Author Topic: White Mechanical Keyboard + Backlight? (Variations Involved) Do these Exist?  (Read 4841 times)
Offline leiigghhh
Hello Geekhack Forums :)
I've been eyeing a white keyboard for over a year now and i still haven't found myself one. (Originally the Poker 2, cancelled the order a Pok3r was announced, then waited for RGB's, saw the preview and NOW a change of mind).
What I'm looking for:
Colour: WHITE (with black keycaps would be nice, tho i can always buy them separate).
Switch Type: Cherry MX Browns (pref), Clears are okay as well
Size: Tenkeyless :) I don't want a full-size so anything below that would be nice. However 60%  keyboards lack the arrow keys therefore I'd opt away from them.
LEDS: White backlighting (To match a theme of my PC i just built and the mouse).
Just wondering if anyone has any suggestions of keyboard which may fit into the categories of what I'm looking for. I live in Australia so I guess there should be options :)
I have attached 2 images to display what I mean by wanting to match the overall theme :)
125331-0
125333-1
Thanks for taking your time to read this :)
« Last Edit: Fri, 22 January 2016, 10:19:08 by leiigghhh »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
I know it doesn't meet all you're requirements since it's fullsize, but the Ducky Year of the Goat is white with RGB backlighting and should come with browns
Offline Delirious
varmilo-va87mr
125348-0
The picture has orange led but you can have a choice between white, orange, or blue.
Offline falkentyne
The Year of the Goat is the best looking one that fits your criteria, but it's full size, as others said.  Plus there are very few new samples available to buy, and the few that are on china tmall are going to cost you north of $300.
The Varmilo VA87MR is not a directly sold keyboard.  It's basically a custom only available from a massdrop, which can come in Cherry MX switch or Gateron types and the drop is inactive.  This is a Chinese keyboard so it's very difficult to buy it.   Maybe you can try ebay for the "M" version which is the normal version, which doesn't seem to be available elsewhere.
http://www.ebay.com/itm/like/272019373878?ul_noapp=true&chn=ps&lpid=82
There are other links there too
http://www.ebay.com/itm/Varmilo-VA87M-Keyboard-Cherry-MX-Brown-switches-Side-printed-PBT-White-Cap-/272019373878?hash=item3f559e3f36:g:m9wAAOSwYHxWHqHm
This is probably your only option.  Everything else is Cherry clone switches.
 There are plenty of white keyboards with RGB backlighting that are TKL (you can just make it white) or fixed colors, but most are MX clones.  There's also the RK TKL white too.   http://www.banggood.com/RK-RG-987-87Keys-RGB-Backlit-Mechanical-Gaming-Keyboard-Greentech-Switch-p-979482.html
Offline leiigghhh
Hello :)
Thanks for the replies, after doing a lot of digging I was considering if it's possible to obtain a Filco Majestouch 2 case which is WHITE?
I found that WASD keyboards has a WASD Code TKL version which fits all criteria, apart from the case. I thought maybe it'd be possible to obtain a white TKL keyboard housing by some chance.
Despite this, i'm really unsure if the PCB will fit inside the casing?
Offline Oxid
  • resin rash and glitter
You can build a B.87 from Winkeyless.kr with a diffused acrylic case. Set the RGB lighting underneath to white and that would achieve effect you're looking for, I believe.
Offline Pdub
The KUL ES-87  - I have heard great things about it. But just heard things never touched.
http://elitekeyboards.com/products.php?sub=keyed_up_labs,tenkeyless&pid=es87u_ce_wss_al
Offline BearManJim
What about a 75% board like the Keycool Hero 84? Dedicated arrow keys included. :)
https://www.massdrop.com/buy/keycool-hero-84?mode=guest_open
I wanted to grab one but didn't feel comfortable using Massdrop?
Others have linked to AliExpress but I've only seen it on there with the Kailh switches?
http://www.aliexpress.com/item/White-LED-backlighting-keycool-84-PBT-compact-mini-mechanical-keyboard-kailh-mx-switches-game-keyboard-keycool84/32412641101.html
Noppoo Choc Mini 84S White (Gateron Black) - KBD75 (Grey, GMK screw-in stabs, Kailh BOX Navy, MAXKEY Foundation SA Keycaps)
Offline leiigghhh
I'm more into the standard layout of the TKL, prefer that simple setup as i guess it's easier to find stuff to mod the keyboards. Standard keyboard layouts offer better solutions to like keycaps etc.
I guess a cheaper option (since i am in Australia) would be the "varmilo-va87mr". White LED's and Cherry MX browns. This board does consist of the standard layout right? I'm not 100% sure.
I can always get the backlit doubleshot PBT BLACK keycaps somewhere online to match the colour scheme. I think the greatest importance is really the casing being white, along with the keys being Cherry MX Browns.
I've never used the other suggested keycaps and i guess i'm too afraid to vary towards them. Despite never owning a mechanical keyboard, using MX browns really made me want a keyboard with a proper tactile feeling.
Offline Megaweapon
varmilo-va87mr
varmilo-va87mr
Massdrop for this is live again.  Looks like most of the switch/case/key/LED combos were immediately sold out, though...
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
