Author Topic: Wireless and Bluetooth features. What is it that you want to see?  (Read 3147 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
As part of my TS65 project, I'm looking to add wireless functionality to the board.
This thread is more general, to find out what features users would like to see in a Bluetooth wireless keyboard. Since my project is open-source, once I have the firmware support and electronic design completed, the wireless features should be easily made into an adapter board that can be used with existing keyboards.
I need to get answers to some simple questions and you are more than welcome to add more.
First, some background:
1. USB can supply 5V at 500mA once enumerated as a keyboard device, truly it can supply 2.5W.
2. Most barebone keyboards use around 40-50mA at 5V, which is 200mW - 250mW.
3. Bluetooth Low Energy (BLE - BT 4.0) uses around 25mA at 3.3V, which is 100mW (Taking into consideration of 5V to 3.3V stepdown efficiency)
4. Rest of the 2.15W (~430mA @ 5V) is available for the other bells and whistles as well as charging a battery if required.
5. Rechargeable AA batteries are about 1900mAh @ 1.2V (Typical) - Using two in series which is quite common for such applications, we can draw about 4.5W. Using a barebones keyboard with BLE and no backlighting/RGB we can get about 12 hours considering the efficiency of step-up conversion.
6. Li-ion/Li-Po batteries suitable for a portable keyboard would be about 2100mAh @ 3.7V - 7.77W, which should give around 21 hours of battery time on the the barebones BLE keyboard.
NOTE: I'm a bit lost as to how existing wireless boards last so long on battery. I would really appreciate an answer on this.
Questions:
1. What kind of battery would you like to see in a keyboard?
  -- AA
  -- Li-Ion/Li-Po
  -- Doesn't matter
  -- Other, please specify
2. Would you like to have the board the ability to charge over USB?
  -- Yes
  -- No
  -- Doesn't matter
3. What would be the max acceptable charge time?
  -- 1 hour
  -- 2 hour
  -- 4 hours
  -- Over night charge (Around 8 )
4. Due to limitations of USB a max of only 400mA can be used for charging a battery, this would mean a charge time of around 4 hours. Would you like the ability to charge via a dedicated charger (Such as one supplied with your phone)?
  -- Yes
  -- No
  -- Doesn't matter
5. If your answer to 4 is yes, what would be your preferred method for charging using a dedicated charger?
  -- Same connector used to connect to computer
  -- Dedicated secondary USB port (micro or mini)
  -- Barrel-style wall wort connector
  -- Qi, wireless charging
  -- Doesn't matter
6. What is the minimum acceptable battery time?
  -- 12 hours
  -- 24 hours
  -- 1 week
  -- 2 weeks
  -- 1 month
TIA
« Last Edit: Mon, 14 March 2016, 05:46:35 by MOZ »
Offline cy384
    • cy384
Re: Wireless and Bluetooth features. What is it that you want to see?
« Reply #1 on: Sun, 13 March 2016, 12:48:08 »
For the sake of comparison, I'll mention my custom bluetooth keyboard; I recently added bluetooth to my Atreus by chopping up a Handheld Scientific adapter.  My main complaints would probably be cost, inconvenience of desoldering parts, size, and having to design my own brackets etc. for the pcb and battery.  It charges a Li-Ion battery via USB but does not pass the connection through (so, bluetooth only).  In terms of the end result, I'm quite happy with it, it charges in a few hours, and lasts 10-ish hours of active use.  As it can charge while being used, it's not exceptionally inconvenient to run out of power.
Regarding what I'd like to see from an adapter/board to embed in future projects:
Li-Ion/LiPo
>Charge over USB?
Absolutely yes.
>Max acceptable charge time?
Overnight
>Dedicated charger
No way, don't want more cables and adapters to keep track of.
>Wireless charging?
Qi/wireless charging would be kinda cool, I'd consider it.
Overall, I'd be interested in either a bluetooth/charging module to add to a keyboard with some other controller, or a single module integrating an atmega32u4 with the bluetooth and charging stuff.
Offline pomk
« Reply #2 on: Sun, 13 March 2016, 14:45:58 »
The trick to having good battery life is just using power optimized components. For example the nRF51822 (bt4.0) chip can run on 200 ľA average current at around 6 key presses per second. The 200 ľA figure is from Raytac. With 2 x AAA batteries it amounts to some silly number like 260 days of continuous typing, not taking battery degradation into account.
« Last Edit: Sun, 13 March 2016, 14:52:55 by pomk »
Offline Zorox
  • Tactile FTW <3
« Reply #3 on: Wed, 16 March 2016, 10:52:24 »
1. Li-Ion/LiPo
2. Yes
3. 4h would be nice
4. No, no more cabels for a wireless build pls :D
5. Wireless charging, with charge pad as removable case :D
6. 24h, incase I have to go to a party afterwork and get hangover :D
Offline ndlu2
« Reply #4 on: Mon, 21 March 2016, 21:07:50 »
I've thought about modding my keyboard to be wireless and I was considering the Adafruit Bluetooth LE board which sells for about $30. It includes bluetooth, can be powered with usb or a lipo battery, and includes a charging circuit.
  -- Doesn't matter
  -- Yes [Qi charging is fine too]
  -- Over night charge (Around 8 ) [prefer 8 hour battery life if its this long]
  -- Doesn't matter
  -- 12 hours
