Poll
Would you like to see this in one universal set, or smaller packs?
One Universal Set
209 (70.1%)
Individual kits
89 (29.9%)
Total Members Voted: 298
Author Topic: [IC] GMK Skeletor  (Read 226091 times)
Re: [IC] GMK Skeletor
« Reply #100 on: Sat, 06 February 2016, 04:09:28 »
I would prefer a green enter (like the Esc) instead of the yellow :/
Check out the OP  ;)
And I just realized that thesiscamper accidentally put the wrong color Esc and Enter based on the OP pic.  I kind of feel bad asking him to swap them to what the OP kit shows when he already kindly swapped the background.
« Last Edit: Sat, 06 February 2016, 04:13:25 by nubbinator »
Offline thesiscamper
    • Keyrenders
« Reply #101 on: Sat, 06 February 2016, 04:12:57 »
Check out the OP  ;)
I thought it was interchangeable and that everything was included in one big kit, should I change it?
"haters are confused admirers"
« Reply #102 on: Sat, 06 February 2016, 04:16:27 »
Check out the OP  ;)
They're both going to be included so that people can choose their preference.  I think either looks good, it's just not the original plan for the set to have that order.  I feel a little bad asking you to swap them, but if it's not a lot of work, it would be appreciated.  I got caught up in how awesome of a job you did that I didn't notice.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #103 on: Sat, 06 February 2016, 04:27:19 »
Poll: What color board would this look best on? Perhaps my LZ needs a re-ano job.
girlshark grey in 2016!
I think grey would work but I'm not really into grey boards :\
by the power of poor photoshop skills!
all the colors:
http://imgur.com/a/x0LRA
i think i like pink.
« Last Edit: Sat, 06 February 2016, 04:28:59 by naasfu »
    • Keyrenders
« Reply #104 on: Sat, 06 February 2016, 04:33:58 »
Check your inbox.  :thumb:
« Reply #105 on: Sat, 06 February 2016, 04:45:20 »
You're awesome man
« Reply #106 on: Sat, 06 February 2016, 04:48:44 »
Still throwing money at screen.
pls halp
Offline FLFisherman
  • I'd rather be fishing.
« Reply #107 on: Sat, 06 February 2016, 06:58:48 »
pls halp
Try throwing your credit card.
Offline 64rky
« Reply #108 on: Sat, 06 February 2016, 08:00:02 »
Sir
I never thought I would like these bright colors, but I must say, I will definitely be placing an order to help you hit MOQ, these look amazing.
I might have missed a messsage, but will there be 1800 support so I can put these on my Octagon/Lightsaver?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #109 on: Sat, 06 February 2016, 08:32:47 »
You're awesome man
Whoa that looks bright af  ^-^
One of the nicer gmk renders in recent times.
Offline ghostjuggernaut
« Reply #110 on: Sat, 06 February 2016, 09:05:36 »
Can't wait man! The render looks amazing.
Offline bloodl1n3
« Reply #111 on: Sat, 06 February 2016, 10:40:45 »
Sir
Same here. These colors are awesome.
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #112 on: Sat, 06 February 2016, 10:56:53 »
You're awesome man
MRW
« Reply #113 on: Sat, 06 February 2016, 11:38:42 »
Sir
Check out the Keyboard Layout Editor mockup in the OP.  That should cover the G80-1800 layout.  There's a 6u and 7u spacebar, 1u 0/Ins, 1u +, 1u -, 1.75u Shift, and then 1.5u Ctrl and Alt or 1u Ctrl, Alt, Win, Menu.
I still need confirmation that I have ISO covered (I went for basic UK ISO) and that the kit covers a bunch of other layouts like winkeyless, HHKB (aside from the spacebar), Pure, and so on.
Another question, should I keep the 1.5u Delete for HHKB, or do I add a pad printed backward delete symbol on the two \| keys?
