Author Topic: [IC] GMK Carbon  (Read 525766 times)
Offline 25251325
Re: [IC] GMK Carbon
« Reply #250 on: Sun, 24 April 2016, 02:41:38 »
Is there any chance that let's just past the IC and run the GB as soon as possible? I just can't wait for this damn wonderful set  :p :p :p
Offline Jedi
Re: [IC] GMK Carbon
« Reply #251 on: Sun, 24 April 2016, 08:26:09 »
By the way, here is 75% mockup.
Added row 4 1.5 control and alt keys (required nonwinkeyles for zz98, 1800, 75%)
We <3 you.
Offline ScottieLK
Re: [IC] GMK Carbon
« Reply #252 on: Mon, 25 April 2016, 01:42:59 »
Will this space bar fit Ducky boards?
Varmilo VA87MR
Offline swimmingbird
  • keyset hoarder
Re: [IC] GMK Carbon
« Reply #253 on: Mon, 25 April 2016, 02:15:41 »
Yep Ducky boards use the standard 6.25 length spacebar that is included in all GMK sets
Offline Tmeee
Re: [IC] GMK Carbon
« Reply #254 on: Tue, 26 April 2016, 06:18:23 »
I know it is a custom keyset.but some colors can match the current standard colors,right?Hope you or GMK could point them out if possible.
Waiting for TGR-910......
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
Re: [IC] GMK Carbon
« Reply #255 on: Tue, 26 April 2016, 10:40:10 »
Custom colors do not cause that much increase in pricing. I dont think gmk has already these colors in their palette, so the colors will be custom.
« Last Edit: Tue, 26 April 2016, 12:24:43 by T0mb3ry »
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #256 on: Tue, 26 April 2016, 13:03:46 »
New update.
The Colorway has been changed to classic one.
Added row4 1u keys Win and Ctrl (optional layouts like zz96 or duck octagon)
Added row4 additional 1.25u Alt and 1.5u Alt (non AltGr).
Added row5 additional Alt (non AltGr).
Its almost final...
Offline nickysan92
Re: [IC] GMK Carbon
« Reply #257 on: Tue, 26 April 2016, 13:06:55 »
New update.
Its almost final...
So much hype for this!!!
Offline rioc
Re: [IC] GMK Carbon
« Reply #258 on: Wed, 27 April 2016, 01:55:37 »
New update.
Its almost final...
oh boy... seeing the new update, I think this would look rad on a filco minila. Any chance for a 1U Shift?
EDIT: allthough it'd need 2x (one could make-shift the rest)... IDK, probably too much to ask for, Minila has a too extravagant layout I guess. Just was a thought I had...
« Last Edit: Wed, 27 April 2016, 02:39:35 by rioc »
Offline RinSama269
Re: [IC] GMK Carbon
« Reply #259 on: Wed, 27 April 2016, 02:23:54 »
New update.
Its almost final...
R2 backspace for HHKB?
Offline Tmeee
Re: [IC] GMK Carbon
« Reply #260 on: Wed, 27 April 2016, 08:06:11 »
Indeed I am not worrying about the price.I am thinking about that if some colors in the keyset are just old ones we are familiar with or they could be found in the existing standard colors,I can probably imagine what this keyset will look like.I am not sure if I make it clear.......
Offline ideus
  • Björkö.
Re: [IC] GMK Carbon
« Reply #261 on: Wed, 27 April 2016, 08:20:13 »
It appears that the renders do not match the final layout anymore, for example, the arrows are in orange, while the finals are dark gray.
Offline bbrotha
Re: [IC] GMK Carbon
« Reply #262 on: Wed, 27 April 2016, 09:01:26 »
New update.
Its almost final...
It is there as the Delete key.
Norbaforce 87U 45g  -- HHKB Type S Blanks-- Kira Keyboard -- M65-A -- Novatouch
Offline Tmeee
Re: [IC] GMK Carbon
« Reply #263 on: Wed, 27 April 2016, 09:19:14 »
New update.
Its almost final...
So we cant see orange arrows in this set?Is there any possibility to add a color pack consisting of orange arrows,enter and F-row?
