Author Topic: 75% Mechanical Keyboard Options  (Read 7645 times)
Offline Carthik
« on: Sat, 06 February 2016, 23:06:10 »
Switch type doesn't matter as I'm still on the fence. Would like to know what all my options are.
Offline Malarkey
    • Keyboards for Programming
Re: 75% Mechanical Keyboard Options
« Reply #1 on: Sun, 07 February 2016, 00:21:29 »
The Noppoo Choc Mini seems to be a fairly popular 75% board.
I can't speak for the quality of the switches or keycaps, but its worth looking into.
Offline Bucake
« Reply #2 on: Sun, 07 February 2016, 02:22:23 »
kbt race (2) is an option
never owned one myself, no idea if it's any good in terms of quality
Offline Carthik
« Reply #3 on: Sun, 07 February 2016, 16:14:12 »
Thanks guys, keep em coming.
Considering there are multiple Noppoo Choc Minis on ebay for parts/not working, I'm not going to bother with it. Looking into the KBT RACE II.
Offline Leslieann
« Reply #4 on: Sun, 07 February 2016, 18:00:52 »
Here's my experience with the Race 1.
The Fkeys are very close to the the number row, something most are not used to, and while it sounds like a minor problem, the FN key happens to be just above the Backspace and it's very easy to clip the FN key when using backspace. This triggers a modifer, opening the calculator and steals focus. If you tend to use backspace a lot, it can really be a problem.  I like my Race, but after weeks of trying to adapt, I finally had to put a shorter key cap on the FN key to stop it from happening. Also, beware, the keycaps may very well be garbage, they were on the original Race (painted over clear), I know they have made advances there, but I don't know if they are included. My legends lasted through one week of hard use (they sent me non-backlit replacements). The originals were also known to have LED problems, and they are not very stiff due to the lack of a plate (not sure if the new one has one). The cases were also painted on the original, which flaked off. Like I said, I liked the keyboad, but considering how much I paid, it wasn't worth it. Oh, and don't base your ideas of reliability on availability of parts, you don't see Race parts for sale because not many have been sold as they were/are hard to find and can cost quite a lot.
You also may want to take a look at the 68key Magicforce keyboards. So far, I'm liking it more than my 75% and my TKL. I posted a review in the Review section.  It's cheaper than 75% boards and better made than any I've seen. I could have bought 4 Magicforce for what I paid for my Race.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline merlin64
    • MechMerlin
« Reply #5 on: Sun, 07 February 2016, 21:16:35 »
Look at the Mk84 on mechanical keyboards.com
Offline xondat
  • i'm not a star
« Reply #6 on: Mon, 08 February 2016, 02:10:53 »
FYI the VE.A is a 75% (for the most part). Price and availability will be the hard part about this board.
Offline merlin64
    • MechMerlin
« Reply #7 on: Mon, 08 February 2016, 10:42:25 »
Don't forget non standard keycaps for that bottom row!
Offline Carthik
« Reply #8 on: Fri, 12 February 2016, 02:06:52 »
Came across the Keycool 84. Does anyone still stock this board with MX switches or have they been discontinued for the Kailh switches?
Offline darkclone24
« Reply #9 on: Fri, 12 February 2016, 02:15:33 »
Massdrop group buys seem to have access to Cherry switches.
For example: https://www.massdrop.com/buy/keycool-hero-84
That means waiting, however, for the next drop. So far as I'm aware, they're only available in Kailh from retailers.
RS84 67g Zealio Purple | Choc Mini MX Black | WASD V2 MX Clear | Golbat 78g Zealio Purple | Duck Octagon V2 MX Clear
Offline Carthik
« Reply #10 on: Thu, 03 March 2016, 00:28:08 »
Bump, still haven't found a quality 75%. Other options?
Offline segfault
« Reply #11 on: Thu, 03 March 2016, 00:53:17 »
The only other board I've seen that is readily available is the Cherry G84-4100, though it uses ML switches which I have no experience of. If you don't mind the DIY route, there is the Winkeyless B.Mini [ref].
Offline klennkellon
  • I like bottoming out
« Reply #12 on: Thu, 03 March 2016, 01:50:08 »
Matias Mini boards. They use Matias switches which are a lot of fun to type on imo.
Offline xondat
  • i'm not a star
« Reply #13 on: Thu, 03 March 2016, 01:57:13 »
Have you seen the Winkeyless.kr B.mini?
Offline Carthik
« Reply #14 on: Sat, 05 March 2016, 01:41:41 »
Anyone have experience with winkeyless? I'm really liking the design, and I wanted a matching number pad so that works well. Seems to be very similar to the very expensive GON (out of Korea too?), is winkeyless a knockoff of them?
« Last Edit: Sat, 05 March 2016, 01:43:15 by Carthik »
Offline xondat
  • i'm not a star
« Reply #15 on: Sat, 05 March 2016, 01:53:54 »
Winkeyless are regarded as great quality, however it is acrylic so you have to remember that. I wouldn't say it's a knock off, just an alternate brand. WKL are good boards from what I can tell, reddit loves them.
Offline Carthik
« Reply #16 on: Sat, 05 March 2016, 15:11:09 »
Can you elaborate on the cons of the acrylic composition?
Offline Tactile
« Reply #17 on: Sat, 05 March 2016, 15:52:01 »
I'm surprised no-one has yet mentioned the Deck 82.
http://deckkeyboards.com/product/deck-82
REΛLFORCE
Offline merlin64
    • MechMerlin
« Reply #18 on: Sat, 05 March 2016, 16:11:01 »
Since someone mentioned the Winkeyless, I'm assuming customs aren't off the list?
In that case I would recommend the GON mx-mini and Duck Octagon
Another non custom option would be: http://www.amazon.com/DSI-Modular-Mechanical-Keyboard-Cherry/dp/B00E6EIY90
