Author Topic: [GB] Sentraq TK78 Keyboard Kit (Closing/Troubleshooting)  (Read 158204 times)
Offline breitling
Re: [GB] Sentraq TK78 Keyboard Kit (Waiting for Replacements)
« Reply #350 on: Wed, 21 December 2016, 11:16:20 »
Are these PCBs good to go? Or should I be testing it? I guess I'll test it anyway but kind of lazy... lol
Just finished testing all the keys on mine before assembly and they're working 100% so mine is good.
Offline doodersbrother
« Reply #351 on: Tue, 27 December 2016, 18:33:16 »
Hey sorry for the delays. Got really busy preparing for Christmas. I'll get these out through tomorrow and the next day.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #352 on: Tue, 27 December 2016, 21:55:34 »
Great! Hope you had a wonderful Christmas with your family
Offline Brammm87
« Reply #353 on: Fri, 30 December 2016, 11:40:46 »
Oooh baby, are those all boards? As in, mine as well (was one of the last to order)?
pls gief bbv2
« Reply #354 on: Sat, 31 December 2016, 18:25:32 »
Tracking Numbers will be updated soon on the spreadsheet. Link is on the first post of the whole thread.
edit: I'm out right now so it should be up noonish tomorrow
« Last Edit: Sat, 31 December 2016, 18:30:19 by doodersbrother »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #355 on: Sat, 31 December 2016, 18:28:43 »
Yay =D
« Reply #356 on: Mon, 02 January 2017, 19:35:17 »
Check the spreadsheet! Jamtakno and Bramm87's shipped. Rest will be updated tomorrow.
Offline Brammm87
« Reply #357 on: Tue, 03 January 2017, 03:34:42 »
Oh man, can't wait :D
pls gief bbv2
Offline bciamny
« Reply #358 on: Fri, 06 January 2017, 20:16:41 »
any update on whether others will be shipped out?
« Reply #359 on: Sat, 07 January 2017, 00:01:46 »
More orders shipped out, check the spreadsheet.
Offline SmithTheNinja
« Reply #360 on: Sat, 07 January 2017, 00:30:59 »
Thanks Dooders! So excited for this board!
Offline breitling
« Reply #361 on: Sun, 08 January 2017, 13:20:17 »
Man I have re-programmed a lot of boards but never using the firmware from someone's github.. how do you run the software on a windows machine? I also went into TKG site but there's no Sentraq TK78 in the dropdown for boards. Anyone able to help? I can use it with default since its close to what I normally use but it would be nice to program a couple of the keys :)
Any help would be greatly appreciated, thanks!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #362 on: Sun, 08 January 2017, 13:26:29 »
Here is the official TMK firmware for the TK78. Which is a fork of the original TMK firmware. However, when programming my planck, I found it easier to use QMK which is a TMK derivative created by Jack Humbert (the creator of OLKB). I might end up re-creating the TK78 matrix into QMK for easier remapping... once I get my new PCB.
Offline Brammm87
« Reply #363 on: Mon, 09 January 2017, 04:38:36 »
dooders, my shipping hasn't moved from "shipping label created" since Jan 3d. Assuming it still has to go out?
pls gief bbv2
« Reply #364 on: Wed, 11 January 2017, 10:52:22 »
You should see movement by now? People in the US should've already received.
Also, make sure to test the PCB before committing to soldering the whole thing!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #365 on: Wed, 11 January 2017, 10:55:54 »
Mine started moving yesterday afternoon. Thanks for getting replacement PCB's out to us!
Offline tj_gee
« Reply #366 on: Wed, 11 January 2017, 12:42:36 »
Have all the replacements shipped or just a few?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #367 on: Wed, 11 January 2017, 12:54:54 »
Link is at the top of the OP. Does not look like yours has shipped.
Offline Brammm87
« Reply #368 on: Fri, 13 January 2017, 00:40:37 »
Mine changed to "acceptance" on Jan 9th, hasn't moved since. I can wait a little longer :p
pls gief bbv2
Offline breitling
« Reply #369 on: Fri, 13 January 2017, 00:44:10 »
Thanks, but how do i run the firmware?
« Reply #370 on: Fri, 13 January 2017, 15:21:27 »
You don't so much run the firmware as build it and install in onto your board.  Check out the QMK Wiki for some guides or try the Build Guide from TMK.  They both have basically the same steps and information.  If you still can't get it there's probably a guide here on the forums somewhere where you can ask for more help.
Also yay! My board is here and first plug in everything works as it's supposed to and all the keys worked correctly when shorted with some tweazers! Time to get soldering so I can post some pictures of this beauty on /r/MK!
Thanks for all the hardwork getting these out Dooders, I can't wait to get clacking away!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #371 on: Fri, 13 January 2017, 16:40:58 »
Woops, sorry, didn't see your response. What SmithTheNinja said is true.
To add to that, you should be able to use any hex loader. Teensy Loader and DFU Programmer should both be good options.
Edit: ****ered that up a bit
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #372 on: Sat, 14 January 2017, 20:21:19 »
Just gave mine a test and everything looks good.
