Author Topic: Go for GMK or JTK  (Read 38568 times)
Offline Baddy126
Go for GMK or JTK
« on: Mon, 22 February 2016, 20:26:00 »
I'm considering buying some thick abs since everyone says it's amazing... my only question is should I just start off with the big boy stuff (GMK) or go for something easier on the wallet for JTK?
They all make very nice sets and I wouldn't mind getting anything by either of them.... just wanted to see some opinions that's all.
Re: Go for GMK or JTK
« Reply #1 on: Mon, 22 February 2016, 20:27:15 »
GMK quality is still better than JTK right now, but JTK is nicer to use than SP and easier on the wallet than GMK.
Offline raymogi
« Reply #2 on: Mon, 22 February 2016, 20:27:27 »
Both are really good. Go for the set (color scheme) that you like more.
Please feed my addiction.
Offline Jokrik
« Reply #3 on: Mon, 22 February 2016, 20:30:34 »
I would personally go for the end game (GMK) if you've the budget
JTK is good, but there are still works to do like their font tidiness, stems (as I find they're too tight)
Although some GMK production also has backlight issue
nevertheless color is more important :)
« Reply #4 on: Mon, 22 February 2016, 20:32:43 »
if you want inconsistent letter size, jtk
if you want scratches, gmk
if you want perfection, get yourself an hhkb.
Offline beehatch
  • baehatch
« Reply #5 on: Mon, 22 February 2016, 20:34:18 »
+1
Offline asdfjkl36
  • blue shirt guy
« Reply #6 on: Mon, 22 February 2016, 20:34:24 »
Is that the new slogan?
« Reply #7 on: Mon, 22 February 2016, 20:35:20 »
si
Offline slickmamba
« Reply #8 on: Mon, 22 February 2016, 20:56:04 »
Like others said. GMK is great.  Their quality dropped a bit last year, and we don't really know if its bounced back yet.
JTK has some problems, but they are continually improving.
Hi :)
Offline Michael
  • Formerly Bro Caps
« Reply #9 on: Mon, 22 February 2016, 20:57:47 »
For being a brand new company, I would say they did a pretty good job. I don't know why you give them so much ****.
Those issues are being fixed for the next run.
Let's look back at all the massive ****ups from SP (a company that has been around a long time, still making ****ups) ;)
Offline bocahgundul
  • a seal
« Reply #10 on: Mon, 22 February 2016, 20:59:57 »
Gmk all the way
« Reply #11 on: Mon, 22 February 2016, 21:01:32 »
Nah, their quality didn't slip last year.  What happened?  A bunch of people blew non-issues like light bleed out of proportion and a single GB didn't have complete color mixing on a custom color.  There were no more scratches or other problems than normal, just two things blew up into a total cluster****.  Even with the issues from the TA buy, they still have better quality caps than anything else out there.
I'm hoping that they are a bit better with the next round.  I don't think we've seen R2 yet, but there were some issues with R1 (purple and white) that make me not sure I can use them since once they've been noticed, there's no unseeing them.  They are still nicer than SP DCS though.
« Last Edit: Mon, 22 February 2016, 21:03:37 by nubbinator »
Offline ideus
  • Björkö.
« Reply #12 on: Mon, 22 February 2016, 21:03:39 »
GMK made with standard colors that implies standard raw materials; it appears their tooling (molds, and injection molding machines) are all setup to process the standard resins and additives, while revising the setups for new ones cause them some quality issues.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #13 on: Mon, 22 February 2016, 21:03:50 »
$120 + a set and you have to put your faith in your GB to take care of mistakes,
JTK significantly cheaper and BL is just a PM away if there are issues...
SP has SA sets, the only reason they get play on my credit card
Offline slickmamba
« Reply #14 on: Mon, 22 February 2016, 21:04:17 »
I agree, but the lightbleed was something that I haven't seen before in GMK sets, but it very well may have existed before.
I'm very excited for what Ctrl Alt and JTK have in store for us.
Hi :)
« Reply #15 on: Mon, 22 February 2016, 21:06:55 »
Light bleed did exist before and will happen with any lighter colored plastic.  Most the previous buys were just darker colors that are less susceptible to it.
