Author Topic: Leopold 750fc Mac setup  (Read 5358 times)
Offline hotrattz
« on: Sat, 19 March 2016, 23:25:15 »
Just got this keyboard love the feel and the weight of it but having a heck of a time getting it set up to use with my Mac can someone give me pointers on using karabiner or any similar remapping Mac friendly software may need to return it for some thing with dip switch configurations
Offline TopreFan333
Re: Leopold 750fc Mac setup
« Reply #1 on: Sun, 20 March 2016, 21:45:49 »
I don't know that keyboard specifically, but Karabiner gives you control over a LOT on OS X and I would be pretty surprised if it can't handle the remaps you want.
By the way, you might know this already, but: if you're just having trouble getting the Command and Option keys in the right places, go to the Keyboard control panel and click the Modifier Keys button -- it brings up a dialog that will let you swap the Windows for the Option key and the Alt for the Command key so it works like a normal OS X keyboard.