However, I can't figure out how the Num Lock & Caps Lock LED's are supposed to light. Doesn't seem to be dependent on them being active.
Also, seems like the printing on the numpad is a bit off (not that it bothers me)
« Last Edit: Sat, 14 January 2017, 20:23:16 by UsualSuspectXXX »
« Reply #373 on: Sun, 15 January 2017, 12:50:06 »
Also don't be like me, the stabs are PCB mount, you need to install them before soldering or you're gonna have a bad time.
« Reply #374 on: Sun, 15 January 2017, 23:14:32 »
Not having a lot of luck reprogramming this guy still, dfu-programmer, Atmel FLIP and QMK Firmware Flasher all die in the same spot with an error along these lines.  It seems like I can't erase the chip to reprogram it?  Anyone seen something like this before?
Code: [Select]
Error: Command failed: C:\Program Files (x86)\QMK Firmware Flasher\resources\app/dfu/dfu-programmer.exe atmega32u4 erase --force
Erasing flash...  Success
Checking memory from 0x0 to 0x6FFF...  Not blank at 0x1.
dfu-programmer atmega32u4 flash *PATH*\tk78-r.hex
Checking memory from 0x0 to 0x5BFF...  Not blank at 0x1.
The target memory for the program is not blank.
Use --force flag to override this error check.
dfu-programmer atmega32u4 reset
Flashing complete!
The board works with the default layout, though the backlight key (fn0 + w) does some odd things, namely it only lights the top row (despite everything lighting up for a split second when plugging it in) and makes it no longer recognize as a keyboard, but I'd live without backlights if I can at least get the keymap I want to work.
EDIT:  The caps right above the MCU are also wicked hot which doesn't seem good... I'm talking burn your finger if you touch them hot.
« Last Edit: Sun, 15 January 2017, 23:31:29 by SmithTheNinja »
« Reply #375 on: Mon, 16 January 2017, 02:49:03 »
Code: [Select]
Flashing complete!
Hmm I'll get back to you on this
Offline skullydazed
  • Had to turn PM's off. Email info@clueboard.co!
    • Clueboard
« Reply #376 on: Mon, 16 January 2017, 07:25:36 »
There's a short somewhere. The MCU should not get that hot.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #377 on: Mon, 16 January 2017, 07:30:21 »
I was about to say the same thing. This would also explain why the LEDS are only working on the top row.
You should check the LED traces somewhere around where the work and don't work. Should provide some insight as to where the short is (hopefully).
Offline skuko
« Reply #378 on: Tue, 17 January 2017, 07:34:24 »
hey guys, i am trying to find someone to take over my order for 180$, any1 interested?
« Reply #379 on: Tue, 17 January 2017, 11:56:09 »
I'll PM you when I get home from work. I'd be game for that.
Edit: PM sent
« Last Edit: Tue, 17 January 2017, 17:06:39 by SmithTheNinja »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #380 on: Sat, 21 January 2017, 16:42:44 »
Alright, so this is kind of strange...
I had tested everything when I got my replacement PCB, all good. Finished soldering everything, plugged it in and everything worked perfectly until I flicked on the LEDs. They all lit up fine, but now I can't get any keypresses to register. Also, I can't turn the LEDs back off with Fn + S.
It almost seems like the LEDs are drawing all of the power away from the controller or the board got wiped somehow.
Any advice would be appreciated, cheers.
« Reply #381 on: Sat, 21 January 2017, 20:52:51 »
Is it still detected by the computer, and if so can you still flash to it? And keyboard is not working at all, just the LEDs and those are unable to be turned off?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #382 on: Sat, 21 January 2017, 21:09:07 »
I can check in a bit. Let me go compile the firware to flash to it. But yes, only the LEDs turn on, keys do not send keycodes to the computer, and Fn + S does not lower them (which leads me to believe the controller is not running). I'll post back here inna bit after I get to re-flashing
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #383 on: Sat, 21 January 2017, 22:06:31 »
Plugged in --> all LEDs lit, no output
Using DFU Programmer, ran erase command
Ran flash command with default firmaware
Unplugged/re-plugged in --> no leds lit, all keys worked
Hit Fn + W to enable LEDs --> top row lit up but dim, no keys worked
Unplugged/re-plugged in --> all LEDs lit, no keys worked.
Repeated above steps to flash firmware --> "no device present."
At this point, DFU can no longer see the board to flash.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #384 on: Sun, 22 January 2017, 17:26:04 »
So, got an update for yall.
Finally got DFU loader to recognize the board again, idk what happened. Did a force flash with the default firmware, all's well.
Installed into the case, popped on all my caps and realized I ****ered up a bit. Left shift was crooked and I had the 1.25u modifiers on the left side one position to the right.
Thank god I already had a solder sucker, so I went ahead and fixed that.
Back to my desk, and and everything is working fine...
Plugged in a different USB cable, all of the LEDs lit up, and I expected nothing to work...
Then all of a sudden (while taking that last picture), the LEDS turned off, board kept working. Turned LEDs on, and only top row lit up, then turned off. Nothing worked again.
