Author Topic: Where to buy correct sized SIP sockets  (Read 2226 times)
Offline biocalves
« on: Wed, 04 May 2016, 11:56:34 »
Hi, I plan on SIP modding all of my newer boards (Ergodox Infinity first as that's coming in early next week) I pick up but was wondering where to get the ones that are long stemmed and low profile that won't cause me headaches during installation.
I know Zeal sells them but I'm looking for them still in their plastic housing and want to buy in relative bulk.
Any help would be appreciated. Thanks!
Offline biocalves
Re: Where to buy correct sized SIP sockets
« Reply #3 on: Wed, 04 May 2016, 17:57:06 »
Thanks guys, I stumbled around and ordered a couple hundred for less than $10. Let's see how well they work when they come in a couple of weeks.
Offline xyverz
« Reply #4 on: Fri, 27 May 2016, 12:40:48 »
Where'd you find 'em?
Offline biocalves
« Reply #5 on: Fri, 27 May 2016, 12:45:00 »
I found a buy link on Walmart for $6 and ordered it, which turned out to be straight pins, and I went back to check and turns out I misread the sale, so that was on me.
I did end up ordering from aliexpress for $11. I ordered not too long ago so I have yet to receive them.
http://www.aliexpress.com/item/Wholesales-DIY-200-pcs-lot-240pcs-lot-Crystal-Base-Long-Pin-Hot-Plug-Hot-Swap-For/32622320922.html?aff_platform=aaf&sk=jqfiaUZja%3A&cpt=1464370977443&af=1000225000000000242022015&cn=aliexpress&cv=banner&dp=19TZ1IKvjzZ9qq7&&aff_trace_key=138a45fcbd0c45449fc3293df629ebd3-1464370977443-09568-jqfiaUZja
