Author Topic: [IC] LeandreN Round 4 - PCBs, plates etc.  (Read 58199 times)
Offline chilldude_22
  • Official streetman
Re: [IC] LeandreN Round 4 - PCBs, plates etc.
« Reply #150 on: Mon, 22 February 2016, 10:14:32 »
GON's Side LEDs and extra electronics won't let the PCB be an immediate fit into a Tex Aluminum case. You'll want to use the acrylic and modify it. The screw holes fit as asked though.
I've put a Gon PCB in a TEX Aluminum case no problem. Granted I didn't use any bottom SMD LEDs, but I don't know why you would want to.
Offline Bumbibear
« Reply #151 on: Mon, 22 February 2016, 10:18:02 »
Is there any other type of aluminium case that is rather simple to acquire that you know would fit ?
Find any case without ridges, really. The MassDrop cast aluminum cases work, or the cases on Amazon right now also work (I think they're called iQunix Lambo cases).
Sweet! Found this one: http://dro.ps/b/eBi1m6F
Thank you! :)
Ducky Shine 3 TKL ISO
Soon: LeandreN GB 4 60% - Sentraq 78%
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #152 on: Mon, 22 February 2016, 13:45:47 »
Yeah, what he said. As long as there is not smd leds at the bottom, it should fit the alu case just fine :D
Offline axtran
« Reply #153 on: Mon, 22 February 2016, 14:07:30 »
All I'm saying is why buy GON PCB of you don't go all rainbow lightshow?
MX Silent > MX Vintage Black > Everything Else
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #154 on: Mon, 22 February 2016, 14:31:08 »
Already have a NerD TKL with an acrylic case for that  ;)
The 60% would be for something else  :)
Offline Chewypost
  • Bacon PanCAAAKES
« Reply #155 on: Mon, 22 February 2016, 22:08:53 »
Would 65% ever be an option? :0
Hana DSA - Duck Octagon V2| Ducky Mini - MX Red
_____________________________________
Offline Pinecone
  • Pine Switches
« Reply #156 on: Tue, 23 February 2016, 01:04:59 »
What SMD LED size would best fit the PCB?
Offline Ludovician
« Reply #157 on: Tue, 23 February 2016, 01:26:20 »
Have you checked out the Clueboard?
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline axtran
« Reply #158 on: Tue, 23 February 2016, 05:49:26 »
1206 SMD.
Offline Atredl
« Reply #159 on: Wed, 24 February 2016, 00:23:29 »
This is exactly what I needed to hear :D Count me in for a PCB in black  :thumb:
Offline Chewypost
  • Bacon PanCAAAKES
« Reply #160 on: Wed, 24 February 2016, 12:39:41 »
I have actually, but I'm more looking more for something with 4 keys along the side of the layout like this.
I've seen some Korean boards like this, but wanted to see if other places had it too.
Offline eksuen
  • Ambassador of explosions.
« Reply #161 on: Wed, 24 February 2016, 13:23:20 »
https://geekhack.org/index.php?topic=77434.0;topicseen
The buy already ran on Massdrop, but you may be able to pick one up second-hand.
Offline Chewypost
  • Bacon PanCAAAKES
« Reply #162 on: Wed, 24 February 2016, 13:52:16 »
Yah I saw that too. Looks beautiful and form is just what I wanted. I'm just looking into whether or not I can make a custom case for it and add some LED for the switches and for some underglow (rgb underglow).
Offline The_Skynacho
« Reply #163 on: Wed, 24 February 2016, 16:21:26 »
This is great, I am in for a PCB and plate. My case and zealios have been unused for too long.  :)
[Edited for clarity]
« Last Edit: Wed, 24 February 2016, 16:25:14 by The_Skynacho »
Offline grav3serker
  • graves + berserker = grav3serker
« Reply #164 on: Wed, 24 February 2016, 20:41:20 »
Would the RGB LEDs from Winkeyless work on the bottom of the board? If so, what would I need? Resistors come pre-soldered, right?
« Reply #165 on: Wed, 24 February 2016, 21:09:12 »
No, they won't work. Resistors and diodes will be pre-soldered if I remember right.
Offline grav3serker
« Reply #166 on: Wed, 24 February 2016, 21:16:36 »
So what LEDs can I use for the bottom? The SMDs from GON?
« Reply #167 on: Wed, 24 February 2016, 21:18:02 »
Yeah, they're standard 1206 SMD LEDs. You can get them on eBay for pretty cheap.
