Author Topic: [GB] 75% Skeleton Keyboard  (Read 155636 times)
Offline xondat
  • i'm not a star
« on: Thu, 07 April 2016, 16:03:59 »
Information:
  • 2mm 6082 Brushed Plates
  • Two Piece "Skeleton" Case
  • Universal Plate with Switch Opening
  • Winkeyless b.mini
« Last Edit: Tue, 01 August 2017, 20:56:54 by xondat »
Offline xondat
  • i'm not a star
Re: [GB] 75% Skeleton Kit
« Reply #1 on: Thu, 07 April 2016, 16:11:03 »
irrelevant
« Last Edit: Tue, 18 October 2016, 14:39:10 by xondat »
Offline byker
  • Literally Canada
Re: [GB] 75% Skeleton Kit - Open for orders
« Reply #2 on: Fri, 08 April 2016, 00:14:58 »
Approval bump, and remember CAVEAT EMPTOR.
Offline endeavour90
« Reply #3 on: Fri, 08 April 2016, 01:11:08 »
How much will the shipping be?
Offline diiiP
« Reply #4 on: Fri, 08 April 2016, 01:36:29 »
Few quick questions  ;D
The PCB in this Groupbuy is this one, right?
http://winkeyless.kr/product/b-mini-x2-pcb/
The Controller Parts, Diodes and Resistors are part of the shipment?
Or are already solderd to the PCB?
Kind regards
Offline Phenix
« Reply #5 on: Fri, 08 April 2016, 02:44:27 »
Can you add support for split space bad? (something like "2. 75 1. 25 2. 75)?
Winter is coming.
Offline joey
« Reply #6 on: Fri, 08 April 2016, 02:50:01 »
This is using the winkeyless.kr PCB, which doesn't support that.
Offline Delirious
« Reply #7 on: Fri, 08 April 2016, 08:28:24 »
Do we have a choice between North or South LED positions?
Offline Radlife
« Reply #8 on: Fri, 08 April 2016, 08:36:46 »
Would we have to solder diodes ourselves or can we order them presoldered?
Offline xondat
  • i'm not a star
« Reply #9 on: Fri, 08 April 2016, 09:31:13 »
Depends on your location, check the section I made for shipping.
Kind regards
It is that PCB. Parts are already soldered, you'll need to do the resistors yourselves as it depends on what color you want.
The PCB doesn't support that so no - see the colorful picture for layout options.
I'll be picking South facing, so that the Cherry logo is the right way. If this is an issue for everyone in the GB then I'll change it.
If you want to solder them, chose it on the form. If not, I'll be doing the soldering.
« Last Edit: Fri, 08 April 2016, 09:35:39 by xondat »
Offline hatran87
« Reply #10 on: Sat, 09 April 2016, 10:44:56 »
do u have any prototype of this keyboard?
Compact SQ by Leeku
Offline xondat
  • i'm not a star
« Reply #11 on: Sat, 09 April 2016, 11:03:39 »
No. But everything fits due to the simplicity of it. It would cost $270ish per kit if I ordered 1.
Offline hatran87
« Reply #12 on: Sun, 10 April 2016, 10:18:12 »
Ohh , so do u have any mockup's pictures ? i want to see it before decide to join :)
Compact SQ by Leeku
Offline xondat
  • i'm not a star
« Reply #13 on: Sun, 10 April 2016, 11:36:16 »
Here is a different layout/keyboard but the exact same idea. It will look like this but 75% layout.
Here is an example photo of what an assembled ANSI 1.50 Winkey kit looks like: (credit to jdcarpe)
Offline Phenix
« Reply #14 on: Sun, 10 April 2016, 11:45:26 »
another question: How can I program this board? (or is an teensy/something similar pre-soldered onto the pcb?
Can you please check shipping costs to Germany? (It says ~55€ to me, is this wrong?)
Winter is coming.
Offline xondat
  • i'm not a star
« Reply #15 on: Sun, 10 April 2016, 11:56:09 »
It is a standard winkeyless PCB therefore you can program it how you want, see this setup guide here for more information.
Shipping should be around $18 - how did you come to that price?
Offline Phenix
Re: [GB] 75% Skeleton Keyboard Kit - Open for orders
« Reply #16 on: Sun, 10 April 2016, 12:14:23 »
I really cant say, most likely I entered some wrong informations :rolleyes:
can you please update the thread how many kits are sold? I think I would join (most likely) for the 135$ option.
How much is an backplate/top plate? And is money saving if soldering diodes myself possible?
