Author Topic: How to figure that the key switch is Alps or Topre?  (Read 3819 times)
Offline Jaaaaaaaaaaaaaaaaaaaaaaay
« on: Sun, 31 January 2016, 05:41:39 »
126427-0
I'm looking for the Sony BKE 9400a, and as well known, this controller is made of Alps or Topre...
How to figure it out without pull one key out and see....
Does anybody know?
Ibm model M(Grey lable 1992)
GTune MKF20(kailh Blue)
Happy Hacking Professional 2(Black)
Realforce 87UB(Black)
Realforce 87UW45(White)
RC930 - 104 RGB(55g)
Filco Majestouch2 Tenkeyless(MX Brown)
Offline jerue
  • (Whenever that happens :P)
Re: How to figure that the key switch is Alps or Topre?
« Reply #1 on: Sun, 31 January 2016, 05:48:37 »
So these come in either white Omron switches or Topre...this should be easy if you can press a key
Is there any audible/tactile feedback? If not, omrons
Is there a deep thocking sound? Topre
This might apply, but this looks like the Topre version because of the side-printed legends on the blue keys on the home row - something that appears to be absent in the Alps versions. I say this without full confidence.
« Last Edit: Sun, 31 January 2016, 05:53:39 by jerue »
« Reply #2 on: Sun, 31 January 2016, 05:52:18 »
So these come in either white alps or Topre...this should be easy if you can press a key
Is there an audible click? White alps
Hmm. Can this be clarified by color or some looks?
Offline jerue
« Reply #3 on: Sun, 31 January 2016, 05:54:29 »
I edited my above post, sort of answers the question. They look identical in google image searches.
edit - again: the LED windows are rounded in the F keys, so this should be the Topre version. Alps/Omrons have square LED windows.
« Last Edit: Sun, 31 January 2016, 05:56:08 by jerue »
« Reply #4 on: Sun, 31 January 2016, 05:58:55 »
quote author=jerue link=topic=79238.msg2034447#msg2034447 date=1454241269]
[/quote]
Thanks a lot.
I appreciate that.
Offline Homenubbie
« Reply #5 on: Sun, 31 January 2016, 12:32:53 »
Thanks a lot.
I appreciate that.
Closed space on quote tag.
Offline Bucake
« Reply #6 on: Sun, 31 January 2016, 15:03:18 »
lol, arrow keys top right
cool board though, damn!
another board i wish to own..
