Author Topic: What the better way to paint a ducky?  (Read 2348 times)
Offline WrxMike
« on: Wed, 13 April 2016, 02:15:17 »
Is it better to paint over it with a couple of coats or sand it down then paint it?
Sent from my SM-N920T using Tapatalk
Offline Fiery
  • Click Clack Clock and a nice Thock
Re: What the better way to paint a ducky?
« Reply #1 on: Wed, 13 April 2016, 02:19:43 »
Are you painting it by hand? and usually you want to sand it down as it helps the paint stick better.
TP4 fanboy
Offline WrxMike
« Reply #2 on: Wed, 13 April 2016, 03:43:14 »
I'm spray painting it. I'm doing a matte white base with light blue keycaps.
Offline Fiery
« Reply #3 on: Wed, 13 April 2016, 03:45:51 »
I see, I would still reccommend sanding it down. There are great guides on painting stuff on various forums. So try looking around.
TP4 fanboy
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Wed, 13 April 2016, 03:50:06 »
Sand first, for sure. Even if you are using a plastic specific spray paint like Krylon Fusion, you should still sand it down to below the original coating.
Offline WrxMike
« Reply #5 on: Wed, 13 April 2016, 12:02:40 »
What's better Krylon or Rustoleum. I know it is subjective. Just wondering what you guys think.