Offline swimmingbird
  • keyset hoarder
« Reply #16 on: Mon, 22 February 2016, 21:10:24 »
I personally am really excited to see how round 2 of JTK turns out - I know everyone complains about the legends but R1 was a pretty ****ing good first shot
« Reply #17 on: Mon, 22 February 2016, 21:38:39 »
lets, SP did **** up a lot. they aren't immune to criticism either. i dont think users should be beta testers for whatever price jtk goes for. c'mon, that white on black set look like it was made for blind people.
« Reply #18 on: Mon, 22 February 2016, 21:45:32 »
At this current moment in time I couldn't recommend JTK. The legends, to someone as anal as me, are glaringly ugly. That said, if improvements are made then JTK will perhaps become a viable option. Only time will tell.
GMK is great, but..
Original Cherry is still the best. I don't believe it will ever be bested.
« Last Edit: Mon, 22 February 2016, 21:48:19 by Photekq »
Offline njbair
    • nickbair.net
« Reply #19 on: Mon, 22 February 2016, 21:49:19 »
I was with you until you decided to drag yet another company through the mud. I'm not sure how bad-mouthing SP makes JTK or GMK look better.
My boards:
Offline Michael
  • Formerly Bro Caps
« Reply #20 on: Mon, 22 February 2016, 21:51:02 »
Oh I am not denying that there were issues, I am just saying that this is brand new tooling, and process for them. Also, it wasn't a secret regarding those legends, as the images of the set were produced
prior to the sale running. They weren't hiding it in any way. So if anyone bought the set, they bought it knowing this.
Offline Michael
  • Formerly Bro Caps
« Reply #21 on: Mon, 22 February 2016, 21:52:04 »
I wasnt trying to drag their name through the mud, I was simply using them as an example that some leniency should be considered in this situation.
« Reply #22 on: Mon, 22 February 2016, 21:52:57 »
the images of the set were produced prior to the sale running. They weren't hiding it in any way. So if anyone bought the set, they bought it knowing this.
Before the first GB? Maybe I missed it but I don't remember seeing any images before I purchased a set.
Offline njbair
    • nickbair.net
« Reply #23 on: Mon, 22 February 2016, 21:53:43 »
Fair enough. I may have interpreted that more harshly than you intended. One thing you've got to give SP credit for, they always make good on their mistakes.
My boards:
Offline Michael
  • Formerly Bro Caps
« Reply #24 on: Mon, 22 February 2016, 21:54:05 »
GMK is great, but..
So the tooling that GMK uses, is that original Cherry corp tooling, or is it their own? I was still never clear on this. Did Cherry produce everything in-house, or were they going out to other companies like GMK?
Offline Baddy126
« Reply #25 on: Mon, 22 February 2016, 21:56:38 »
Seems like the only set of JTK I can get are the WoB on originitiveco and the other sets were from a group buy that I wasn't even aware of. I do like the hyperfuse but that also seems out of the question and the only available set I see that I would like is the sky dolch but at $165... that's almost triple the price of the JTK sets on ctrlalt.io
Offline Michael
  • Formerly Bro Caps
« Reply #26 on: Mon, 22 February 2016, 21:56:41 »
No doubt, they definitely do. I just wanted to point out that even established companies have issues like this.
Offline vivalarevolución
« Reply #27 on: Mon, 22 February 2016, 21:59:04 »
Just get blanks in Cherry profile.  They are cheap and you don't have to worry about nonsense like screwed up legends.
« Reply #28 on: Mon, 22 February 2016, 22:00:37 »
GMK has the original Cherry doubleshot tooling, but they do not manage to produce keycaps of the same quality as Cherry. Small errors in some legends, the texture isn't as nice, etc. I'm not sure why this is. Perhaps it's just lack of QC, perhaps they have had to make repairs/changes to the moulds or perhaps it's both.
Really though, I was mostly referring to Cherry dyesubs. They're so far ahead of even Cherry doubleshots. They are perfect.
