Author Topic: Gateron vs Cherry switches  (Read 45741 times)
Offline jcoffin1981
« on: Sun, 07 February 2016, 02:54:50 »
These Gateron switches have been around for a while now, and I was wondering what people's opinions were vs. the two keyboards.   I honestly cannont decide 100!% so I keep them  both on the desk and switch back and forth.
The Gateron brown is lighter and smoother.  I also replaced the keycaps with very expensive aftermarket  PBT keycaps.  I have to say there may be some quality control issues with the V60 Gateron boards.  My  originial was shipped the wrong model.   The second was damaged and caused the spacebar to repeat almost every stroke.  Turns out the frame was bent at the spacebar.  This is my third one and I love it, but  I still experience the spacebar chatter, though not as frequently.
The  Poker 3 has Cherry Brown switches and I like it very much.  It's stiffer compared to the GTR, but there is no chatter anywhere.  However some of the keys ping, which drives me nuts.  I'm also not a fan of the keycaps,  but it's still much better than the standard Dell ABS.  I'm just curious where other's opinions stand on this.
Offline bocahgundul
  • a seal
Re: Gateron vs Cherry switches
« Reply #1 on: Sun, 07 February 2016, 03:01:06 »
I have to say that modern cherry sux ass and gateron is better than this modern cherry mx. But nothing can beats vintage worn cherry mx
Gateron might feels lighter cause its smoother than the modern cherry that you got
Offline jcoffin1981
« Reply #2 on: Sun, 07 February 2016, 22:45:17 »
There is no question, the pressure  to actuate the  switch is definitely lighter.  I think they both actuate at about 45g, but the cherry brown switch has to overcome the peak resistance, which is around 55g.  With so little resistance to press the Gateron brown, I find that just resting my fingers on the home row I get accidental keystrokes, which I never get with Cherry.
One thing that absolutely drives me bonkers is the chatter or extra keystrokes, specifically on the space bar.  I  constantly have to go back and correct these mistakes.  If anyone has any tips on how to combat this I'd be much oblidged.  I did update the firmware to V107, which is the most recent.  Somedays I think I like the Gateron V60 better, and others I  like  the poker 3 better.  I can't decide, so I keep both.
Offline gain
« Reply #3 on: Sun, 07 February 2016, 23:20:54 »
I've converted to Gateron for the most part
Just need an equivalent to the MX White without me butchering god knows how many and we're good  :thumb:
So far I'm not a fan of the new switch housing, maybe my stance will change after I see them in person,
« Last Edit: Sun, 07 February 2016, 23:53:21 by gain »
« Reply #4 on: Sun, 07 February 2016, 23:28:03 »
Although I'm sure my stance will change after I see them in person, so far I'm not a fan of the new switch housing.
I'm confused by your last statement. Your stance will change once you see them in person? So you haven't used Gateron?
And you're not a fan of the new Gateron housing, the black and transparent?
Offline gain
« Reply #5 on: Sun, 07 February 2016, 23:52:45 »
My bad, a little brain dead today!
Nah I have a misc pile of them already with the old housing, just not sure how to feel about the fully translucent housing they now have.
Maybe I just need to see them in person.
« Last Edit: Sun, 07 February 2016, 23:54:21 by gain »
Offline axtran
« Reply #6 on: Mon, 08 February 2016, 07:01:06 »
To be fair, the new housing is a transparent top and what looks like (depending upon batch) a black or a white colored base. The transparent bases I've only seen from Zeal's switch orders. They're just as smooth, albeit manufactured quality I'd say higher than the stock, "frosty" Gateron switch.
MX Silent > MX Vintage Black > Everything Else
Offline bocahgundul
  • a seal
« Reply #7 on: Mon, 08 February 2016, 17:41:38 »
Make room for the Grandaddy of them all
Hey that isn't a Pro 2 >:D
This is cool tho
We can use gateron housing without making any feel difference right? I love those translucent housing
Offline saxophone
« Reply #8 on: Tue, 09 February 2016, 05:00:33 »
A bag of Gateron RGB reds just arrived. I believe the "RGB" is simply used to indicate that it's the new batch as all the listed RGB ones on taobao are ones with the newer black housing + clear top rather than the old frosted ones.
First impressions: Just pushing down the slider directly shows that it's criminally smooth :p.
I think that the difference doesn't like in only the plastic, but also in the construction of the housing: there's 2 outdent lines on the walls where the slider usually would be touching the housing, resulting in decreased contact surface and less friction from just that.
Anyways these things are amazing, I bought these to swap out the switches on my Zhuque swappable switch keyboard. If I had soldering equipment I'd definetly buy more and replace the switches on my other keyboards as well. Note the fact that there are no holes on the bottom of the casing for the SMD to glow through despite the switches being labeled RGB on taobao. Maybe you're supposed to cut out the hole by yourself? No idea.
