Author Topic: [IC] GMK TA Royal Alpha 610 Typewriter inspired set ~~~~~~GB LIVE!~~~~~~  (Read 159938 times)
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Re: [IC] GMK Royal Alpha Typewriter inspired set (Lime, Green and Cream)
« Reply #50 on: Tue, 02 February 2016, 22:44:38 »
U9 looks way off. L9 is good, as well as CP.
L9 has far too much yellow.  3K is still the closest, IMO, though it's really a color between 3K and 2B and closer to 3K.
The main reason I'm very vocally against L9 is because is it's the same color as the OG Cherry Alphas that are a dime a dozen.  I have thin lasered PBT and GMK AE mods from EK on my keyboard at work and there's not much difference between that and L9 with N7 legends.  3K is a far less common color and looks very good and it makes sense to me to have something that will have a little more contrast and is less common while still looking good.
I am with Nubbs. I trust his opinion!
Offline ileben
« Reply #51 on: Tue, 02 February 2016, 22:55:58 »
To me, the charm of the reference set comes from the two shades of green placed side by side. By splitting the two greens between mod background and alpha legends, this set completely loses that charm. I would prefer to see modifiers themselves in two different shades of green.
RF 87 55g (silenced) | FC660C (silenced) | Unicomp Ultra Classic | Filco MJ2 Brown | Matias Mini Quiet Pro
« Reply #52 on: Tue, 02 February 2016, 23:01:41 »
I need this for my GON.  :eek:
Also, I know this is primarily intended to be a TA green colored set, but I'll also throw out support for 3B in the interest of replicating CCnG.  :thumb:
Offline radio_killah
  • Chinchillin'
« Reply #53 on: Tue, 02 February 2016, 23:05:08 »
I think I might just abandoned my mod pack idea and through my support towards this effort.  :D
« Reply #54 on: Tue, 02 February 2016, 23:26:16 »
So, not 100% accurate (I couldn't use the spot tool to get a close enough color to what 3K really looks like), but here's a rough mockup with some of the ideas people were spitting out.  It's N7 on 3K Alphas and CP on AE and N7 mods.
And Keyboard Layout Editor link with rough color values in if anyone wants to play with it.
« Last Edit: Tue, 02 February 2016, 23:28:27 by nubbinator »
Offline ccarlitos2
« Reply #55 on: Tue, 02 February 2016, 23:33:19 »
This is great! Sign me up. Any chance on 1800 support?
« Reply #56 on: Tue, 02 February 2016, 23:35:07 »
That's up to MOZ, I'm just throwing samples out there for people to get an idea.
Offline ccarlitos2
« Reply #57 on: Tue, 02 February 2016, 23:36:09 »
Ah gotcha well I think it's an amazing idea! Great work nubbs
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #58 on: Wed, 03 February 2016, 01:11:12 »
Thanks a lot nubs for the photos and the mock up.
Currently I am leaning towards the TA group buy set as a base, most extra keys would be the same, with some other extras.
I am almost certain on using the colors numbs has mentioned, which is N7 on 3K for alphas and CP on AE for mods.
There will ofcourse be CODE keys, I'm think CP on AE and one in N7, not sure to have the deeper green as base or legend. I have emailed GMK for the available CODE legend keys.
1800, let's see, definitely will have a short right shift. Maybe a 1U "0 Ins"  and a 1U "+". I don't think having any other keys for profile matching is going to be worth it.
I'd like to know what keys would you like to see in the N7 green.
Offline MOZ
  • Busy making stuff
« Reply #59 on: Wed, 03 February 2016, 08:49:16 »
Quick mockup edit using Photoshop, with new suggested colors.
Offline ccarlitos2
« Reply #60 on: Wed, 03 February 2016, 08:52:28 »
Looking good :D!! And I'm glad to hear there will be a short shift
Offline lolpes
« Reply #61 on: Wed, 03 February 2016, 08:52:51 »
YES!
« Reply #62 on: Wed, 03 February 2016, 08:55:35 »
This is pretty much CCnG right? The mods are a bit brighter but the concept has definitely been executed before.
Offline lolpes
« Reply #63 on: Wed, 03 February 2016, 08:59:05 »
The alphas are light grey, ccng had cream alphas right? And the alphas lengends are of a darker green than the mods.
« Reply #64 on: Wed, 03 February 2016, 09:00:13 »
Yeah those are the details and you're right. But they're a pretty close match. Just something that came to mind. Not that it's a bad idea or set.
