Author Topic: [IC] 60% AEKII & AT101W Plates  (Read 42015 times)
Offline phoible
« on: Fri, 29 April 2016, 21:57:08 »
I'm looking to make a run of 60% plates compatible with the AEKII (ANSI). It sounds like there might also be interest in AT101W compatible plates.
If there is enough interest, I would consider trying to procure some ALPS64 PCBs as well?
Is anyone interested?
« Last Edit: Sat, 30 April 2016, 01:38:45 by phoible »
Offline climbalima
  • likes building stuff
Re: [IC] 60% AEKII Plates
« Reply #1 on: Fri, 29 April 2016, 21:59:30 »
Im down for one plate.
Offline KaminKevCrew
« Reply #2 on: Fri, 29 April 2016, 21:59:39 »
I'm somewhat interested. I've got way too many alps switches right now, and I don't know what to do with them, so I'd be interested.
Sent from my SM-G925T using Tapatalk
Offline emdude
« Reply #3 on: Fri, 29 April 2016, 22:00:20 »
I would be, if you could get plates for other layouts, AT101, etc..  :p I'm not sure otherwise..
Definitely would be nice though, given hasu's current Alps64 round.
« Last Edit: Fri, 29 April 2016, 22:04:54 by emdude »
Current drivers: IBM Model M SSK
Offline phoible
« Reply #4 on: Fri, 29 April 2016, 22:08:32 »
If you could get 5+ people interested in AT101 plates, I might be willing to do it.
Offline emdude
« Reply #5 on: Fri, 29 April 2016, 22:12:15 »
Okay, great.  I'd be down for 2 AT101 plates myself. :D
Did you manage to get the CAD files from JDCarpe?
« Last Edit: Fri, 29 April 2016, 22:30:45 by emdude »
« Reply #6 on: Fri, 29 April 2016, 22:29:06 »
I might be down.
« Reply #7 on: Fri, 29 April 2016, 22:47:06 »
I'd be more interested in at 101
 plates, since it would be easier to get caps for that. I'd be interested in at least two of those, I think.
Offline emdude
« Reply #8 on: Fri, 29 April 2016, 22:55:58 »
I'm all for this, but I'm confused by your statement.  It seems to be much easier to get key caps for an AEK-style plate than it is for the AT101 101/103-key plate.
Do you mean the 104-key AT101W?
Offline Radlife
« Reply #9 on: Sat, 30 April 2016, 00:08:15 »
I was thinking of doing the same thing since I got into hasu's short run. I'm going to get plates anyways, might as well save some money.
Count me in.
Offline Radlife
« Reply #10 on: Sat, 30 April 2016, 00:13:38 »
I PM'd JD about it cause I also wanted to get my own plates. He said that since the only way he earns anything is from his designs, and has a blanket policy of to deny requests like that. He did show me how to make my own alps plate design with builder.swllkb.com which has all you need
Offline CosmosAtlas
« Reply #11 on: Sat, 30 April 2016, 00:51:25 »
Count me one, I will definitely picked one up.
Offline phoible
« Reply #12 on: Sat, 30 April 2016, 00:51:42 »
Swill's KB Builder doesn't handle the AEKII spacebar (6.5u) properly. It uses the wrong stabilizers.
If there is sufficient interest, we can either license an existing plate design or generate our own.
The other problem is that having a one-off plate made is quite expensive (~$100). If we can get a group buy together (at least 5 of each type and possibly 10+), the cost per plate will go down considerably.
Offline emdude
« Reply #13 on: Sat, 30 April 2016, 00:55:21 »
Wow, I e-mailed JDCarpe about getting the files as well and haven't gotten a response, I guess that's why.  BlueNalgene said after his GB that one would be able to ask JD for the files as long as it was for a one-off or a non-profit GB..
Anyhow, I think having his CAD files would be ideal because SwillKB's plate designer doesn't seem to fully support Alps..
Like so, JDCarpe/BlueNalgene's AT101 plate:
versus the one I made with SwillKB's editor:
Note that it does not have the necessary holes for the spacebar stabilizer, has extra stabilizer cutouts, etc.  Perhaps someone knows how to fix these in some CAD program?
