Author Topic: Make your own 60% keyboard sleeves (pic heavy)  (Read 11222 times)
Offline hoggy
  • * Ergonomics Moderator
« on: Sun, 21 February 2016, 10:40:49 »
[edit] since photobucket isn't being nice, the pictures are now available here. https://imgur.com/a/UGJ6G[/edit]
Useful tools
Iron the fabric.
It's best to assume that your fabric isn't exactly square.  The easiest way to cut a square/rectangle is to make a template out of card or paper first.  Measurements that work for me: 376mm x 314mm.   Edit - I also use 15mm seams (quite large, but easier to work with).
Paper template pinned to fabric
Cut out the fabric using the template as guide
The cut out fabric
Sew the inner bag first to save a bit of time later.
Don't start at the very edge, you'll want the reverse a few stitches to lock the thread
Reverse stitch to the edge
...and forwards, removing pins as you go.
Slow down for the corner
Stop and leave the needle down (through the fabric)
Lift the sewing machine 'foot'
Rotate 90%
Foot down
Sew along the bottom edge
Same again for the outer bag - I've marked the seam
Now we need to trim the corners - this will reduce bulk in the seams
Snip 1
Snip 2
Snip 3
... and again for the outer bag (looks like I rotated the fabric by not quite 90 degrees)
Snip 1
Snip 2
Snip 3
Iron the seams open
Turn to right way out, you can use a pointy thing to get nice crisp corners
Iron the seams on the inner bag, we don't need to turn this one out.
Slide the inner bag into the outer bag
Line the seams up.
Pin the two bags together, make sure you don't pin the bag closed.
To get the 'free arm', I need to remove part of the table.
Now we have the free arm, perfect for sewing along the top edge.
Slide the bag over the free arm
Start to sew - slowly.  The machine will feed the fabric...
Ideally, the start and finish should meet.
How it looks from the inside
Fold the top edge at the stitching towards the inside of the bag
Iron it as you go to get it to stay in place
Fold it over again, this will completely hide any raw edges
Yet more pins
Sew using the free arm.  (for best results. snip that thread before sewing over it)
Final product.
« Last Edit: Fri, 07 July 2017, 11:31:06 by hoggy »
Offline thatllbeme
Re: Make your own 60% keyboard sleeves
« Reply #1 on: Sun, 21 February 2016, 11:40:45 »
Wow, awesome stuff and great guide! I really ought to make one of these myself one day. Whereabouts do you get your fabric from? I love the design.
Offline hoggy
« Reply #2 on: Sun, 21 February 2016, 12:00:50 »
A local haberdashery should have something interesting in the way of fabric.  I've used 'fat-quarters' which are 50cm x50cm - but the measurements will almost certainly vary a bit.
You could try Spoonflower.com if you want something custom printed - I haven't used them myself.
If you want to make one, but don't have any kit, it might be cheaper to pay for a quick sewing lesson - these sleeves might not take long to make so take enough fabric to make two sleeves just in case.
« Last Edit: Sun, 21 February 2016, 12:06:35 by hoggy »
Offline philphilphil
Re: Make your own 60% keyboard sleeves (pic heavy)
« Reply #3 on: Mon, 22 February 2016, 17:43:43 »
Very well illustrated, thanks for sharing! I sent it to the gf and we will try it next weekend. Gonna post results :)
Offline hoggy
« Reply #4 on: Tue, 23 February 2016, 00:03:32 »
You're welcome - hope it turns out well.  I've updated the text a bit because I forgot to mention the seam allowance - I use a pretty large seam allowance of 15mm (so the row of stitches is 15mm from the edge of the fabric) as it makes aligning the seams of the two bags at lot easier.
Looking forward to seeing the results.
« Reply #5 on: Tue, 23 February 2016, 00:04:26 »
Nice, dawg! Bookmarking this.
Offline carlossless
    • Personal Page
« Reply #6 on: Tue, 23 February 2016, 10:53:28 »
Oh wow, thanks a lot for posting this!
« Reply #7 on: Fri, 26 February 2016, 11:13:55 »
I did it! It looks a bit messy and the stitches aren't perfect but for the first try it looks alright i think :). Thanks again for posting, now i gonna make one for my TKL!
Edit: i just saw that i folded the edge only once what would explain why it looks so ugly. gonna get some nice fabric and try again :)
« Last Edit: Fri, 26 February 2016, 16:46:09 by philphilphil »
Offline hoggy
« Reply #8 on: Fri, 26 February 2016, 18:00:23 »
Looking good!  It's always satisfying to make something like this yourself.  You could always fold the top edge in again, but I think it adds character as it is.
