Author Topic: [GB] Sentraq TK78 Keyboard Kit (Closing/Troubleshooting)  (Read 158196 times)
Offline tj_gee
Re: [GB] Sentraq TK78 Keyboard Kit (Waiting for Replacements)
« Reply #300 on: Wed, 21 September 2016, 10:42:46 »
That's what I thought. He sent it to me late at night so I assumed he meant plastic and was just tired.
Offline kawasaki161
« Reply #301 on: Wed, 21 September 2016, 12:07:40 »
If your case is machined like mine I'd recommend using real washers on the right standoffs (so the PCB does is not bent by default) and some foam on all screw holes on both sides of the PCB since the standoffs are not angled like the PCB. I used some foam sheet from an arts supplier and made my own foam washers.
For the middle and left screws the combination would be Screwhead -> Foam -> PCB -> Foam -> Case
For the right screws it would be Screwhead -> Foam -> PCB -> Foam -> Washer -> Case
Offline IneffableTao
« Reply #302 on: Wed, 21 September 2016, 16:07:09 »
I did the assembly for tj_gee so I might as well chime in here and bypass the middleman.
Find longer metal screws and use metal washers between the screw head and the plate to secure the plate to the case without really touching the pcb
You mean plastic/paper washers? Wouldn't a metal washer just short the circuit again?
What I meant with my last of 4 possible solutions (quoted above) was something like this, expertly drawn, cross section: http://i.imgur.com/X1ufizC.jpg
There would not be any metal touching the top of the PCB which seems to be where the short is occurring.  I'm not positive there's enough space between the switches on top of the plate to squeeze a washer anyway, so this is all mostly moot, but of the 4 options it keeps the metal the farthest away from the exposed connection.
I'll have to see if the standoffs suffer the same issue as described by kawasaki161 but I don't think they do; I'll validate tonight.
FWIW I have conferred with my EE cousin and he said nail polish, super glue or a conformal coating (most often used for waterproofing PCBs) can be used to cover the exposed trace and then a non-conductive washer will suffice.  I'll probably go with the superglue as I have several varieties on hand already, and then either foam or paper washers on top of that (and maybe under the PCB as well, if necessary)
Thanks all for the feedback and suggestions.
Offline skullydazed
  • Had to turn PM's off. Email info@clueboard.co!
    • Clueboard
« Reply #303 on: Thu, 22 September 2016, 14:59:33 »
On the screw holes, my recommendation would be to use longer screws and secure the plate to the case that way. If you can't do that for some reason nylon or rubber washer will work as well. I would prefer those over paper washers as they're less likely to tear and expose copper underneath, won't scrape off silkscreen, and will spread the load better.
Offline breitling
« Reply #304 on: Sun, 25 September 2016, 09:52:27 »
what is the eta for the replacements?
Offline doodersbrother
« Reply #305 on: Thu, 29 September 2016, 19:56:49 »
Hey guys, 5 PCB's are being made to make sure everything works and once we confirm that we will order the rest of the PCB's. I'm not certain on how long this will take, especially because of the week long holiday in China starting Oct 1.
I'll post another update when I know more.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #306 on: Thu, 29 September 2016, 20:37:20 »
Thanks for the update dooders. Hopefully this batch comes out better than the last  :thumb:
« Reply #307 on: Fri, 07 October 2016, 09:47:40 »
The first 5 PCBs are supposed to be finished around the 10th, as soon as they are tested we'll get the rest ordered!
Offline SmithTheNinja
« Reply #308 on: Fri, 07 October 2016, 22:08:38 »
Thanks for the update Dooders, glad to hear things are moving along!
« Reply #309 on: Tue, 11 October 2016, 17:30:10 »
Test PCBs are finished and are currently being tested!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #310 on: Tue, 11 October 2016, 18:50:00 »
Great news! Too bad they're green, the white looked nicer.
Offline deductivemonkee
  • Professional Lurker
« Reply #311 on: Tue, 11 October 2016, 20:08:55 »
Test PCBs
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #312 on: Tue, 11 October 2016, 20:34:39 »
Test PCBs
Good point =|
Offline breitling
« Reply #313 on: Tue, 11 October 2016, 22:10:30 »
i kinda like the green... dont have many green pcbs its kind retro.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #314 on: Tue, 11 October 2016, 22:22:49 »
Retro indeed
Offline kawasaki161
« Reply #315 on: Wed, 12 October 2016, 00:51:58 »
Don't forget the mounting hole between the (referring to standard 1,25 and 6,25 layout) spacebar and right alt key again  ;) I can't spot it on that prototype.
« Reply #316 on: Wed, 12 October 2016, 22:49:50 »
Guys, only this PCB is green. The actual replacements will be white. Sorry for the confusion.
Offline Brammm87
« Reply #317 on: Tue, 18 October 2016, 06:01:24 »
Any updates on this?
pls gief bbv2
« Reply #318 on: Sat, 22 October 2016, 13:55:39 »
What's the word on testing Dooders?  Did the green sample boards pass?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #319 on: Sat, 22 October 2016, 16:38:58 »
Interested to know the same. This pile of SIP'd switches has been sitting on my desk forever!
Offline scramm
« Reply #320 on: Sun, 23 October 2016, 08:43:53 »
Speaking of piles of switches, since my 60% from massdrop had to go back,  i have 70 zealios (78g) sitting here. Anyone have a few they could sell me so i can fill this board with them?