Unplugged, re-plugged in, and no LEDs, but it's working again. Mostly. Four keys stopped working (Fn, RCtrl, Num0, NumDot).
Now I'm back to DFU loader no longer seeing the board...
This really feels like there is a sever issue with the LED controller
« Reply #385 on: Sun, 22 January 2017, 18:55:02 »
Alright, I'm still trying to figure out what could be going on. Can you post pics of the PCB, specifically the controller and LED driver?
Great looking board btw, love the color scheme. Just a shame you're having these issues.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #386 on: Sun, 22 January 2017, 19:16:55 »
Thanks. I really do love how it looks in black/green with the blanks on it!
This should be enough pictures to get started. Sorry for potatoes. If you need some better pics or more detail of a specific area, please let me know, I'd be happy to.
http://imgur.com/a/37b0X
Offline skullydazed
    • Clueboard
« Reply #387 on: Sun, 22 January 2017, 19:40:57 »
When it was assembled someone got the positions of a capacitor and a resistor wrong. I'm not sure how your board ever worked like that but that would explain some of what you're seeing.
It also appears that most of the decoupling caps have been removed to accommodate the change to TQFP. This would explain why the problem manifests when you turn the backlight on and/or up. Without those caps the current draw from the LEDs turning on is too much for the MCU to withstand and it halts.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #388 on: Sun, 22 January 2017, 19:58:39 »
Oh boy. I've never done any surface mount soldering, you think this is something that I can fix?
As for the second thing that you mentioned, what "decoupling caps" are you talking about? And what is TQFP?
In terms of overpowering the MCU, that makes sense. Surprisingly, everything worked with the LEDs on for a good 5 or 10 minutes.
And I guess the capacitor and resistor could explain why the board suddenly stopped working, but I agree, I'm surprised this works/worked at all to begin with.
Thanks for taking the time to look into my issues. Would you advise me to try to fix this PCB? And could you give me any suggestions for the SMD related soldering?
« Reply #389 on: Sun, 22 January 2017, 20:48:04 »
Decoupling caps limit the power delivered. TQFP is the package (form factor?) Of the controller. The PCB originally used a QFN package.
I'm not sure correcting the caps and resistors will fully fix it when decoupling caps are missing.
I'm out with the family right now, but I'll get back to you after.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #390 on: Sun, 22 January 2017, 20:59:27 »
Thanks dooders. Enjoy your time with the family!
Offline skullydazed
    • Clueboard
« Reply #391 on: Mon, 23 January 2017, 01:13:08 »
I think fixing the cap/resistor that have been swapped will fix the "it doesn't come back ever after replugging" problem. The LED's turning on can still cause the undercurrent problem, but with the other problem fixed the MCU should reset and start working again after the current stabilizes. The decoupling caps can be added by soldering something like this directly to the proper pins on the MCU.
As for whether or not you can fix it, that's really a question you can answer better than I can. It's well within anyone's ability to do a swap like that, the question is whether you have the patience to do it by yourself without an experienced hand to watch and guide. I can honestly say that before I spent some time soldering SMD components I would not have had the patience. I have friends who did have the patience, and after they learned they taught me. You'll have to figure out which side of that fence you're on.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #392 on: Mon, 23 January 2017, 06:54:35 »
I guess I'll have to order some smaller soldering tips before  give it a shot though. Thanks for your help.
« Reply #393 on: Mon, 23 January 2017, 17:44:41 »
Dang Skully you have eagle eyes for figuring that out so quick!
Also Dooders, mines the same deal with those caps and resisters being swapped so I would check the other boards that you have.
Does anyone have specs on what that resister and that cap are?  I'm not the best at surface mounted soldering and have junked a few parts getting them off of boards in the past, so I would like to grab a few extras in case I screw it up.
« Last Edit: Mon, 23 January 2017, 17:49:35 by SmithTheNinja »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #394 on: Mon, 23 January 2017, 17:48:03 »
skully, when I get around to switching these two components, what is the correct orientation of the resistor? Should it be the same as the picture or the same as the other resistor?
« Reply #395 on: Mon, 23 January 2017, 18:50:12 »
Resistors aren't directional.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #396 on: Mon, 23 January 2017, 18:51:58 »
Good to know. Thanks
« Reply #397 on: Wed, 25 January 2017, 16:02:34 »
Hey, how is it going? Any progress?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #398 on: Wed, 25 January 2017, 16:26:11 »
Haven't gotten a chance to swap cap and resistor yet. Need to pick up some desoldering wick first. Should be able to get to it Saturday night though. I appreciate you checking in though.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #399 on: Sat, 28 January 2017, 10:01:01 »
Well, **** me.
I was doing so good, had both of them desoldered, moved the resistor over, and then I dropped the cap. Just spent the last 20 minutes looking all over the floor with one of those bright shop lights. nothing ='[
Can't even explain how angry I feel at myself right now
« Last Edit: Sat, 28 January 2017, 10:11:47 by UsualSuspectXXX »