I think you're being a bit hard on yourself, your corners look pretty neat and the stitching on the top edge starts has the same start/end seam allowance.  Even better, your keyboard fits inside.
Are there any changes to the tutorial that you think would help?  Were any parts tricky to suss out?
« Reply #9 on: Fri, 26 February 2016, 18:02:14 »
This guide is great. Thanks for doing it hoggy. My guide looks similar but my first step is "Beg sister to do it for me since she's a fashion major then watch her sew" :))
« Reply #10 on: Mon, 29 February 2016, 03:53:13 »
No, i think you did pretty well describing everything in detail :)
I ordered some cloth yesterday to make the TKL one. I also plan on adding a cord inside the folding to close the bag. Do you have any tipps how i could do this? I thought about adding the holes and inserting the eyelets before folding the edges and than fold and stitch it and when its done add the cord.
Offline FoC_Tow
  • Brokehlicious
« Reply #11 on: Mon, 29 February 2016, 13:53:33 »
Nice in depth tutorial, and lots of great pics to go a long with it!
Really wish I still had a working sewing machine here to do some my own.
Kinda tempted to get a new one for this purpose now  ;D
Offline hoggy
« Reply #12 on: Mon, 29 February 2016, 14:47:06 »
Phil Phil Phil, that's pretty much my thought.  You could make the template a bit longer to accommodate a larger fold and to allow the bag to close around the board.  If your machine can sew a buttonhole then that might be a better way to go.  You're right, you would have to do this before sewing the other seams.  Looking forward to seeing the results.
FoC_Tow, go for it.  Alternatively, ask a friend who has one to help you with it, it's more fun.
Offline funderburker
« Reply #13 on: Mon, 29 February 2016, 15:25:16 »
Well, now I know what I'll ask my girlfriend to do next weekend! Maybe someone knows what measurements do I need to make a 40% sleeve?
Keyboard design by Skepur
Offline user 18
« Reply #14 on: Mon, 29 February 2016, 17:13:41 »
You can probably get appropriate measurements by measuring your keyboard, and adding a bit of a margin.
Avatar by ashdenej
Offline hoggy
« Reply #15 on: Mon, 29 February 2016, 21:04:46 »
To get a rough idea just fold the fabric in half around the keyboard. You'll want it to be able to slide in and out without a struggle so add a margin for 'ease'.  Pin the fabric in place and remove the board.
If you uneasy with the size, use a long stitch on the machine so it's easier to unpick.
I'm interested to see how it turns out,  and please let us know the measurements!
« Reply #16 on: Tue, 01 March 2016, 02:37:55 »
Ok, thanks. My girlfriend isn't a seamstress so any tips&tricks are appreciated. When it'll be made I'll post some pictures (and measurements) here!
« Reply #17 on: Sun, 13 March 2016, 07:06:20 »
So i made a few over the last two weeks, one got really nice one and one really ugly (was the first with a cord, so its ok). Instead of the buttonholes i did cut the fabric at the end of the one flat site so the cords can go out there. It works but i think i have so sew the edges of it to prevent the fabric from fraying. One big problem i had was when folding the fabric twice for the front edge, the pile of fabric gets so big at the edge that my sewiwgmachine can't really sew it and missplaces the seam. I didn't see it until i was done and sewed it again which lead to some ugly seams. Not sure what i can do there, maybe iron it more.
Offline hoggy
« Reply #18 on: Sun, 13 March 2016, 13:25:21 »
Still looking good!  The top one looks really good.
The problem you're having sewing over that bump is because the sewing 'foot' can't climb over the bump.  You can cheat with a humper-jumper, or even a scrap of fabric folded over a few times.
When you are almost at the bump, leave the needle down (in the fabric) and lift the foot.  Take your folded fabric and place it behind the needle and lower the foot.  The foot should now be parallel to the ground.  Sew a few stitches and then leave the needle in the fabric, raise the foot and move the folded scrap in front of the needle (not too close, you don't want to sew it!), then lower the foot.  This way, your machine can feed the fabric through, and the foot is kept level.  Once the needle is past the bump, remove the scrap of fabric.  I hope this makes some sense...
« Reply #19 on: Sun, 13 March 2016, 16:37:27 »
Yes that makes sense I'll try that :) Thanks for all the help and effort!