« Reply #114 on: Sat, 06 February 2016, 11:53:35 »
all the colors:
Thanks bb! Maybe the wine red lz won't be so bad
Offline 64rky
« Reply #115 on: Sat, 06 February 2016, 13:48:13 »
Sir
shweeeeet!! Thank you sir
Offline ccarlitos2
« Reply #116 on: Sat, 06 February 2016, 14:18:18 »
Sir
I think it would be okay to just do the pad printed backward delete symbol
Offline njbair
    • nickbair.net
« Reply #117 on: Sat, 06 February 2016, 16:06:13 »
all the colors:
Somehow I like it on blue the best:
My boards:
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #118 on: Sat, 06 February 2016, 17:22:45 »
that's the current color of your LZ, right?  yeah it might still look good. :)
thanks to shark weekend, i can do basic photoshops now.
yeah, blue looks nice too.  all the colors seem to go reasonably well with the keyset as long as you like lots of colors.
Offline lashiel
« Reply #119 on: Sat, 06 February 2016, 20:46:55 »
Is it bad I'm considering this just so I can make Skeletorfuse?
« Reply #120 on: Sat, 06 February 2016, 21:28:59 »
Of course not.  We are accepting of all kinds.
Offline terminallytrill
« Reply #121 on: Sat, 06 February 2016, 21:41:01 »
was exactly what I was thinking
Offline N3RDLY
    • G33k.works
« Reply #122 on: Sat, 06 February 2016, 23:06:16 »
Hey nub any chance to get some blank modifiers as well.
Offline bbrotha
« Reply #123 on: Sat, 06 February 2016, 23:20:58 »
I'd build a new keyboard just for this set. Would I have everything I need for a HHKB layout? 7u spacebar also?
Norbaforce 87U 45g  -- HHKB Type S Blanks-- Kira Keyboard -- M65-A -- Novatouch
« Reply #124 on: Sat, 06 February 2016, 23:38:44 »
Probably not unless I did a separate kit.  I'm trying to make a mostly universal set (except the damn ergodox that takes a million odd caps) that's affordable.  I'm not really looking to add any caps unless they're essential.
Keep in mind that each larger key added is about $1-2.50.  To make blanks for an Ergodox, you'd be looking at an additional $15-20 on the base price most likely.  As you add more, that cost barrier becomes harder to overcome.
HHKB has a 6u space bar.  It's planned for the kit, but for G80-1800 compatibility since the spacebar is off-centered.  I don't know if any keyboards that support that layout will also support the off-centered space.  The Viper looks like it uses a 7u space bar (that's also included), but, again, I'm not sure what keyboards that support that layout use on the bottom row since I haven't kept up on that.
« Last Edit: Sat, 06 February 2016, 23:47:11 by nubbinator »
« Reply #125 on: Sat, 06 February 2016, 23:52:31 »
+1
Girlshark Grey pls
Offline N3RDLY
    • G33k.works
« Reply #126 on: Sun, 07 February 2016, 02:33:35 »
Thanks for letting me know I'll probably still get the set and make it work as I need :)
Cheers
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #127 on: Sun, 07 February 2016, 02:39:58 »
+1
Girlshark Grey pls
HALVERSON Y U NO GIRLSHARK GREY?
« Reply #128 on: Sun, 07 February 2016, 02:40:49 »
+1
Girlshark Grey pls
I just can't seem to get into silver or grey boards!
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #129 on: Sun, 07 February 2016, 02:42:41 »
+1
Girlshark Grey pls
grey goes well with everything, though.  i can throw anything on my dark grey GON and it looks good. :)
i love the brightly colored boards, but then i would be limited to certain keysets.