Offline iLLucionist
  • Topre is Love.
« Reply #9 on: Tue, 09 February 2016, 09:02:18 »
Topre-smooth?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Tue, 09 February 2016, 09:45:24 »
Of course Gaterons are smooth, they drown them in lube xD .
Offline jacobolus
« Reply #11 on: Tue, 09 February 2016, 10:08:10 »
Half this list (https://deskthority.net/wiki/Category:Linear_switches) is nicer than Cherry MX from the 80s [not really surprising... the older nicer switches cost a lot more to produce]. And there are plenty of linear switches that never made it to that list.
I agree that 80s MX switches are nicer than the current ones or most of the MX clones though.
« Last Edit: Tue, 09 February 2016, 10:13:09 by jacobolus »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12 on: Tue, 09 February 2016, 10:13:30 »
Half this list (https://deskthority.net/wiki/Category:Linear_switches) is nicer than Cherry MX from the 80s. And there are plenty of linear switches that never made it to that list.
I'd really love to try a Hall Effect board someday...
Offline crickclackman
« Reply #13 on: Tue, 09 February 2016, 10:53:18 »
More luuuubbbbeeee!
Offline saxophone
« Reply #14 on: Tue, 09 February 2016, 14:33:17 »
No actually, I opened two of the switches to check. They're totally dry on the inside. There's no denying that the difference lies in the material that the slider is made out of.
Offline Corsa1r
« Reply #15 on: Tue, 09 February 2016, 15:11:34 »
I'm also quite interested in Gaterons since finding the sound of vintage cherry blacks so nice to hear, and from what I've been told, Gateron blacks seem like they get a similar effect without all the screwing around under the hood.  (Which could end up being fun, but I don't really have the time).
Ducky Shine 4 - Mx Blues // Ganss G.S-87 - Mx Browns // Type-S HHKB 45g // FC660M - Mx Reds // FC980M Silent Pink // Aula F75 Ice Veins // Rainy75 MMD Vivians
Offline bocahgundul
  • a seal
« Reply #16 on: Tue, 09 February 2016, 17:45:06 »
B-b-b-but he said cherry vs gateron right?
Well I'd love to try hall effect board tho is it possible to make a modern hall effect board?
Offline Geroximo
« Reply #17 on: Tue, 09 February 2016, 18:20:23 »
I'm waiting for my gateron black board to arrive ... SO excited how they compare to Cherry MX
Offline Corsa1r
« Reply #18 on: Tue, 09 February 2016, 18:41:34 »
Oooh, which board did you get?  I've been looking around for a nice board with Gateron blacks.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #19 on: Tue, 09 February 2016, 19:24:23 »
The Varmilo VA87MR is on Massdrop right now for $110. From what I've heard it's a decent board for the money
edit: nvm, all the Gateron options seem to be out of stock
« Last Edit: Tue, 09 February 2016, 19:26:11 by hwood34 »
Offline Corsa1r
« Reply #20 on: Tue, 09 February 2016, 22:09:22 »
I looked yesterday!  And saw that they were all sold out.  Are full Gateron-black boards hard to find put-together in general right now?
Offline Bevo
« Reply #21 on: Tue, 09 February 2016, 22:13:01 »
How do gateron blacks feel compared to vintage blacks? Pretty similar?
Offline Corsa1r
« Reply #22 on: Tue, 09 February 2016, 22:57:40 »
I want to know all of this.
Offline bocahgundul
  • a seal
« Reply #23 on: Tue, 09 February 2016, 23:51:20 »
Wait till I get my hands on one bae
Offline Bevo
« Reply #24 on: Tue, 09 February 2016, 23:55:32 »
Hurry up!
Offline bocahgundul
  • a seal
« Reply #25 on: Tue, 09 February 2016, 23:56:43 »
Hurry up!
You can wait bae
I have some incoming! Just need a Vintage black
Offline Bevo
« Reply #26 on: Tue, 09 February 2016, 23:58:23 »
Hurry up!
You can wait right bae?
*waits patiently*
Offline ideus
  • Björkö.
« Reply #27 on: Wed, 10 February 2016, 11:33:13 »
Anyone has had experience with green Gateron's?
« Reply #28 on: Wed, 10 February 2016, 11:45:30 »
Aren't they a little too new?
Aren't they a little too Raph?
Offline ideus
  • Björkö.
« Reply #29 on: Wed, 10 February 2016, 12:41:09 »
That is precisely why I am asking.
Offline xepherys
« Reply #30 on: Wed, 10 February 2016, 13:55:36 »
I'm just jumping back into mechanical keyboards and ended up getting a switch tester to try four brands of blue, black, brown, and red switches.  I'm personally planning to pick up blues and really prefer the Cherry MX, but in the browns I like the Gateron's better - they feel smoother and have more... feedback for lack of a better term.  Actually, I think I prefer the Gateron reds over the Cherry as well.
