Author Topic: My first hand wired mechanical Keyboard  (Read 8769 times)
Offline RevLinux
« on: Mon, 08 February 2016, 14:50:57 »
https://imgur.com/a/FJuFO
Thanks to everyone here.
I did a LOT of lurking, reading, and swearing; but I finally got it finished.
Offline animal
Re: My first hand wired mechanical Keyboard
« Reply #1 on: Mon, 08 February 2016, 14:58:45 »
Looks good. I like the plate.
Do you have your modifiers upside down?
Real men do it with a keyboard.
Offline RevLinux
« Reply #2 on: Mon, 08 February 2016, 15:04:43 »
Thanks, it was a good time building this.
I don't think anything is mounted upside-down.
Also, if you like the plate I have plenty of spares (there was an MOQ when I had them made)
Offline regack
« Reply #3 on: Mon, 08 February 2016, 15:17:36 »
I was about to ask where you got them, but I guess you had them made?  I imagine you could move some of them in the classifieds if you have a bunch of extras, they look good.
Offline RevLinux
« Reply #4 on: Mon, 08 February 2016, 15:24:51 »
That's a great idea, I'll have to look at the posting guidelines in the classifieds and put a post together.
Thanks
Offline RevLinux
« Reply #5 on: Mon, 08 February 2016, 15:52:43 »
Well, I guess being a filthy  lurker isn't all sunshine and roses.   ;)
My post count isn't high enough to make a post in Classified.
Maybe later.
Offline regack
« Reply #6 on: Mon, 08 February 2016, 16:15:43 »
Maybe later.
I forgot all about that, sorry...
Offline RevLinux
« Reply #7 on: Mon, 08 February 2016, 16:33:07 »
No need to apologize!
As a matter of fact, every time you needlessly apologize, I get to needlessly reply, and my post count goes up!
So, thanks!  :thumb:
« Reply #8 on: Mon, 08 February 2016, 17:16:00 »
That looks really smooth with the bent plate as a case and the wiring's nice and tidy too - good work!
Are the blues louder without a case around them or less loud as they don't have an echo chamber?
Offline evangs
  • TheVan
« Reply #9 on: Mon, 08 February 2016, 17:44:07 »
nice looking board, good job!
Offline RevLinux
« Reply #10 on: Mon, 08 February 2016, 18:11:43 »
Thanks!  I worked hard on it, and it was a blast to build.  I've built about 4 more since I did this one (trying to burn thru all of these left over plates), and the are all getting easier and more "tidy" as I go.
I'm not sure "less loud" is right, but it seems ... less.  Just less. No echo.  It doesn't seem to "ping" from bottoming out like blues in a case do. It feels more solid than any other (inexpensive) keyboards I have used because of the heavy steel.
Overall, it's the best board I've could hope for.
Offline RevLinux
« Reply #11 on: Mon, 08 February 2016, 18:12:17 »
Thanks!  That means a lot coming from this group.
Offline studentben
« Reply #12 on: Mon, 08 February 2016, 20:56:49 »
How long did it take you?
I know you said it was your first hand wired mech, but did you have any soldering experience before?
I was considering starting out a hand wired project, but I'm not sure how long it would take. Someone gave me a soldering iron for Christmas, and it's just been sitting at my desk unused... Haven't soldered since like grade 8 which was a long time ago, so I'm kind of worried about that.
Offline RevLinux
« Reply #13 on: Mon, 08 February 2016, 21:24:31 »
It took me a looooong time only because I wanted it to be my afternoon hobby. It was really relaxing to work on it (2 of them) every day after work for a few weeks.
If i were to put it into hours, I'd say 10ish. 30 minutes here, 20 minutes there.
I can finish one a LOT more quickly now.
Offline neverused
« Reply #14 on: Mon, 08 February 2016, 21:31:20 »
Looks great, do I see both dsa and oem/dcs/cherry profile caps together?
Offline RevLinux
« Reply #15 on: Tue, 09 February 2016, 06:12:01 »
Yup, you do.
I was just throwing on leftover caps to get a picture.
Offline thatllbeme
« Reply #16 on: Tue, 09 February 2016, 06:50:49 »
That looks great!  What was your technique for bending the metal like you have?
Offline RevLinux
« Reply #17 on: Tue, 09 February 2016, 07:47:17 »
It was part of the custom design I had made. So, the fabrication shop took care of that for me.
Offline RevLinux
« Reply #18 on: Tue, 09 February 2016, 18:53:26 »
I still do not have enough posts to make a thread in Classifieds, so I started a thread on r/MechMarket
https://www.reddit.com/r/mechmarket/comments/44z87d/usoh_h_steel_60_plates_w_paypal/
Offline regack
« Reply #19 on: Tue, 09 February 2016, 20:14:53 »
Good luck!  I like that shot of the box of plates :D
Offline funderburker
« Reply #20 on: Thu, 11 February 2016, 05:43:05 »
Really a wonderful build. Wanted to ask about the plate a bit more because I'm searching a shop where to do my own custom plates. Is it cut with a laser cutter/waterjet or CNC'd?
Keyboard design by Skepur
Offline RevLinux
« Reply #21 on: Thu, 11 February 2016, 06:28:03 »
It's laser cut.  I asked about the other methods, but they said that the laser cutter was the most cost  effective and had the tightest tolerances.
Offline xondat
  • i'm not a star
« Reply #22 on: Thu, 11 February 2016, 12:56:20 »
I really like the plate/case. I think it's brilliant - I believe GON sells this as the 'skinny' case.
Would you consider other layouts, or PCB compatibility for your future?
Offline RevLinux
« Reply #23 on: Thu, 11 February 2016, 13:43:36 »
Never saw that "Skinny" case before. It looks nice.
I think next time I do this, I'll try to make the plate with a hole for the USB port on a PCB.