It does appear that the extra holes were simply hand-drawn in... :P
« Last Edit: Sat, 30 April 2016, 01:38:39 by emdude »
Offline emdude
« Reply #14 on: Sat, 30 April 2016, 00:57:16 »
I hope we can get something like 25 plates done so the price will be around what BlueNalgene charged for them, about $27.50.
Offline emdude
Re: [IC] 60% AEKII & AT101W Plates
« Reply #15 on: Sat, 30 April 2016, 01:52:40 »
Oh I noticed that you changed your IC to include AT101W plates, I just want to clarify that I'd be interested in AT101 plates (101/103-key), not AT101W (104).
I hope other people will want AT101 plates.  :-[
EDIT: Here are all the options that BlueNalgene offered, might help to include them in the OP, if you're willing to offer more than just the AEK and AT101W plates:
AT101
AT101W
AT102W
AEKII ANSI
AEKII ISO
Infinity
HHKB
« Last Edit: Sat, 30 April 2016, 02:00:07 by emdude »
Offline lootbag
« Reply #16 on: Sat, 30 April 2016, 06:19:09 »
Interested!
Would like to have an HHKB style plate ās well if there is enough interest.
Offline njbair
    • nickbair.net
« Reply #17 on: Sat, 30 April 2016, 06:41:46 »
I have way too many Alps 60% boards right now, but if you're making plates from scratch I recommend considering the addition of Costar stab clip holes. That way the boards can support SP Alps keycaps.
My boards:
« Reply #18 on: Sat, 30 April 2016, 07:47:32 »
Yeah, if you all get a community GB going, and want to use my designs, let me know. My licensing fee is quite small, as other GB leaders can attest! :D
Offline tintoret
« Reply #19 on: Sat, 30 April 2016, 08:53:09 »
Definitely down for an AEKII
Offline SJHL
« Reply #20 on: Sat, 30 April 2016, 09:50:15 »
I was planning to just get an AEK and cut it myself but if this group buy happens, Im interested.
Offline phoible
« Reply #21 on: Sat, 30 April 2016, 11:09:18 »
I'm looking into 16ga 304 Stainless. 6061 aluminum is cheaper, but not nearly as strong.
I'm going to contact some local waterjet cutting places to figure out the cost at various quantities. There may be a MOQ on each style if we offer multiple styles, but if not, I'm happy to produce the full range of plates compatible with Hasu's PCB.
It would be awesome if we can get the price to about $30 per plate (plus shipping).
Offline need
« Reply #22 on: Sat, 30 April 2016, 11:25:17 »
I'd love to be in for a AEKII.
And if other plates are possible, I'd really want one that supports 1.5u CTRL & ALT.
Which are AEK and 103 from Hasu's PCB layout range.
Offline StormyMonday
« Reply #23 on: Sat, 30 April 2016, 18:37:39 »
Swills tool uses Costar stabs for the spacebar and Alps stabs for the rest.
Offline Mattr567
« Reply #24 on: Sat, 30 April 2016, 19:41:38 »
Somewhat interested in a AEKII and a PCB.
« Last Edit: Sat, 30 April 2016, 19:46:04 by Mattr567 »
IBM P77, SKCC Green, 1984
Offline rand77
« Reply #25 on: Sun, 01 May 2016, 00:36:55 »
I would be interested in 2 AEK plates.
« Last Edit: Sun, 01 May 2016, 00:38:45 by rand77 »
Offline kiwi99
  • that's a gnarly dookie
« Reply #26 on: Sun, 01 May 2016, 00:50:23 »
I have an aek II on hand as well as a 60% aek II plate I cut for myself that works, mine doesn't have the holes for the spacebar stabilizer hole thing but I could take some measurements and include it (didn't have the aek at the time) and I also did my clueboard plate that supports costar + alps mounting for the spacebar so I would be able to help out with the CAD if needed. I'd also suggest you try to not make the plate too thick so the switches still latch in nicely since I've heard some people complain about that a little.
plates I cut for reference.
Offline punkpc
« Reply #27 on: Sun, 01 May 2016, 23:01:43 »
Interested in a AEKII plate for sure.
Offline Scarpia
« Reply #28 on: Mon, 02 May 2016, 01:42:17 »
I'm most likely in for an AEKII as well, as long as the stab holes will work with the stock AEKII caps
Offline harlw
« Reply #29 on: Mon, 02 May 2016, 09:12:13 »
Interested in both potentially.
