Author Topic: F internals 50/49 key IBM  (Read 2312 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Fri, 22 January 2016, 18:32:50 »
Hey guys, I am looking at getting a 50/49 key IBM buckling springs board, but I want F internals over PCB, not membrane.
To my knowledge, these are going to be relegated to just the 4704 banking series, correct?
There are some other 49/50 key versions on ebay that look like they have the metal back plate styled like an F, and look like it has a foam and top plate similar to F, but it is clearly a Membrane inside.
Can anyone shed some proper light on this subject?  I would really like to replace my Orbweaver with an IBM.
Offline E TwentyNine
    • Some of My Keyboards
Re: F internals 50/49 key IBM
« Reply #1 on: Fri, 22 January 2016, 19:00:01 »
These were pulled apart here a while ago, believe it was F-like construction with M-like mechanicals.
I'm sure there's details buried here somewhere.
Offline Melvang
« Reply #2 on: Fri, 22 January 2016, 19:03:00 »
Yeah, that's the impression I was getting from the ones that orhilacrin has listed on eBay.
I wonder if Ellipse would allow others to use his suppliers for F parts and someone design a pcb and case for a FGH36.  I think there could be enough interest for that to do a run.
Offline fanpeople
« Reply #3 on: Fri, 22 January 2016, 23:21:20 »
From the Kish website it looks as if there was a 50 key that would be complete F
http://kishy.ca/?attachment_id=852
as the one in the picture does not have the ibm logo just like the others
Offline Melvang
« Reply #4 on: Fri, 22 January 2016, 23:30:24 »
Thanks for the link, any idea how often these pop up for sale?
Offline fanpeople
« Reply #5 on: Fri, 22 January 2016, 23:33:47 »
honestly I could swear that I have come across some for sale, specifically these ones. I just can't remember where. It may have been a parts site when I was digging deep of a kish or f77. I am going to do a bit of looking when I get home from work (also thinking) to try and remember where and if I have actually seen them.
Offline fanpeople
« Reply #6 on: Sat, 23 January 2016, 02:50:18 »
It was Ellipse. He found a bunch a while ago....
https://deskthority.net/f-o-r-s-a-l-e-f58/some-ibm-model-f-50-key-4704-keyboards-t9409.html
I think he sold them all but it couldn't hurt to hit him up about it.