« Reply #321 on: Sun, 23 October 2016, 09:59:26 »
PM'd
« Reply #322 on: Thu, 03 November 2016, 22:07:20 »
Hey guys, another update. The sample PCB tested well and they are making 20 pcs right now. The PCB's may actually be green instead of white as previously mentioned. As soon as they're finished they'll get shipped to me where I'll inspect and test each one and ship out to you guys.
Thanks again for being so patient with this...
« Reply #323 on: Thu, 03 November 2016, 22:17:59 »
Thanks for the update dooders, I was starting to get worried :P
I for one embrace the possibility of green, its not like it will be visible much behind the plate though.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #324 on: Thu, 03 November 2016, 22:21:43 »
Hey dooders. Appreciate the update. Can't wait to get a working PCB in hand  :thumb:
Offline breitling
« Reply #325 on: Thu, 24 November 2016, 01:08:18 »
any chance these will make it before Christmas?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #326 on: Mon, 28 November 2016, 20:53:56 »
Interested to know the same. What's the timeline looking like?
« Reply #327 on: Thu, 01 December 2016, 00:03:20 »
Okay guys, I received the new PCB's. I'll test them further, but so far it's looking promising. Once I'm comfortable that they work well, I'll start shipping as soon as next week.
« Reply #328 on: Thu, 01 December 2016, 00:50:55 »
It's begging to sound a lot like maybe,
Thanks to doodersbro;
Take a look in this thread, it's glistening once again
With LEDs and silver traces aglow.
Boards in ev'ry store,
But the prettiest sight to see is the keeb that will be
On your own front door!
Thanks for the update Dooders, put me in the holiday spirit! :P
« Last Edit: Thu, 01 December 2016, 00:52:26 by SmithTheNinja »
« Reply #329 on: Thu, 01 December 2016, 01:38:55 »
I'm sorry that you guys have had to wait this long in the first place :/
« Reply #330 on: Thu, 01 December 2016, 01:50:39 »
Don't worry about it bud, a lot of this stuff was outside your control and you've gone well above and beyond to make sure everyone still gets a fully functional board.  You're a champ in my book. <3
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #331 on: Thu, 01 December 2016, 08:36:28 »
Thanks dooders. Looking forward to it =D
« Reply #332 on: Sun, 04 December 2016, 20:40:47 »
Kits will start shipping out in order this week.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #333 on: Sun, 04 December 2016, 21:11:33 »
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #334 on: Sun, 04 December 2016, 22:55:28 »
I always love a good Office gif
Offline Brammm87
« Reply #335 on: Mon, 05 December 2016, 07:09:32 »
Oh baby! Been itching to get my solder iron out again :D
And then I just realized I'm still at my parents (in between moves) and all my keyboard stuff is somewhere in a box in storage... Roll on January!
pls gief bbv2
« Reply #336 on: Wed, 14 December 2016, 18:13:35 »
Ok so breitling's was shipped last week, tracking should've been emailed.
The following just need replacement PCB's, correct? If so, I'll get those out tomorrow.
TJ_Gee
alexjd99
UsualSuspectXXX
SmithTheNinja
The rest will ship very soon after, and those who needed assembly will take about a week.
Offline tj_gee
« Reply #337 on: Wed, 14 December 2016, 18:19:15 »
Mine can go last.
My builder hacked mine together in an ingenious way so that it works, but I would like a replacement in case something else pops up with it.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #338 on: Wed, 14 December 2016, 22:32:24 »
Great. Thanks for the update dooders!
Offline Brammm87
« Reply #339 on: Thu, 15 December 2016, 02:23:25 »
Awesome news! Looking forward to finally building this :D
pls gief bbv2
Offline skuko
« Reply #340 on: Thu, 15 December 2016, 04:58:53 »
thank you for the update dooders
Offline breitling
« Reply #341 on: Thu, 15 December 2016, 10:11:35 »
Sweet!!!! Didn't see an email with tracking but am happy to hear its on its way!!!!!
Offline alexjd99
« Reply #342 on: Thu, 15 December 2016, 18:13:52 »
TJ_Gee
alexjd99
UsualSuspectXXX
SmithTheNinja
I do need a replacement PCB.
Thanks so much for the update! :thumb:
« Reply #343 on: Thu, 15 December 2016, 21:05:17 »
TJ_Gee
alexjd99
UsualSuspectXXX
SmithTheNinja
Yup just the PCB for me!
Offline breitling
« Reply #344 on: Fri, 16 December 2016, 15:25:45 »
Arrived!
Looks pretty sweet. Lighter than most of my aluminum boards.
Are these PCBs good to go? Or should I be testing it? I guess I'll test it anyway but kind of lazy... lol
Offline kawasaki161
« Reply #345 on: Fri, 16 December 2016, 15:29:22 »
Arrived!
Did he forget the mounting hole in the lower middle again?  :)) :)) :))
Offline phinix
« Reply #346 on: Fri, 16 December 2016, 16:20:21 »
Is there ISO layout too?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #347 on: Fri, 16 December 2016, 17:35:05 »
Arrived!
Appears that way
Offline Brammm87
« Reply #348 on: Mon, 19 December 2016, 06:47:03 »
Dooders, you might have an old address of mine, what's the best way to reach you to update that?
pls gief bbv2
Offline scramm
« Reply #349 on: Mon, 19 December 2016, 07:07:30 »
I just sent a pm for the same reason, I'll be moving before these ship out