Ergodox (x2), V.EA Clone, Tada68, Atreus XL, Planck, Model M 70% Mod
Offline rand77
« Reply #30 on: Mon, 02 May 2016, 22:54:24 »
I will be taking apart a AEK II this weekend and harvesting the switches and keycaps.   I can make some measurements if anyone is doing a design.   Unfortunately with work being as hectic as it is, I probably won't have time to do the design myself in the next couple weeks.
Offline emdude
« Reply #31 on: Mon, 02 May 2016, 23:07:04 »
For the sake of expediency, I feel it would be better to license JDCarpe's plate designs, unless somebody has already drawn up a design! :P
« Last Edit: Mon, 02 May 2016, 23:19:41 by emdude »
Offline Luneth
« Reply #32 on: Tue, 03 May 2016, 01:04:04 »
I would be in for an AEKII plate. Got in on Hasu's most recent PCB round, so I need to plate for it  :p
Offline emdude
« Reply #33 on: Sun, 08 May 2016, 00:27:39 »
Perhaps this is still too soon, but any updates? :o
Offline phoible
« Reply #34 on: Sun, 08 May 2016, 01:11:55 »
I'm working on getting some quotes on producing the plates locally. One place got back to me, but their prices are going to be significantly higher than the ALPS party GB. I'm supposed to chat with another place on Monday to get pricing from them. Will post here when I have more information.
Offline emdude
« Reply #35 on: Sun, 08 May 2016, 01:18:25 »
Okay, thanks for the update and best of luck with your negotiations!  :)
Offline need
« Reply #36 on: Sun, 08 May 2016, 04:09:52 »
Good luck man, we are very thankful for what you're embarking upon!
Offline infodroid
« Reply #37 on: Wed, 11 May 2016, 17:34:04 »
I'm definitely down for at least one of each, AEKII and AT101 and AT101W  :thumb:
Are you considering any fancy options like powder coating?
« Last Edit: Wed, 11 May 2016, 18:13:15 by infodroid »
Offline emdude
« Reply #38 on: Wed, 18 May 2016, 08:48:57 »
I'm wondering, have you consulted places that do laser cutting?  BlueNalgene's Alps Party plates were cut that way and it may be cheaper.
Offline kiwi99
« Reply #39 on: Wed, 18 May 2016, 22:19:50 »
textured black powder coating looks dope imo, heres my AEK II plate I did.
Offline murkey
    • murkey's alpaca farm
« Reply #40 on: Wed, 18 May 2016, 23:32:53 »
I'd be down for a PCB and 1-2 plates!
Offline tintoret
« Reply #41 on: Thu, 19 May 2016, 09:27:16 »
That looks great. And it would probably go well with anything in terms of case or cap colors.
I really hope this GB runs in time for the build I'm doing this summer.
Offline need
« Reply #42 on: Thu, 19 May 2016, 10:06:55 »
dude there won't be any PCB.
Offline murkey
« Reply #43 on: Thu, 19 May 2016, 10:45:59 »
OP mentioned it as a possibility and I want one, so I'm showing my interest. Thanks for your reply.
Offline Radlife
« Reply #44 on: Thu, 19 May 2016, 11:03:52 »
[/quote]
[/quote]
Also showing interest for a pcb and 2 plates  :thumb:
Offline need
« Reply #45 on: Thu, 19 May 2016, 11:11:19 »
oh sorry, just noticed that...you're right
Offline murkey
« Reply #46 on: Thu, 19 May 2016, 11:24:21 »
No worries! If the PCB doesn't work out I hope someone can help me find one. Or give me some tips for hand-wiring :eek:
Offline emdude
« Reply #47 on: Thu, 19 May 2016, 11:27:12 »
The issue with PCBs is that Hasu just finished his current Alps64 run so he may not have any more.
Offline need
« Reply #48 on: Thu, 19 May 2016, 11:32:46 »
Yeah, I guess you could try to pm hasu to see whether he's ordered extras.
Offline phoible
« Reply #49 on: Mon, 23 May 2016, 21:09:34 »
Just to provide an update. I contacted a couple of local waterjet cutting places, and it's going to cost significantly more to have the plates cut here than the last ALPS Party GB. That's one of the downsides of living in San Francisco.
I'm going to see whether I can find someone who isn't local to do the cutting for less money.