« Last Edit: Sun, 10 April 2016, 12:29:01 by Phenix »
Winter is coming.
Offline xondat
  • i'm not a star
« Reply #17 on: Sun, 10 April 2016, 12:34:31 »
I've added an option in the form to commit at $135. The top/bottom plates would be -$50 from each price point. My soldering is free; the option is just there in case someone want's to solder the diodes on themselves.
Offline Phenix
« Reply #18 on: Sun, 10 April 2016, 12:39:52 »
so 50$ per plate (I assume?)
=100$ together
Winter is coming.
Offline xondat
  • i'm not a star
« Reply #19 on: Sun, 10 April 2016, 12:54:22 »
=100$ together
Essentially yes - it's more like 65/35 due to the complexity of the top plate.
Offline Phenix
« Reply #20 on: Sun, 10 April 2016, 14:03:04 »
http://i.imgur.com/EOBffxX.jpg
will the final board look like this?
(are the spaces in this pic are acrylic/translucent?
Winter is coming.
Offline xondat
  • i'm not a star
« Reply #21 on: Sun, 10 April 2016, 14:05:36 »
Yes. There's nothing in the spaces.
Offline TalkingTree
    • My projects
« Reply #22 on: Sun, 10 April 2016, 14:21:15 »
Is it possible to pay through SEPA?
Offline blighty
« Reply #23 on: Sun, 10 April 2016, 14:48:27 »
You really should have a prototype made, just to make sure that the top plate fits.  It would be a waste of alot of people's money if these were cut and it turned out that something was a fraction of a millimeter off...
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline xondat
  • i'm not a star
« Reply #24 on: Sun, 10 April 2016, 15:26:07 »
What would be able to go wrong? Many people have used the exact same service and process to do what I'm doing and it's worked out fine. I've spoke to a few people that generated the files through swillkb and then used BBS and it's gone flawlessly.
The whole reason this came about is due to a one off being very expensive - a few people said they'd be interested in doing a tiny group buy around it so I'm offering it to everybody.
I'll be running more skeleton group buys if this goes well, so feel free to join those. If you're sceptical now, then I will refund your money if it goes wrong for you.
Offline xondat
  • i'm not a star
« Reply #25 on: Sun, 10 April 2016, 15:27:45 »
Sure - I'll have to research it a bit though.
Offline darkclone24
« Reply #26 on: Sun, 10 April 2016, 15:37:00 »
Already waiting on 3 boards from other buys; but you're making the greatest layout and running from the greatest country. I'm in!
« Last Edit: Sun, 10 April 2016, 15:39:17 by darkclone24 »
RS84 67g Zealio Purple | Choc Mini MX Black | WASD V2 MX Clear | Golbat 78g Zealio Purple | Duck Octagon V2 MX Clear
Offline xondat
  • i'm not a star
« Reply #27 on: Sun, 10 April 2016, 16:17:51 »
Thanks for joining. 75% is pretty neat, can't wait.
Offline Phenix
« Reply #28 on: Sun, 10 April 2016, 16:47:56 »
ok.. Sounds (at least for me) not that nice.
Has someone somemore pic of such an build?
Whats the advantage of this design beside saving costs?
« Last Edit: Sun, 10 April 2016, 16:53:08 by Phenix »
Winter is coming.
Offline blighty
« Reply #29 on: Sun, 10 April 2016, 17:58:25 »
That's kind of vague.  Perhaps pics of these completed projects?
I'll be running more skeleton group buys if this goes well, so feel free to join those. If you're skeptical now, then I will refund your money if it goes wrong for you.
For a person who has classified sales because "money," and backs in and out of group buys, you don't exactly inspire confidence in being able to issue refunds if something goes wrong.
I wish you luck in this, and I hope it goes off without a hitch.
Offline Delirious
« Reply #30 on: Sun, 10 April 2016, 20:33:43 »
Just want to point out something, I remembered something was odd about winkeyless pcb when I built mine so I took a look at the case drawing on his site.
As you can see the backspace and left shift have reversed orientation for stabilizers, right now your schematic has all the stabilizers facing south. You might run into clearance issue with that.
Also just a minor point but stepped cap support would be nice.
Offline Data
« Reply #31 on: Mon, 11 April 2016, 00:36:34 »
This is exactly why you build a prototype and do a fit check.
Offline endeavour90
« Reply #32 on: Mon, 11 April 2016, 00:44:04 »
Some prototype from acrylic would be nice.
