Author Topic: Hello from California  (Read 2099 times)
Offline Boundl3ss
« on: Sun, 24 April 2016, 23:09:03 »
Hello, I just bought my very first mech (a CM Storm Rapid w/ MX browns) as it was suggested to me by many due to its ability to be modded with a frosty flake and fully standard keycap set. I will be getting it in soon and am very happy to be upgrading from my $20 TKL membrane. I also bought o-rings with it as it was only an added cost for $7.50. Hoping to get into this new hobby.
Re: Hello from California
« Reply #1 on: Mon, 25 April 2016, 00:10:47 »
Welcome to Geekhack!
Have you used a modern mechanical keyboard?  It will be interesting to see what you think of it once it arrives.
For most people it is something of an epiphany to use a mechanical keyboard after years of suffering a rubber dome keyboard, not knowing there is something better out there.
Offline Boundl3ss
« Reply #2 on: Mon, 25 April 2016, 00:18:00 »
The most I have used a mechanical keyboard is testing one in a store. I used a laptop with membrane for over 2 years, and then built my desktop ~2 months ago and am just getting a mech now after buying a cheap membrane when I built the computer.
« Reply #3 on: Mon, 25 April 2016, 00:54:50 »
I hope you like the one you have bought :)