Offline Tmeee
Re: [IC] GMK Carbon
« Reply #264 on: Wed, 27 April 2016, 09:26:11 »
ummmm....Sry,I made a mistake.
Offline zhihuichan
  • Click,click,click
Re: [IC] GMK Carbon
« Reply #265 on: Wed, 27 April 2016, 09:36:37 »
New update.
Its almost final...
No R5 2x 0 and enter on numpad ???
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #266 on: Wed, 27 April 2016, 11:03:31 »
Yeah TKL render is out of date but not 60%. I'll ask Zambumon for new renders for us.
I'll look into it, but i do not promise.
There will be no color pack. As i said no child deals, just a single base kit. In case of Novelties, if they are going to drop, then only as a separate drop.
Don't know but you are not the first person who can't see that delete key.
I really dont understand that you are trying to say. But i am trying to get my hands on gmk color chips, just for the case they got some matching colors already. However it does not change the fact that this keyset will get its original colors.
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #267 on: Wed, 27 April 2016, 17:04:44 »
Updated renders from Zambumon  :)
Offline ideus
  • Björkö.
Re: [IC] GMK Carbon
« Reply #268 on: Wed, 27 April 2016, 17:58:03 »
Offline MMjacksN
Re: [IC] GMK Carbon
« Reply #269 on: Wed, 27 April 2016, 17:59:21 »
I'm not sure whether or not it has been suggested already, but how about an R3 FN key to replace Caps Lock?
Offline s3vv4
Re: [IC] GMK Carbon
« Reply #270 on: Wed, 27 April 2016, 18:14:28 »
This set looks amazing!
Offline shower_king
  • Pain is weakness leaving your body
Re: [IC] GMK Carbon
« Reply #271 on: Wed, 27 April 2016, 19:41:23 »
do we need MOQ at 500 or less due to custom color?
Offline VereChi
Re: [IC] GMK Carbon
« Reply #272 on: Wed, 27 April 2016, 20:57:34 »
New update.
Its almost final...
In my opinion,the old colorway is much better.
Offline Tmeee
Re: [IC] GMK Carbon
« Reply #273 on: Wed, 27 April 2016, 22:25:17 »
New update.
Its almost final...
Great minds think alike.
Offline nickysan92
Re: [IC] GMK Carbon
« Reply #274 on: Wed, 27 April 2016, 22:30:04 »
Sorry if this is a stupid question but will you be retaining the Windows logo as per this render? Because the mock-up showed the Win key as just "Win" legends.
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #275 on: Wed, 27 April 2016, 23:57:18 »
Can't get the idea for that? Can you show an example?
Not sure yet, we should discuss it probably. I am not that neatpicky about that.
It was designed for TKL layout. See my previous mockups for other alyouts like 75% or 1800. The colorway breaks. It was always on my mind to change the colorway to classic one. Less orange is more. But if people want that hard i can add atleast f1-4 and f9-12 in orange and maybe arrows. But we are speaking here of pricing above 140$.
Nope, we'll need 150 units.
Offline kivx
Re: [IC] GMK Carbon
« Reply #276 on: Thu, 28 April 2016, 01:50:34 »
New update.
Its almost final...
I prefer the old one as well.
Please~~~
Offline nickysan92
Re: [IC] GMK Carbon
« Reply #277 on: Thu, 28 April 2016, 05:00:53 »
I'd personally prefer having the Windows logo there, but the mileage of others may vary.
Regarding the colorway, I think the current setup is okay but I can understand where people are coming from with the "yet another orange over black" color combination. Personally, I'd be fine with either because I think both accentuate the set quite well!
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #278 on: Thu, 28 April 2016, 12:36:27 »
Ok i get it.
The thing is, i have to make some decisions, which will hurt either the conservatives (classic colorway) or the liberals (Carbon original colorway). Now i dont want to do that. Because i feel the hype and i want everybody to get his Carbon as he wishes, ofcourse in realistic way. In short i was aiming at price of 140$ for a set and it is quite hard task. You know the limitations.