Offline lolpes
« Reply #65 on: Wed, 03 February 2016, 09:00:55 »
Also, may be a bit of overkill but include 3 colors of spacebars? light grey; lime; dark  green?
I wouldn't mind this the grey and dark green since lime green spacebars have already been made
Offline MOZ
  • Busy making stuff
« Reply #66 on: Wed, 03 February 2016, 09:06:04 »
Will have to include 6 space bars (3 colors, 6.25U and 7U). :/
Let's see how this develops, maybe the mod set and alpha set will be different and we run it through MD for a better chance of hitting the numbers.
Offline geniekid
« Reply #67 on: Wed, 03 February 2016, 09:43:26 »
Front printed Irish legends...too ambitious!?
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #68 on: Wed, 03 February 2016, 09:45:03 »
This is great looking! If there is a buy , I am 100% in.
Offline lolpes
« Reply #69 on: Wed, 03 February 2016, 09:47:48 »
Yeah it's a bit much, hence why i said it might be a good idea to drop the lime spacebars(already around)
If you do a separate pack for the alphas then it might be a good idea to print some sublegends in lime green?
Offline ba7777
« Reply #70 on: Wed, 03 February 2016, 09:58:29 »
How about make the whole green on white set then put a splash of green on the esc key or other two or three keys?
IMHO it would be more like the alpha 610 and more eye candy this way.
I don't mean the green mod is not good,  but it is just too intensive for me after staring at it for 2-3 minutes.
By the way, if the Irish legends could be include that would be perfect! Maybe pad print?
Offline geniekid
« Reply #71 on: Wed, 03 February 2016, 10:40:32 »
Maybe a complete N7 on 3K set and a separate pack for AE mods?  I know I'd buy one full set and 2 AE mod packs.
« Last Edit: Wed, 03 February 2016, 10:48:36 by geniekid »
Offline lolpes
« Reply #72 on: Wed, 03 February 2016, 10:45:47 »
Please stop saying green on white :x it's green on light grey
Offline MOZ
  • Busy making stuff
« Reply #73 on: Wed, 03 February 2016, 10:59:20 »
I though of that and felt it would be the best way forward. Full N7 on 3K 104+ISO+Tsanga and a mod pack like Bluegaloo, mostly CP on AE with a few CP on N7 mods thrown in.
Regarding the Irish, since it does already exist in dyesub form I'm not sure how much interest it will gather. The Irish legends will have to be pad printed like the Cyrillic set that Originative did, primary legends double-shot, secondary pad-printed. If we go that route, I think AE (Lime) colored Irish legends would be best. In all honesty, initially I had thought of having the Irish legends too, but thought due to the existence of the dyesubs, that idea would get shot down, which might still be the case :))
The advantage with all of this would be  that those that already have the dyesubs will have a nice mod set to go with them, those that don't can get the GMK set.
Offline FrostyToast
  • Litshoard
« Reply #74 on: Wed, 03 February 2016, 11:04:35 »
I thought it was already discussed before that GMK lost the molds for the r4 CODE keys since it was brought up in billnye's thread.
The only thing they have now is r1 "Code"
Quote from: elton5354
Offline MOZ
  • Busy making stuff
« Reply #75 on: Wed, 03 February 2016, 11:08:49 »
Wasn't aware of that. However it does look like they have started to provide custom legends, understandably pricier.
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #76 on: Wed, 03 February 2016, 12:33:12 »
That's a pretty nice colorway. We'll see b/c I'm still debating on that current pulse group buy (base kit, zambolos, planck, Fox, & forum kit). Not quite sure that I want to part w/ $217 for that keycap set. So, we'll see. Eitherway, if you get a gb going, will the planck &/or TKL kits include all the keycaps or will I have to buy the basekit? Sorry if someone already asked this b/c I didn't check all the comments.
« Last Edit: Wed, 03 February 2016, 12:43:12 by William_S_Jones »
    • WTB/WTTF Thread
« Reply #77 on: Wed, 03 February 2016, 13:03:58 »
I need this! Hopefully with partial 1800 support at the minimum.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #78 on: Wed, 03 February 2016, 13:11:18 »
That picture looks very familiar :D
Offline ileben
« Reply #79 on: Wed, 03 February 2016, 20:26:22 »
Yes I'd love having an option for full green/dark green mods or grey mods, so then I could put in just as much green as I want and on the keys that I want. Kind of what is commonly done with splashing red/blue mods over dark grey in Round 5/6 SA caps.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #80 on: Wed, 03 February 2016, 21:08:40 »
I have no idea why this set hasn't been done yet. This is what I'm talking about:
OH SWEET GEEZUS this key-set has to be done SOON.