Offline grav3serker
« Reply #168 on: Wed, 24 February 2016, 21:19:24 »
Thanks a bunch!
Offline Fullcream
« Reply #169 on: Thu, 25 February 2016, 06:09:53 »
Hello, I'm sorry that I don't know anything. All I want to do is buy parts to build a hhkb layout board and want to be able to put LEDs through the switches and in to the pcb.
(short right shift, 2x1u instead of the standard 2u backspace on top row, bottom row: 1u/1.5u/7u/1.5u/1u, and stepped caps would be nice.)
So I guess I need a pcb, plate, and stabilizers. Am I in the right place?
Offline Jumie
« Reply #170 on: Thu, 25 February 2016, 06:24:36 »
You are.. Stay tune
Offline Fullcream
« Reply #171 on: Thu, 25 February 2016, 06:30:24 »
thanks m8.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #172 on: Fri, 26 February 2016, 04:03:13 »
Hi. Sorry for the lack of updates. I'm going to merge the winkeyless and HHKB buy into this one. Any orders for winkeyless and HHKB plates can be edited or cancelled now if you want. Still waiting for samples...
LeandreN
Offline TalkingTree
    • My projects
« Reply #173 on: Fri, 26 February 2016, 05:11:28 »
Will you handle merging the orders? I wanna add things from this IC to the HHKB plate I ordered.
Also, ETA on this GB?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #174 on: Fri, 26 February 2016, 05:13:34 »
No ETA yet. Need the samples and then shortly after, the GB will start.
I will probably delete orders and send a message to everyone to refill the form. I know this is very inconvenient, but it is way easier for me.
Offline TalkingTree
    • My projects
« Reply #175 on: Fri, 26 February 2016, 05:14:18 »
Yeah, that looks like the safest and easiest way.
Offline endeavour90
« Reply #176 on: Fri, 26 February 2016, 07:24:43 »
Hi, I am new to custom keyboard.
I checked the GON website, it offers Nerdy GUI to customize the keyboard layout but it is only available on windows.
Is there a similar software to edit keyboard layout in mac osx?
I don't really mind if it does not have the friendly interface, but getting a windows computer to edit the layout is too much for me  :D.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #177 on: Fri, 26 February 2016, 07:27:13 »
The software is Windows only. I checked this up for someone a couple of weeks ago. Unfortunate for for people who use OSX exclusively.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline grav3serker
« Reply #179 on: Mon, 29 February 2016, 13:01:10 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline TalkingTree
    • My projects
« Reply #181 on: Mon, 29 February 2016, 14:21:04 »
jump over here
https://geekhack.org/index.php?topic=79315.msg2037225#msg2037225
The form is still for HHKB and Winkeyless plates. Did you clear the (pre)orders or do you still have them?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #182 on: Mon, 29 February 2016, 14:24:59 »
jump over here
The submissions will be deleted. I will message everyone that entered.
Offline TalkingTree
    • My projects
« Reply #183 on: Mon, 29 February 2016, 14:29:23 »
jump over here
Roger that. Will the new form include orders for PCBs and universal plates as well?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #184 on: Mon, 29 February 2016, 14:30:44 »
jump over here
Correct
Offline TalkingTree
    • My projects
« Reply #185 on: Mon, 29 February 2016, 14:33:32 »
jump over here
Correct
You're mighty awesome, as always.
Offline bnthor
« Reply #186 on: Tue, 01 March 2016, 06:29:12 »
I'm in for a black plate and a black PCB, I just need to know, does the PCB is ISO compatible ?
OR even two of both... In that case one of the plates would be Red.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #187 on: Tue, 01 March 2016, 06:30:37 »
Of course. ISO is the only layout!
I'm nice to include ANSI support.
Offline bnthor
« Reply #188 on: Tue, 01 March 2016, 09:09:39 »
haha Great  ;) then I'm definitely in !
Offline bnthor
« Reply #189 on: Tue, 01 March 2016, 09:29:35 »
Sorry I'm a bit of a noob... but the Gon PCB should fit in there right ? it's said being compatible with
  • Poker/ Poker X/ Poker 2
  • GH60
  • Pure/ Pure Pro
  • Ducky Mini (MK1 only)
  • V60 (with 3 screws affixed)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #190 on: Tue, 01 March 2016, 12:09:34 »
  • GH60
  • Pure/ Pure Pro
It will work only if you're not soldering the smd leds but other than that, should be fine.
Offline bnthor
« Reply #191 on: Tue, 01 March 2016, 12:36:46 »
  • GH60
  • Pure/ Pure Pro
THX!
