Author Topic: Costar Stabilizers Issue with Thick Keycaps  (Read 3763 times)
Offline Zar7
« on: Thu, 07 April 2016, 15:01:09 »
Hey guys! I am currently figuring out the issue I have with my Quickfire Rapid (Cherry MX Red). The other day I lubed all the stabilizers on the keyboard (including the spacebar), and with the stock ABS keycaps, the keystrokes are buttery smooth and very satisfying. However, when I acquired a batch of Vortex Doubleshot PBT Keycaps, there is a drastic change of feel for the keys with stabilizers beneath them. For example, my enter key feels very sticky (felt like it was rubbing against something underneath). Even when the stabilizers lubed, it still feel sticky and inconsistent.
What is the best way to resolve this issue?
Offline n3ro
Re: Costar Stabilizers Issue with Thick Keycaps
« Reply #1 on: Thu, 07 April 2016, 17:24:46 »
I followed this guide for my Filco with Leopold thick pbt keycaps.
http://imgur.com/a/ln1nW
« Reply #2 on: Thu, 07 April 2016, 21:45:31 »
You can test by putting the stock keycaps back on.
If buttery smoothness comes back, then the keycaps are rubbing.
Offline yomammary
« Reply #3 on: Fri, 08 April 2016, 02:12:58 »
I filed some keycaps and it fixed my problem.
RF 87u 55g | Leeku 1800