So my suggestion is, what about if we rise the bar to 150$. With 150 bucks we got room for both colorways. Ofcourse there will be people who will say: yeah but i need it only for my 60% board. In this case i just want to counter: Think in a long term! Its better to have spare keys and knowing your keyset can match every layout. It may come you'll find a better board but with different layout and you will have the keys for it. Its a good thing. Also it will raise the variety of colorways. For example you can have f-row completely gray.
Now my question is, is Carbon (with that variety) worth 150$?
Got new render from user VereChi. The modifiers are black but give this guy some props ;) (doing renders is work)
Update: i'll get probably next month gmk color chips  ;)
« Last Edit: Thu, 28 April 2016, 12:39:07 by T0mb3ry »
Offline nugglets
Re: [IC] GMK Carbon
« Reply #279 on: Thu, 28 April 2016, 12:50:51 »
I'm in for this no matter what, honestly.
While I do prefer some more orange (orange alphas + warning signs was so awesome), I still really like the current Base Kit offering.
That said, if I'm paying $140 for a keyset I absolutely don't mind paying $150 for one with even more options. I'm not going to let $10 stand in the way of everyone getting what they want.
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #280 on: Thu, 28 April 2016, 13:15:46 »
Now i got some news actually. But stay calm first and take it all with "grain of salt".
Got Novelties render from gmk. Colors are wrong, so we dont need to speak about colors right now!
Its going to be double shot not printed! Its not final as Carbon periodic key is missing
You can expect these pricing and moq. Again its not set in stone!
150 ..... 70$
250 ..... 53$
500 ..... 40$
Novelties will be a standalone drop!
Hype!  :p
Offline user 18
Re: [IC] GMK Carbon
« Reply #281 on: Thu, 28 April 2016, 13:35:16 »
150 ..... 70$
250 ..... 53$
500 ..... 40$
Hype!  :p
All the hype! I need this in my life.
Avatar by ashdenej
Offline nugglets
Re: [IC] GMK Carbon
« Reply #282 on: Thu, 28 April 2016, 13:40:06 »
150 ..... 70$
250 ..... 53$
500 ..... 40$
Hype!  :p
I swear I just said something about how awesome warning signs was... but "reverse warning signs" is something I never thought of and now can't live without. Holy crap.
Offline heedpantsnow
  • Old enough to know better
Re: [IC] GMK Carbon
« Reply #283 on: Thu, 28 April 2016, 14:02:54 »
Wow yay for 1.25u FN!
I'm back.
Offline ideus
  • Björkö.
Re: [IC] GMK Carbon
« Reply #284 on: Thu, 28 April 2016, 14:03:33 »
A set of novelties by GMK, wow, this should be a first ever set made by the Germans. As a side note, I think it is fair to include the carbon novelty along with the main set, it is like an authenticity seal, one maybe included in the novelties set as well.
Offline Jedi
Re: [IC] GMK Carbon
« Reply #285 on: Thu, 28 April 2016, 14:05:24 »
Go for $150 dude, I know EXACTLY what you mean.
And you have GOT TO do the MOQ 150@$75 for the novelties.  This needs NO further discussion.
Offline ideus
  • Björkö.
Re: [IC] GMK Carbon
« Reply #286 on: Thu, 28 April 2016, 14:16:23 »
Ok i get it.
GH users interested in GMK sets may be incline for the most expensive option with everything included; but, based on recent failed drops and almost failed ones, you should better ask in places like r/mk, that I think accounts for most of the demand at massdrop, it is generally accepted that r/mk users tend to be younger, if so, they might have less money available than DT and GH users do, also they are less conservative and tend to prefer brilliant colors and other profiles over GMK, stuff like PBT cheap sets, even if they say yes to the expensive set option, the set may not reach MoQ, and for sure, it well get a lot of criticism because of its high price tag.
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #287 on: Thu, 28 April 2016, 14:35:41 »
I got over 2.6k votes for redrop on Carbon in SA profile. I am prety sure we will gather 150 participants if not more. 99% this is going to be reality. I am leaving 1% for saying **** happens.
Carbon SA sold ~700 base kits. Thats a lot. And honestly it is still a hard to get keyset, because almost nobody wants to sell it. That i am trying to tell, Carbon is to attractive (for majority) to fail. Again i dont want to sound ingnorant but its proven for succes.