« Reply #130 on: Sun, 07 February 2016, 02:44:29 »
+1
Girlshark Grey pls
Yea but I am a difficult person and that's just how it is bb
« Reply #131 on: Sun, 07 February 2016, 03:47:55 »
Messing around and I think I have some favorites for you Halverson:
Magenta and Grey:
Green and Magenta:
Yellow and Pink:
Similar to these:
And a bunch of other colors:
« Last Edit: Sun, 07 February 2016, 03:49:51 by nubbinator »
Offline bocahgundul
  • a seal
« Reply #132 on: Sun, 07 February 2016, 03:51:26 »
This would look amesome with mistakemistake lz gh  :p
« Reply #133 on: Sun, 07 February 2016, 03:52:56 »
Awesome nubs! Love all the ideas :D
I think that pink wins hands down. I do love that first splatter one and most other brighter pinks. Wonder how I could get that effect on my case.
Offline Prelim
« Reply #134 on: Sun, 07 February 2016, 05:51:43 »
unicorn level /HIGH  :eek: :eek: :eek:
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline GeeNDL82
« Reply #135 on: Tue, 09 February 2016, 07:37:33 »
love it. I will be in with 1 full set
Vietnam Mechanical Keyboard Club: http://vietnammechkey.com/
Offline bbrotha
« Reply #136 on: Tue, 09 February 2016, 16:46:45 »
Hey guys, I made a quick image with the hhkb layout.
Also, by doing this layout I found out that a cyan column key in R1 might be needed :)
« Reply #137 on: Tue, 09 February 2016, 17:14:25 »
Oops, that \| cap was meant to be for HHKB layout.  Looks like I had a brain fart and messed up the color.  Thanks for catching that.
Edited because I'm retarded.
« Last Edit: Tue, 09 February 2016, 21:26:00 by nubbinator »
Offline livingspeedbump
    • KeyChatter
« Reply #138 on: Tue, 09 February 2016, 17:27:27 »
This set is is obnoxiously loud. I freaking love it  :thumb:
<- My Collection (so far)
Offline Niomosy
« Reply #139 on: Tue, 09 February 2016, 18:46:08 »
This could well be a family favorite for my household.  I'm guessing the kids will love it.
Offline W_hinklebottom
« Reply #140 on: Tue, 09 February 2016, 21:24:33 »
I was thinking the same thing. I'll sell it to the wife as a keyset for my daughter and then secretly use it myself. This is pretty rad.
Offline dyrdevil
« Reply #141 on: Wed, 10 February 2016, 00:36:00 »
When I first saw this IC I thought it was one of the ugliest colorways I had seen.
Now I'm thinking of modding my HHKB to MX and putting this on.
Offline N3RDLY
    • G33k.works
« Reply #142 on: Wed, 10 February 2016, 10:42:42 »
Don't you dare put that thought in my head.  :eek:
Offline honeynugget
    • /u/honeynugget on reddit
« Reply #143 on: Wed, 10 February 2016, 13:15:56 »
This colorway is so cool! I love how the colors just pop out at you and grab your attention.
Hope this turns into a group buy!
Offline Niomosy
« Reply #144 on: Wed, 10 February 2016, 13:24:34 »
That's a tricky game to play.  The little one might latch on to that set and fight you for it ;)
I'm lucky in that I've got the only keyboard Cherry MX compatible keyboard in the house.  That and the kids are pretty much used to laptops and just using the built-in keyboard.
« Reply #145 on: Wed, 10 February 2016, 13:44:46 »
I guess you'd just have to buy two then.  You know, one for the kid and a backup.
Offline Niomosy
« Reply #146 on: Wed, 10 February 2016, 17:48:25 »
Yup, I'm thinking there's going to either be some parents buying double or parents wishing they'd bought double from this set.
For the parents with daughters, perhaps getting Hana moving might work as well.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #147 on: Wed, 10 February 2016, 18:07:00 »
How would these look with yellow legends?
« Reply #148 on: Wed, 10 February 2016, 20:38:13 »
In my opinion, it would look awful.  It could work on the purple keys, but, IMO, it really disrupts the set.
Offline Bromono
  • Wanabe Cicerone
« Reply #149 on: Wed, 10 February 2016, 20:47:46 »
I see your point.
I just feel like its still missing something =/
idk