Offline falkentyne
« Reply #31 on: Wed, 10 February 2016, 19:10:01 »
You have to open the switch and bend a small metal contact a very small amount to fix the chatter.  There was a detailed post on that, with pictures, awhile back but I don't have it.  You can try to search for the post.  I believe new runs of those switches fixed that issue.
Offline bocahgundul
  • a seal
« Reply #32 on: Wed, 10 February 2016, 19:12:16 »
Where can I find the new run ones? I want to buy gateron switch but I don't want to run into this issues
Offline 1391406
« Reply #33 on: Wed, 10 February 2016, 19:21:59 »
So if Gateron's are smooth, how do they compare to Topre?
Offline falkentyne
« Reply #34 on: Wed, 10 February 2016, 22:19:05 »
You can't compare Cherry MX switches to Topres (Gaterons are a clone of Cherry MX).
It's like trying to compare Topres to Alps or Alps to Beam springs.
Completely different kind of switch.
You have to actually buy a Topre (or find a switch tester for one, if one even exists).
Alps seem like they are more well known because many older keyboards used Alps or clicky alps, so they're considered a vintage type switch also.   The old Apple 2/Apple 2C and IIGS and other keyboards I believe used them.
Offline bocahgundul
  • a seal
« Reply #35 on: Wed, 10 February 2016, 22:21:57 »
@falkentyne I think what his trying to compare is the smoothness of gateron to topre
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #36 on: Wed, 10 February 2016, 23:30:32 »
I would like more tactile options.
Offline 1391406
« Reply #37 on: Wed, 10 February 2016, 23:56:36 »
Correct.
Offline 1391406
« Reply #38 on: Wed, 10 February 2016, 23:58:52 »
Sure you can. People do it often. Topre feels closest to either MX Red or Brown, in my opinion. MX Browns aren't as smooth as Topre though, and feel a bit scratchy by comparison to me. However, I was curious about the smoothness of Gateron switches vs. the smoothness of Topre switches.
« Last Edit: Thu, 11 February 2016, 00:02:16 by 1391406 »
Offline bocahgundul
  • a seal
« Reply #39 on: Thu, 11 February 2016, 00:41:00 »
Nope we can't compare the feel of topre to any other switches!
Its crazy when you think that tomatoes is the same as steak 😂
Offline antCB
« Reply #40 on: Thu, 11 February 2016, 06:22:36 »
had MX Blacks on my 6GV2, replaced them all last month with Gateron Blues. Chattering went away, and the keyboard gained a new life (IMO).
the keycaps also seem to be a tighter fit with the Gaterons opposed to the MX Blacks. Some keycaps were extremely easy to take apart with the MX Blacks, now they sit tight on the switches.
Steelseries 6GV2 ISO-PT with Gateron Blues.
Offline tronbeaver
« Reply #41 on: Thu, 11 February 2016, 08:31:29 »
Gaterons are overhyped.  Don't they have switch chatter?
Offline bocahgundul
  • a seal
« Reply #42 on: Thu, 11 February 2016, 08:39:23 »
Nah don't listen to this trolls
They fixed the chatter issues tho
Offline 1391406
« Reply #43 on: Thu, 11 February 2016, 09:02:16 »
Too late, I already have.
I'm guessing no one who's reading this has used both Gateron's and Topre.
Offline Vittra
  • Airflow Optimizer
« Reply #44 on: Thu, 11 February 2016, 09:20:47 »
https://geekhack.org/index.php?topic=78773.msg2048910#msg2048910
Zealios are modified Gaterons to give some frame of reference.
I have Gateron Yellows on order from MD, but I don't expect to use them for quite some time for a direct comparison.
Filco MJ Linear R LE TKL
Offline iLLucionist
  • Topre is Love.
« Reply #45 on: Thu, 11 February 2016, 09:24:31 »
Is Topre tomatoes or steak? :P
Offline reallifetim
« Reply #46 on: Thu, 11 February 2016, 12:18:00 »
Good read here on some Gateron Black vs Cherry Black, even some vintage comparisons.
https://geekhack.org/index.php?topic=70676.0
« Reply #47 on: Thu, 11 February 2016, 12:57:01 »
Vintage Blacks are GOAT. Been itching to get back to my B.face with Vintage Blacks, but waiting for a keycap set before pounding on it again.
Offline iLLucionist
  • Topre is Love.
« Reply #48 on: Thu, 11 February 2016, 14:14:36 »
Nice, didn't knew about that.
Offline OwlWatch
« Reply #49 on: Thu, 11 February 2016, 16:22:42 »
I personally prefer the Cherry switches, from what I have seen gateron switches always seem to get stuck when you first press them.
