Author Topic: Which keyboard layout is this?  (Read 2290 times)
Offline Caleb666
« on: Mon, 01 February 2016, 00:11:07 »
Hi,
I'm planning on getting my first mechanical keyboard but I can't quite find one that has the same layout as my current Logitech K750: http://blog.pc-magus.hu/wp-content/uploads/k750-920-002932.jpg
This looks like ISO layout, but what is different from other ISO layouts is that you also have the pipe key ("|") directly above the right shift key, which is very comfortable for a programmer like me.
I looked at various Topre keyboards, but none of their 105-key variants have this exact layout :-(.
« Last Edit: Mon, 01 February 2016, 00:53:33 by Caleb666 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Which keyboard layout is this?
« Reply #1 on: Mon, 01 February 2016, 00:13:24 »
Never seen a layout like that before. In theory, if you really wanted to you could just remap whatever key is typically where the pipe is on that keyboard to be a pipe. Then you could either use blanks, swap keys and have the wrong profile, or just leave the keycaps as is
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Tue, 09 February 2016, 09:37:40 »
That layout isn't different from basically any other ISO keyboard, except the Enter/Shift/Backspace/... keys are a bit narrower (0.5u I think).
The key between apostrophe and Enter is always backslash/pipe (assuming US QWERTY is used on the host computer), while the key between Shift and Z returns a distinct code (usually assigned to something like a pipe too).
« Reply #3 on: Tue, 09 February 2016, 09:39:26 »
That's known as US ISO. You won't find it on many keyboards.