« Last Edit: Mon, 22 February 2016, 22:02:08 by Photekq »
Offline Baddy126
« Reply #29 on: Mon, 22 February 2016, 22:00:38 »
Where do I get thick blank abs?
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #30 on: Mon, 22 February 2016, 22:08:32 »
I posted images of the set prior to launching the buy
They are available to find in the forum
I also made it very clear on the original sale page that this was he first production and there would be issues specifically regarding legends
Since there were issues, we have offered free full legacy support with jtk, when we fix and finalise a legend it'll be reproduced for all the original buys
We extensively tested jtk before anyone ever knew anything about it, people close to me we're seeing samples 2 years before I said anything publicly
But there were subtle changes in materials chosen at the end and other issues that come in to play when going in to mass production
Initially we also had lots of legends on one mould, and changing one legend had a knock on effect across others
It took a ton of trial and error and these moulds and legends are made by hand
Not only will the issues be fixed for future sets, they will for past sets as well
Everyone who purchased the debut set knew exactly what they were buying, unless of course they didn't bother to read the information at the very top of the sale page
The sets made on the debut one are wob,bow and purple
There will be huge improvements on sophomore sets, I'm sure it still won't be perfect, but it'll get closer every time
People are welcome to wait until the set is up to there standards, or support the project to help speed up these changes
But at no point have I stated the set is finished and finalised, nor have I claimed it to be a replica of gmk, which is the standard it is being held to
« Last Edit: Mon, 22 February 2016, 22:10:55 by BunnyLake »
Offline bocahgundul
  • a seal
« Reply #31 on: Mon, 22 February 2016, 22:14:28 »
Man that makes me want the dyesubs more!. Reply to my pm man
« Reply #32 on: Mon, 22 February 2016, 22:18:55 »
People are welcome to wait intil the set is up to there standards, or support the project to help speed up these changes
I guess I must have just missed the pictures, or perhaps my memory is just hazy. Of course. I purchased the set knowing that it was going to be the first, imperfect run and I'm sure everyone knows that too. Whenever I see JTK criticized it is almost always followed by a statement of the fact that it will be seeing improvements, so I certainly don't think it's a little-known fact.
I just cannot recommend buying JTK for using on a keyboard at this moment in time due to the legends. That said, buying JTK for the sake of supporting improvements is something else entirely. I look forward to seeing how the sets improve.
Offline nmur
  • ಠ_ಠ
« Reply #33 on: Mon, 22 February 2016, 22:21:38 »
it's a shame that most JTK discussion/question/media threads seem to turn into ****ting on JTK
not sure how or why people expect them their sets to be on par with GMK, considering how new JTK are to this and the pricing difference between both manufacturers
if you want the premium stuff, go GMK (classifieds for past sets)
if you want a cheaper, yet still pretty decent set, go JTK
Offline Baddy126
« Reply #34 on: Mon, 22 February 2016, 22:22:29 »
To be honest I think the PoW looks nice overall. These were all from group buys so even if I wanted to purchase it I can't   :-\
« Reply #35 on: Mon, 22 February 2016, 22:22:56 »
is he? he's not exactly the most level headed when somebody criticizes how he runs things.
but before i get called out for "hating" on bunny, save it. i don't care what his stans say.
anyway, the purple on white is nice.
« Reply #36 on: Mon, 22 February 2016, 22:24:18 »
I don't see this occurring. I see criticism of JTK, which is absolutely fine and is something that must be done. Without criticism, whether it be from one person or from many, how can you hope for there to be improvements? This rings true for any person and any thing - not just JTK.
Offline beehatch
  • baehatch
« Reply #37 on: Mon, 22 February 2016, 22:30:34 »
I'd like to point out this wasn't supposed to be cluster**** or anything. OP wanted/still wants suggestions and help about keysets. How about focus on that?
To put it simply, I don't think demik was attempting to "talk ****" but merely do a quick con list with quirky remark. It was just simple criticism that I think certainly got blown out of proportion, as he was not exactly attacking JTK/GMK just stating facts.
so OP, buy anything you want but:
JTK sets (BoW, WoB, PoW) will have some legends that may distract you from the varying size in lettering. Future JTK sets will not have these issues. However, they are colorful, cheap, and thick so, potentially worth the wait if you care.
