Author Topic: Can an IBM terminal Model M keyboard be used today?  (Read 6754 times)
Offline aptivaboy
« on: Wed, 23 March 2016, 00:45:24 »
You know the one I'm talking about.  ;D ;D ;D More function keys than you can shake a stick at! The original equivalent of Unicomp's PC-122. I'm aware that they cannot be used as is due to their keys being mapped differently and modern PCs not being able to read them. But, is there a reasonable way to remap their keys and make one usable with a modern Windows system?
Many thank,
Robert
Offline Red October
Re: Can an IBM terminal Model M keyboard be used today?
« Reply #1 on: Wed, 23 March 2016, 01:56:33 »
More than a reasonable way, a turnkey solution.
http://www.ebay.com/itm/NEW-Soarers-Converter-Adapter-for-IBM-Model-F-122-Keyboard-Remapping-Macros-NKR-/271644933588
His other auctions have the ones for the boards with Modular plugs and PS/2 connectors.
« Reply #2 on: Wed, 23 March 2016, 08:27:47 »
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
Offline aptivaboy
« Reply #3 on: Wed, 23 March 2016, 12:19:03 »
Cool... There are a number of them on the Bay of Evil right now that look nice, including one pure white case - not the more standard off-white case. I may make one into a project.
One other thing - I'd be using it with an HP laptop. When I'm at home, I plug it into a standard keyboard for ease of typing. Were I to remap the keys, would that remap them integrally to the keyboard? I guess what I'm asking is, would the remapping apply no matter which PC it was plugged into, or only with the laptop?
Thanks,
Robert
« Reply #4 on: Wed, 23 March 2016, 18:37:06 »
I am not exactly sure about your question, but a Soarer's Converter intercepts the keyboard and sends codes on in a USB form that the computer can understand. As I recall, wcass gave an easy instruction in reply #560.
Remapping keys is reprogramming the key codes to be interpreted as whatever else you select, so that the computer sees the Teensy, not the keyboard. So yes, the keyboard/Teensy combo will appear the same no matter what computer that you plug it into.
Orihalcon's cables probably behave pretty much the same way, but I don't know for sure.
Offline aptivaboy
« Reply #5 on: Thu, 24 March 2016, 00:29:28 »
I ran across this on the Bay of Evil: http://www.ebay.com/itm/NEW-RJ45-to-USB-Soarers-Converter-Model-M-Terminal-Keyboard-Remapping-Macros-/281476431381?hash=item41894d7e15:g:wwYAAOSwF1dUSZVm
I'm guessing this is what I need then, correct? I'm foreseeing some interesting macros for the extra function keys, he he he...
« Reply #6 on: Thu, 24 March 2016, 07:37:52 »
Yes, Orihalcon's cables are very clean and work well.
Offline aptivaboy
« Reply #7 on: Thu, 24 March 2016, 12:20:31 »
They'd also work for a Unicomp PC-122, I'm guessing? I may go that route (see other thread).
https://geekhack.org/index.php?topic=80741.0
Robert
« Last Edit: Thu, 24 March 2016, 12:27:44 by aptivaboy »
Offline appleonama
  • Trollo en USA
« Reply #8 on: Thu, 24 March 2016, 12:22:16 »
Interesting I didn't know about this but there must be a cheaper solution right?
Offline Moistgun
  • Slippery When Wet
« Reply #9 on: Thu, 24 March 2016, 12:43:00 »
You can wire in a teensy 2.0 for half that price and use the code to convert it directly. Takes a bit more work.
« Reply #10 on: Thu, 24 March 2016, 14:45:10 »
[/quote]
And you can buy a Chinese knock-off for $5, but each price jump makes it considerably easier to use.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #12 on: Thu, 24 March 2016, 22:35:03 »
Like this?
http://imgur.com/a/tIonH
I had mine done by Phpsphorglow.
« Reply #13 on: Sat, 26 March 2016, 05:07:28 »
+1000
I use mine every week - works perfectly on a few Model Ms with my Mac.
Won't get much cheaper than this one:
http://www.ebay.com/itm/Vintage-IBM-Model-M-Clicky-Keyboard-1395660-RJ45-Not-a-AT-/351681868817?hash=item51e1df7411:g:oQcAAOSwAuNW7fMc&afsrc=1&rmvSB=true
And looks like you won't get that one anyway - already sold ;)
Like this?
I still like that keyboard, and not just because of the yellow underlay.
Ok, maybe because of the yellow underlay :p
Offline Snowdog993
« Reply #14 on: Sat, 26 March 2016, 08:01:50 »
Like this?
It's actually being used, and has been since the day I obtained it.  It's not sitting in a box at all.  That keyboard is very special.
« Reply #15 on: Sun, 27 March 2016, 19:59:47 »
Like this?
Good  to hear :)
