Author Topic: Canned air sprayed between keys  (Read 3414 times)
Offline AndrewZorn
« on: Wed, 09 December 2009, 15:03:09 »
It might be a stupid question, but I keep forgetting to ask, so here it is...
I feel like the most common method of quick-cleaning a keyboard is to spray compressed air between the keys.  A lot of junk comes out!  But I can't imagine why this is actually done...
If you think about the way the keycaps are shaped, and the way the switches are elevated off the plate or casing, aren't the internals normally out of harm's way of dust/dirt/food/etc?  When you start blowing it all around, turning the keyboard sideways or upside down when you do (to aid in the stuff falling out) are you not actually giving the junk a chance to get into these usually-unreachable places?
Maybe every time I think about this, it's because I'm imagining a Cherry switch, high and mighty above all the crap down below.  Then air blowing all the stuff around, and it landing on/near the stem.  In the case of a tilted or upside-down board, all the stuff landing on the inside of the keycap... then once righted, down into the switch itself.
Even rubber domes have design that makes it look like it is impossible for dust to get in under normal conditions.
I'm asking because I don't want dust to get into places I cannot get it out of, but can I really avoid ever doing this, taking off all the keycaps every time?
Offline itlnstln
« Reply #1 on: Wed, 09 December 2009, 15:07:50 »
That's a good point; I have never really thought about that, but I guess you're right.  I clean my keyboards quite often (with a feather duster), so I lower the chances of stuff getting below the keys.  That said, I don't use a feather duster, so anything that does get below the keycaps stays. People have mentioned that they have had dust get into blue Cherrys preventing them from clicking.
Offline _js_
« Reply #2 on: Wed, 09 December 2009, 15:24:42 »
I tend to agree, but I am far from any kind of expert on the subject.  But, FWIW, I would personally NOT spray my boards with compressed air.  First of all, sometimes you get liquid out of those cans, and that leaves a residue which I doubt is conductive.  Second, as you point out, you're just blowing dust and crap into places where it shouldn't be.  If it falls in from outside, it is naturally inbetween keyswitches, right?  When you blow it, you are going to blow it into them.
I would think that properly cleaning a keyboard involves pulling all the key caps and doing something more thorough and a lot more delicate and directed than a blast of compressed gasses.
HHKB Pro 2, AEK II
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Wed, 09 December 2009, 16:22:09 »
If you really want a clean keyboard, it's good to remove all the keys and vacuum out the inside. A metal patch for a PCI slot makes a great key puller that does not damage key caps.
Offline AndrewZorn
« Reply #4 on: Wed, 09 December 2009, 16:41:07 »
Quote from: ripster;140675
You guys worry too much.  Take the keyboard, hold it over the garbage can, and shake upside down.  Repeat until the garbage can is filled up.
junk falls into keycaps
(keyboard back on desk)
junk falls onto stem
(you type something)
junk falls into switch
Offline AndrewZorn
« Reply #5 on: Wed, 09 December 2009, 16:59:30 »
would still happen
Offline nanu
    • http://T-T.be/portal
« Reply #6 on: Wed, 09 December 2009, 17:23:39 »
My latest philosophy on cleaning keyboards is to not care too much.
Between removed-keycap cleanings I use an acid brush for debris between rows.
It is not very effective but removes some dry particles that don't fall out via shakin'.
The thin metal edges also have a high chance of scratching your keys if you're clumsy.
« Reply #7 on: Wed, 09 December 2009, 17:27:42 »
Quote from: ripster;140702
[/IMG]
The cruddy rubber dome is getting a nice new home! :-)
  • Live long and prosper
« Reply #8 on: Wed, 09 December 2009, 17:30:55 »
How about using a shop air compressor to get all the dust out?  That air moves so fast it doesn't have any time go anywhere else but out.
tp thread is tp thread
« Reply #9 on: Wed, 09 December 2009, 17:32:15 »
Those do the job well.
Offline bitflipper
« Reply #10 on: Wed, 09 December 2009, 18:32:39 »
Please take it outside to blow it out with canned air! And don't get any on you.
« Reply #11 on: Wed, 09 December 2009, 18:37:36 »
That needs more than a can of compressed air.
Offline MFGorilla
« Reply #12 on: Wed, 09 December 2009, 18:39:30 »
maybe two cans.
"I want an Official Red Ryder Carbine-Action Two-Hundred-Shot Range Model Air Rifle!"
Using Now: Unicomp Spacesaver (black/grey) | IBM Model M 1391401 White Label| IBM Model M 1394946 by Lexmark
[COMMENT]On The Way: IBM Model M Industrial[/COMMENT]
Wish list: Filco Majestouch tenless with Blue Cherries | Matias Tactile Pro 3 | IBM Model M Space Saver
In Storage: IBM M2, DELL bluetooth wireless
Offline bitflipper
« Reply #13 on: Wed, 09 December 2009, 18:50:02 »
Quote from: Computer-Lab in Basement;140755
Yeah, the power supply fan failed for some reason.
« Reply #14 on: Wed, 09 December 2009, 19:03:34 »
This is more of what I was thinking of:
10HP Air compressor.
Offline ironcoder
« Reply #15 on: Thu, 10 December 2009, 05:10:45 »
Shop vac with a good brush. Make sure all the key caps are stowed and their tray tables are in an upright position.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline GenEric35
« Last Edit: Thu, 10 December 2009, 10:23:45 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline GenEric35
« Reply #17 on: Thu, 10 December 2009, 10:09:45 »
Quote from: Computer-Lab in Basement;140763
yea, and electrical compressor are good too, got mine as a gift last year, someone in my familly upgraded his and gave me the small one, it has 10 years of hobby usage and still works like new
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #18 on: Thu, 10 December 2009, 19:47:05 »
Quote from: GenEric35;140920
http://www.canadiantire.ca/AST/browse/6/Tools/1/CompressorsAirTools/Compressors/PRDOVR~0991125P/Campbell%2BHausfeld%2BCompressor%2BKit%2B%2526%2BNailer.jsp
Ooo Canadian Tire (Canadian Name: Crappy Tire).
I miss not having one of those around, I needed a pair of cheap winter gloves yesterday, I have no idea where to even look in Japan.
Its just like not having Timmy's or Robins (Tim Hortons and Robin's Donuts). The doughnuts at Robin's have been better ever since Timmy's started using factories to produce their.
Damn that definitely just proved the Canadian section in the Wikipedia article about Doughnuts
Per capita, Canadians consume the most donuts in the world, and Canada also has the most donut stores per capita.
There are at least 4 Tim Hortons on my university campus back in Waterloo.
Good thing I found a good bakery on my way to work.
BTW Melon Pan from grocery and convenience stores are crap, amazing from good bakeries.
[Note to self: do not eat bread/pasteries near keyboard]
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline mmgoose
« Reply #19 on: Thu, 10 December 2009, 20:51:21 »
if it's a keyboard you really couldn't care less about other than discouraging all sorts of critters dining in the all you can eat filth buffet then canned air is a good idea. but in my experience although most of the dust just kinda swirls around, the sticky crud attracts some and gets jammed in the nooks and crannies tighter than before.
if it's really a bother, remove the top half first.
Customizer Ultimate
