 »
I'm guessing pad printing.  IBM M-13 had pad printed black keycaps.  Never heard of any IBM keys being doubleshot.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10 on: Thu, 21 January 2016, 12:59:14 »
No IBM caps are double shot.  All light on dark caps are pad printed.  It is a fairly high quality version of it.  All IBM caps are PBT, and as far as I know, it has never been double shot with PBT legends.  All the double shot PBT caps I have seen use POM for the legend.
Offline SamirD
« Reply #11 on: Thu, 21 January 2016, 14:03:53 »
I want a t-shirt that has that "F11 Person" keycap on it.  That's just awesome to me.
