Author Topic: New PCB for my 60% build - which one? (Satan GH60 / AMJ60 PRO2.0)  (Read 7677 times)
Offline hKing
  • I am ze Ubermensch!
« on: Fri, 12 February 2016, 15:24:57 »
As mentioned above.
I am planning a new 60 % build for myself. Case and plate will be black.
The main requirement would be a pre-soldered board as I am a total noob when it comes to soldering :)
Which one can you recommend?
Satan GH60
http://www.ebay.com/itm/SATAN-pre-soldered-DIY-GH60-Keyboard-PCB-support-Breathing-LED-60-cherry-MX-/272032784852
AMJ60 PRO2.0
http://world.taobao.com/item/42204599599.htm?fromSite=main
(Is this pre-soldered????)
A more pricey one would be a Bface X2. Price is pretty steep compared to the above mentioned.
Which one can you recommend? Are there better alternatives?
I'd prefer a black one for color matching...
Offline Moistgun
  • Slippery When Wet
Re: New PCB for my 60% build - which one? (Satan GH60 / AMJ60 PRO2.0)
« Reply #1 on: Fri, 12 February 2016, 15:34:45 »
I have a 60satan.
Worked well for me.
Got it from that seller as well.
Any specific questions about it? I have no experience with any other pcbs.
Offline hKing
« Reply #2 on: Fri, 12 February 2016, 15:38:34 »
I am asking myself if the white color of the pcb will be visible when the keyboard (black case, black plate) is fully assembled.
What kind of firmware does it use - any problems with it?
Offline TalkingTree
    • My projects
« Reply #3 on: Sat, 13 February 2016, 02:59:29 »
If you're not on a rush, you can get Gon's NerD 60 through LeandreN's Round 4.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #4 on: Sat, 13 February 2016, 03:01:29 »
This seems like an ok option.
Offline appleonama
  • Trollo en USA
« Reply #5 on: Sat, 13 February 2016, 03:16:57 »
just go for gh60
the gon is cool and all but wait times are insane
Offline TalkingTree
    • My projects
« Reply #6 on: Sat, 13 February 2016, 03:26:19 »
That's why I suggested to get it through LeandreN's Round 4. Gon promised not to delay orders in his GB and LeandreN's orders are usually completely shipped out within two months from him.
Offline hKing
« Reply #7 on: Sat, 13 February 2016, 04:27:06 »
Hm, I don't know, it's only an IC
I wanted to assemble it in march / april when Zeal ships his R2 Zealios ...
Is there an ETA on those PCBS?
Money isn't the problem. Maybe I just buy it straight from his shop.
Am I right that the won't be that much of a difference between Satan GH and Gon's NerD?
/edit
Nevermind, I think I'll go with the FaceW 60% in black. Found this PCB on MK.com!
« Last Edit: Sat, 13 February 2016, 06:17:25 by hKing »
Offline ctm
  • Hello, world!
« Reply #8 on: Sat, 13 February 2016, 11:30:22 »
I have a 60satan.
Worked well for me.
Is GH60 Satan exactly like GH60? Can I flash in TMK for GH60 without any modification?
Coming:
Ellipse Model F F62.
Offline Moistgun
  • Slippery When Wet
« Reply #9 on: Sat, 13 February 2016, 11:32:06 »
I just run the tmk toolkit,  run setup, drop my keymap.Eep onto the refresh.bat.   And it's remapped .
Offline Moistgun
  • Slippery When Wet
« Reply #10 on: Sat, 13 February 2016, 11:48:12 »
I have a 60satan.
Worked well for me.
And I don't know much about the gh60 other than it doesn't support leds
Offline appleonama
  • Trollo en USA
« Reply #11 on: Sun, 14 February 2016, 14:58:57 »
This is just my opinion but it's kinda cruddy for gon to be doing this while personal orders go unfulfilled. Anyways gon has a track record for delays
Offline ideus
  • Björkö.
« Reply #12 on: Sat, 19 March 2016, 10:01:40 »
This r/MK conversation may add some information to this thread, I can also add that the Nerd60 is easier to program than the GH60´s due to the GUI interface that GON developed, its controller can be flashed with TMK as well, but that just void the warranty and there is no much that TMK add to the functionality already built into the GON.