The Grey and Green go together like mayonnaise and spit.
Please make this happen for 2016 because I know this will take off faster than a Dingo with an Itchy Arse .
« Last Edit: Wed, 03 February 2016, 21:13:29 by Elrick »
« Reply #81 on: Wed, 03 February 2016, 21:10:05 »
The Grey and Green go together like mayonnaise and spit   ;) .
Please make this happen for 2016 because I know this will take off faster than a Dingo with an Itchy Arse  :thumb: .
And a baby? Does the dingo have a baby?
Offline Elrick
  • Hype Master
« Reply #82 on: Wed, 03 February 2016, 21:14:56 »
Been proven false but they like blaming innocent animals for their filthy crimes, nothing new there.
« Reply #83 on: Wed, 03 February 2016, 21:16:14 »
DID A DINGO EAT YOUR BABY?
« Last Edit: Thu, 04 February 2016, 07:35:46 by romevi »
Offline mcwhirr
« Reply #84 on: Thu, 04 February 2016, 02:43:43 »
WOW~ Green YapetS Set
Offline geniekid
« Reply #85 on: Thu, 04 February 2016, 07:40:08 »
As far as layout support goes, I feel Skidata was well thought for a base set and Bluegaloo was well thought out for a mod pack.  Miami Nights also had a surprisingly low cost for a base set with HHKB/1800 support (and true Control/Caps Lock swap!) although we would probably want to convert all the R0 profile keys to R1 and R5 to R4.
Offline priyadi
« Reply #86 on: Thu, 04 February 2016, 11:23:27 »
Will definitely join this if it has short right shift and vendor neutral win keys (blanks are fine).
Boards: Filco TKL+HID Liberation, Infinity 60%, Sentraq S60-X, Whitefox, Ergodox, Planck.
Member of the flat keyboard society.
Keycap manifesto: "Key sets without vendor neutral Super key are worthless"
Offline HPE1000
  • Keycap Paparazzo
« Reply #87 on: Thu, 04 February 2016, 11:27:19 »
I need this
« Reply #88 on: Thu, 04 February 2016, 11:36:46 »
The more I stare at this the more it grows on me.
Like moss. Bright, vibrant, raw.
Offline xondat
  • i'm not a star
Offline MOZ
  • Busy making stuff
« Reply #90 on: Thu, 04 February 2016, 12:09:41 »
Great news guys, GMK are excited and fond of the color scheme we are going for. The mockups that I sent them were with the Irish sublegends. They don't have a bottom row CODE key buy they are going to produce the legends for this GB at no additional cost. Woo Hoo.
The basic pricing they have provided looks promising too. :)
« Last Edit: Thu, 04 February 2016, 12:22:46 by MOZ »
« Reply #91 on: Thu, 04 February 2016, 12:12:00 »
Great news guys, GMK are excited and fond of the color scheme we are going for. The mockups that I sent them were with the Irish sublegends. They don't have a bottom row CODE key buy they are going to produce on the legends for this GB at no additional cost. Woo Hoo.
Fantastisch!
Offline KaminKevCrew
« Reply #92 on: Thu, 04 February 2016, 12:21:29 »
Oooo! That's exciting! :)
Offline ccarlitos2
« Reply #93 on: Thu, 04 February 2016, 12:59:17 »
That sounds fantastic!!! So when does it start :p?
« Reply #94 on: Thu, 04 February 2016, 13:06:17 »
No kidding. I'm definitely down for a set.
Offline Dee1
« Reply #95 on: Thu, 04 February 2016, 14:41:19 »
I really love the colors in this. I can't wait! :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #96 on: Thu, 04 February 2016, 14:51:46 »
Yay!  :-*
Offline geniekid
« Reply #97 on: Thu, 04 February 2016, 15:30:39 »
That IS great news! ;D
Are the sublegends on top or on the front?  I worry if they're on top they will fade over time, although with GMK's clear coating it might be many years before any fading is even visible.  Personally I think top looks better than front so it's kind of a win/win for me.
Offline lolpes
« Reply #98 on: Thu, 04 February 2016, 15:34:35 »
Wow those are some amazing news!!
Offline WNovizar
« Reply #99 on: Thu, 04 February 2016, 16:43:05 »
Can't wait
I like mechanical keyboards