Offline 27
  • The Maple Man
« Reply #33 on: Mon, 11 April 2016, 02:19:27 »
The stabilizers are pcb mount, so the wires should be under the plate.  The stabilizer holes he's chosen will not have any sort of issues.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline xondat
  • i'm not a star
« Reply #34 on: Mon, 11 April 2016, 03:29:43 »
Neither plate doesn't support plate mount stabilizers. This means that the wires are under the plate.
The PCB doesn't support stepped caps lock - it would be nice but its impossible.
Offline xondat
  • i'm not a star
« Reply #35 on: Mon, 11 April 2016, 06:42:40 »
I've contacted Hojin for clarification on the stepped caps lock support as his pictures conflict.
I've also posted an update in the 2nd post of this thread.
Offline pomk
« Reply #36 on: Mon, 11 April 2016, 07:32:33 »
The holes are OK, but their orientations are not compatible with the chosen pcb. Glancing the pcb I see that the ANSI enter and spacebar are OK, all other stabilizer notches should be rotated 180 degrees around the stabilized switch.
« Last Edit: Mon, 11 April 2016, 07:39:16 by pomk »
Offline 27
  • The Maple Man
« Reply #37 on: Mon, 11 April 2016, 09:07:19 »
Ahhh, I see what you mean.  Looks like he's checking in with Hojin to confirm anyways.
Offline pomk
« Reply #38 on: Mon, 11 April 2016, 10:05:34 »
Hope so!
Offline xondat
  • i'm not a star
« Reply #39 on: Mon, 11 April 2016, 14:58:19 »
Good news - yuktsi, the creator of the TGR customs, has taken time to create a new top plate design to accommodate for the PCB compatible stabilizers.  I will update the main post with updated screenshots and compatibility previews in a hour or so. I will still be getting a prototype made, just to be sure, and I would like to deeply thank yuktsi for the assistance.
Offline xondat
  • i'm not a star
« Reply #40 on: Mon, 11 April 2016, 16:38:30 »
Updated with 'renders' of the updated top plate (& bottom for good measure). For all that were concerned, please check the stabilizer positions and correct us if we have made a mistake. A prototype will be ordered promptly tomorrow.
Offline Spaceman1200
« Reply #41 on: Tue, 12 April 2016, 13:37:12 »
Joined! Hit commit by accident so I am in at moq
Offline xondat
  • i'm not a star
« Reply #42 on: Tue, 12 April 2016, 16:44:20 »
Great - I made a note of that.
Offline amharris
« Reply #43 on: Tue, 12 April 2016, 17:03:03 »
Damn, xondat, this is fantastic!
This would be perfect for a friend of mine; it's just a matter of whether he can get the money together in time or not.
Cheers for such a great GB, regardless. :)
Offline pomk
« Reply #44 on: Wed, 13 April 2016, 04:36:00 »
A bit of a late reply from me. The updated plate design looks to be compatible with the pcb. My only complaint would be that the ISO enter area is a bit lazily drawn and the switch is not supported by the plate from the right side. Take a look at Gon tkl plate design for the 'optimal' shape, just add the switch top removal notches.
http://www.gonskeyboardworks.com/123-thickbox_default/gon-ns-nerd-tkl-housing-only.jpg
Offline xondat
  • i'm not a star
« Reply #45 on: Wed, 13 April 2016, 09:21:09 »
The absolute deadline for payment is the 8th of May, you may want to let him know. Thanks for the kind words!
If you can help me make this addition to the file then that'd be great, otherwise you have to understand that my options are limited and it won't make a noticeable difference. Take the Orion V2 as an example, same as mine and no one complained. A prototype is currently in production - I will see if it makes a difference.
Offline xondat
  • i'm not a star
« Reply #46 on: Thu, 14 April 2016, 08:36:28 »
Currently 2 away from the MOQ and then 1 more kit for the price drop. Still another 15 days to order :thumb:
Offline heissler
  • I engineer invisible stuff
« Reply #47 on: Thu, 14 April 2016, 09:41:23 »
Committing at 135  :thumb:
Has trouble not spending money on keyboards
Offline xondat
  • i'm not a star
« Reply #48 on: Thu, 14 April 2016, 10:26:03 »
Thanks. This puts the group buy one away from the lowest price ^-^
Offline K.Mak
Re: [GB] 75% Skeleton Keyboard Kit (1 Order From Drop)
« Reply #49 on: Thu, 14 April 2016, 10:31:16 »
Do you have an estimated ship date?
