Author Topic: One key not working on new Ducky YOTG. Is desoldering the only option here?  (Read 2803 times)
Offline spanyam
  • Enjoy the gift of life!
The up arrow key is not working a new Ducky YOTG. The LED does not light up when pressed in reactive / reactive-advanced mode (but it does work in other lighting modes), and the keystroke does not register. I've contacted the retailer regarding their policies, but in case an RMA / return turns out to be too expensive, how do I go about looking into diagnosing and fixing it myself? I've never soldered/desoldered key switches before, so I hope that isn't the only option available. I'm open to learning it if that's the only option.
« Last Edit: Tue, 26 January 2016, 15:35:22 by spanyam »
SKCM Orange ALPS on Infinity 60% bent-metal case w/ hasu ALPS64 PCB and PBT blank DSA caps | KBP V60 w/ Matias Quiet Linears | IBM Model M | QFR w/ MX Blues
Offline lunatics
The only thing I'd be weary about with this board is that it has 2 PCBs in it and I saw someone asking about dissembling it on reddit and people weren't sure yet how the inside of the keyboard is set up and what would be required to desolder the key from it/them.
Offline spanyam
Ahh, yes. That's another issue. Also I just found out the backspace key sometimes sticks after being depressed. That, along with a slight "clankety" sound on all the stabilized keys, makes me want to return it for something more straightforward and local like a Filco, especially for daily use.
Here's the clankety sound I'm referring to, as well as the other issues on the board:
Other than the nonfunctional Up-arrow key, I am not at all happy with the feel and sound of the spacebar, backspace, or the enter, especially for such an expensive board. Is this sound and behavior normal fare for Ducky boards or RGB Cherry MX Reds in general? Or is this just a bad piece?
« Last Edit: Tue, 26 January 2016, 16:39:59 by spanyam »
Offline Corsa1r
I would RMA the hell out of that thing.
Ducky Shine 4 - Mx Blues // Ganss G.S-87 - Mx Browns // Type-S HHKB 45g // FC660M - Mx Reds // FC980M Silent Pink // Aula F75 Ice Veins // Rainy75 MMD Vivians
Offline spanyam
I'm leaning towards that as well. As a bonus, there are a few things I learned from this rather expensive (time- and money-wise) experience:
  • Linear switches are nice, but I might want to go with blacks over reds.
  • I LOATHE key rattle of any kind. If there's one thing that will make a keyboard feel cheap to me, it's this.
  • I prefer a tenkeyless board, much like my current Quickfire Rapid
So, given the above, what are some solid TKL boards with mx blacks that can be good for both gaming and coding? I would really want something with solid feeling keys that don't rattle. The QFR does a surprisingly good job at this, but the MX Black version seems to be out of stock everywhere.
« Last Edit: Tue, 26 January 2016, 18:09:23 by spanyam »
Offline Corsa1r
What I wouldn't be able to stand out of the box for a board like a Ducky is sticking keys and most of all, a key that simply doesn't work (plus the other stuff, mostly the defective led state).
Offline Geroximo
I would get rid of this board asap.
I do have a QFR with blacks. It is indeed a wonderful board.
Sadly the MX Blacks are just too heavy for my light fingers and I'm going to sell it sooner or later.
Offline appleonama
  • Trollo en USA
yeah rma that thing/return
I recommend the fc750r with black. It was the absolute best stock keyboard I've tried not even close to QFR .
« Last Edit: Tue, 26 January 2016, 18:11:20 by appleonama »
Offline spanyam
Thanks, I will RMA this. The stock on Cherry MX Black boards seems to be rather low now, so I'll just stick with the QFR blue that I have for some time. QFR blue is still a great board that miraculously recovered from this: https://geekhack.org/index.php?topic=78427.0