The only thing i am asking is feedback. It has to be a pleasure for everyone.
« Last Edit: Thu, 28 April 2016, 14:44:17 by T0mb3ry »
Offline ideus
  • Björkö.
Re: [IC] GMK Carbon
« Reply #288 on: Thu, 28 April 2016, 15:04:51 »
Great! forget it then, everything appears to point to a big success.
In my case MD is out of my reach as for some reason they decided to drop to ship to where I am now, I will try to find a proxy, or even a relative that may receive the set and keep it until I travel to ConUS, in any case, congratulations.
Offline Jedi
Re: [IC] GMK Carbon
« Reply #289 on: Thu, 28 April 2016, 16:49:43 »
Ideus, PM me if you need a proxy. Happy to help.
Offline 27
  • The Maple Man
Re: [IC] GMK Carbon
« Reply #290 on: Thu, 28 April 2016, 17:57:38 »
I didn't even realize GMK did custom legends and colours at lower moqs!  Exciting stuff. I'll try to scrape together some money for a set.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline gadzkun
Re: [IC] GMK Carbon
« Reply #291 on: Thu, 28 April 2016, 20:48:42 »
150 ..... 70$
250 ..... 53$
500 ..... 40$
Hype!  :p
im definitely in for novelties!  :p
« Last Edit: Thu, 28 April 2016, 20:50:27 by gadzkun »
Offline rioc
Re: [IC] GMK Carbon
« Reply #292 on: Fri, 29 April 2016, 01:58:30 »
150 ..... 70$
250 ..... 53$
500 ..... 40$
Hype!  :p
Hype indeed!
Look gorgeous :)
Any Chance for an ISO Novelty enter?
Offline FoC_Tow
  • Brokehlicious
Re: [IC] GMK Carbon
« Reply #293 on: Fri, 29 April 2016, 05:31:18 »
Dang dat novelty set...  :eek:
To me Carbon is a lot about having the warning symbol keys, so for me they really make or brake the set.
If the novelty set makes it I'm definitely down for a set!  :thumb:
I think the amount of options is a little limited by two keys I would be really missing tho personally:
An orange on gray Esc and atleast one additional orange 1u R1.
Right now the options for using the orange novelty row would be pretty much limited to this:
To achieve symmetry you would need atleast one of the mentioned keys, which would allow for layouts like this:
With Orange on gray Esc
With one additional 1u R1
Im personally a big fan of the all orange top row.
If adding additional keys is not an option at this point, this could even be achieved by changing print, lock and pause to gray on orange like it was in the original Carbon set.
The best solution imo would be to add the additional orange on gray Esc, aswell as an extra gray on orange 1u R1 like ~`.
I reallt hope this can be taken into consideration as it shouldn't be to big of a change, and I personally would much prefer more color options and proper implementation of the noveltys over R5 support...
Edit: excuse the quick dirty mockups
« Last Edit: Fri, 29 April 2016, 05:34:36 by FoC_Tow »
Offline user 18
Re: [IC] GMK Carbon
« Reply #294 on: Fri, 29 April 2016, 09:29:19 »
Orange novelty row could also be used on function keys on a TKL or fullsize board.
Avatar by ashdenej
Offline kurtle107
Re: [IC] GMK Carbon
« Reply #295 on: Fri, 29 April 2016, 10:44:04 »
i prefer more orange in the base set, that will look better
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
Re: [IC] GMK Carbon
« Reply #296 on: Fri, 29 April 2016, 12:37:04 »
That'll do pig, that'll do.
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon
« Reply #297 on: Fri, 29 April 2016, 12:56:47 »
I understand and all but you guys understand we are limited here. I mean we are very limited.
Offline _joe_king
Re: [IC] GMK Carbon
« Reply #298 on: Fri, 29 April 2016, 13:27:46 »
[/quote]
[/quote]
This seems to be missed here.. Thank you for whatever we end up with! Super pumped about it  :thumb: :thumb: :thumb:
Offline evangs
  • TheVan
Re: [IC] GMK Carbon
« Reply #299 on: Fri, 29 April 2016, 13:28:51 »
I'm in no matter what, thanks for all the work on this!