GMK sets (Cyan, TA, Hyperfuse at the top of my head) can have scratches and/or the ability to bleed with backlighting. For example, Hyperfuse doesn't for me, but my Cyan set does. These sets are expensive, sometimes hard to find for a decent price on Classifieds or r/MechMarket but it's possible.
Offline Baddy126
« Reply #38 on: Mon, 22 February 2016, 22:36:47 »
Thanks for the pros and cons Beehatch. Aside from what you've listed, could you shed some light as to how they feel? If you were to close your eyes and typed on them could you even tell the difference or are they all pretty much exactly the same?
Offline appleonama
  • Trollo en USA
« Reply #39 on: Mon, 22 February 2016, 22:54:54 »
Depending on the color scheme you want either is fine. If you aren't anal about the legends and looking at your set with a microscope then go for Jtk. The price is pretty good for a pretty good quality plastic.
I never look directly at my keyboard so inconsistencies wouldn't bother me and there is some inconsistencies with gmk but it is hardly noticeable .
« Reply #40 on: Tue, 23 February 2016, 03:39:46 »
I'd have to do a blind test, but AFAICR JTK is a little smoother than GMK.
But then these are ABS, and they will all shine up if you use them long enough.
Offline Diokhan
« Reply #41 on: Tue, 23 February 2016, 04:19:28 »
That is the only thing that would stop me from buying I think..
The shine.
« Reply #42 on: Tue, 23 February 2016, 09:44:51 »
Maybe it depends on the set, but I know some of my JTK caps have small gaps between the legends and the cap and some have soft looking legends in addition to legend size variance.  It's not all microscopic stuff.  The quality is suppossed to be improving and, like I said, I'd still take it over SP DCS, but, for the white on purple set at least, it's not so minute that you won't notice it without a microscope.
If you're willing to spend the extra, I think GMK is worth the premium right now.  If you don't, JTK is great.  As things get figured it and quality improves, JTK may end up being recommended over GMK.
Offline asgeirtj
« Reply #43 on: Tue, 23 February 2016, 12:27:30 »
GMK is great, but..
What's the difference between OG cherry DS and GMK? Is there much difference in feel of the texture of the caps?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #44 on: Tue, 23 February 2016, 12:34:59 »
Offline Diokhan
« Reply #45 on: Tue, 23 February 2016, 12:35:51 »
how bad is the shine on the abs?
« Reply #46 on: Tue, 23 February 2016, 12:46:21 »
It all depends on use, environment, personal chemistry etc.
Offline keshley
    • Blog n stuff
« Reply #47 on: Tue, 23 February 2016, 12:59:03 »
I have the opposite opinion. Currently have JTK alphas and GMK mods on the board I'm typing on now, and I find the GMK to be slightly smoother. Or at least consistently so. The scoops feel smoothest of all the caps on the board.
Not that the JTK caps feel bad or anything. I don't notice the difference when I'm hacking away. I'd say the real only issue, as noted previously, is the legends. And as already mentioned, that's being addressed with each new run.
Barring price and availability, I'd choose GMK as it stands right now, if I could only have one. But I'm not unhappy with my JTK set and will likely buy more sets as improvements and colorways are introduced. If pricing is an issue, then I have no problems recommending JTK, assuming the legends don't bother you.
HHKB Pro 2       Pok3r
Offline Baddy126
« Reply #48 on: Tue, 23 February 2016, 14:07:37 »
Thanks for your reply! I've already made up my mind that the JTK legends aren't that bad... but the availability  of these sets seem so scarce compared to GMK so if I were to purchase any sets brand new... it'd probably be eaiser to get GMK over JTK unless someone else can point me in the direct of getting some JTK preferably (PoW)
« Reply #49 on: Tue, 23 February 2016, 18:56:05 »
There have been some JTK sets sold in classifieds and bunnylake may have some extras still.
I've also seen some at a few other vendors.
