Author Topic: MagicForce 68 With Outemu Black Switches Quick/Mini Review  (Read 12212 times)
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« on: Wed, 04 May 2016, 15:24:45 »
This is a short quick sweet review to which i will be doing a full one on Youtube in the near future.  Bit behind on my Video reviews due to the wife being fairly ill as of late and looking after her. Ordered the MagicForce 68 With Outemu Black Switches from Amazon for 40$ US.
First Shot Keyboard in the box untouched.
136185-0
Second Shot Keyboard Box opened,Some unexpected accessories here....Hmm
 136187-1
Included a White rubber USB cable and a plastic cheapo Keycap puller along with an OTG cable...not bad.  Good thing i have the lightning adapter i need however.
136189-2
The keyboard all by itself in it's budget glory
136191-3
So all that photo glory aside now what do i think of the keyboard?
Pros: Outemu Blacks feel fantastic!  Smooth heavy but not intolerably so, really solid feeling.  Would never take over my Topre but may use this over my Pok3r if it works with my iPad.
Price!!!  40$ US!?  Is this real life?  With a variety of switches available at this price from Outemu Black,Brown,Blues all on Amazon.  Pricier options available with Backlightning and or CHerry switches are out there.  I even saw a backlit Cherry MX Green and a Backlit CHerry MX White option out there.
The Keycap printing method isn't the greatest but they are fairly thick for Stock ABS and definitely are better feeling than some of the other keycaps i have seen stock on MUCH more expensive boards (KUL ...cough KUL)
Fantastic rubber feet keep this keyboard in place without moving which is a huge plus, not even my HHKB Gets this right at more than 5X the cost of this board.
Included USB cable is not overly stiff and easy to bend in any direction
Cable routing system works well and stays in place without issue
Built in Function level Volume controls and media controls
CONS:  Stabilized keys are VERY rattly and sound worse than an unmodded Novatouch does by far.  The Enter key and Right shift and Spacebar being the worst of the bunch.
No dip switches on cheaper non backlit model
Odd choice of Del/INS/PgUP/PgDN four key cluster on upper right corner, would have preferred elimination of these and arrow cluster moved to the left for a smaller form factor overall.
Bearing in mind the price of the board i would have to say this is THE budget pick right now and unless someone needs a TKL i would feel very comfortable recommending it over a QFR as a fantastic starter board or travel board....or if you are like me just another board to add to the pile :p
Among it's price point i would give the board an 8.5 out of 10 knocking it down for the noisy stabilized keys and just weird choices of extra keys for that 4 key cluster on the top right wasting space.  Asides from that what more could you ask for 40$?
BONUS INFO:  Just tested and confirmed this works on my iPad with the lightning to USB camera adapter!  I would be willing to bet the backlit models however do not work.
« Last Edit: Wed, 04 May 2016, 15:37:42 by LiquidEvilGaming »
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline Leslieann
Re: MagicForce 68 With Outemu Black Switches Quick/Mini Review
« Reply #1 on: Wed, 04 May 2016, 16:55:21 »
I completely agree, it's not perfect, but what a bargain and great portable keyboard these are, certainly the best deal going.
Something worth noting, these use standard keycaps and I'm sure a bit of grease on the stabs would quiet them down (something I should do myself).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline phantasma
« Reply #2 on: Thu, 05 May 2016, 15:31:21 »
Thanks for your review. How does they switch feel? Is it similar to Cherry Mx Black?
« Reply #3 on: Thu, 05 May 2016, 17:45:20 »
I only have a Cherry MX Black switch tester to compare but it feels slightly heavier?  If you'd like i can test it with nickels and report back Actuation force on my own board.
« Reply #4 on: Thu, 05 May 2016, 18:48:19 »
While i am glad i decided to order one of these as it's a nice fun little board think i may sell this one and order another with Brown switches as the Blacks are getting insanely tiring with extended use.  Literally can feel the pain building in my arm right now as i type this out.
Offline Leslieann
« Reply #5 on: Thu, 05 May 2016, 19:01:41 »
That happened to me after running Blues and trying to go back to a Model M.
Eventually you adapt, but if you type a lot, it can be tiring getting there.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #6 on: Thu, 05 May 2016, 19:21:41 »
Possibly but these seem a bit heavier than Cherry Blacks as it is and those are a bit heavy as it is.  It's really nice when gaming i'll say that but for extended typing it's a bit uncomfortable.  Definitely far more tiring than my MX Blues pok3r is by a long shot.
Offline phantasma
« Reply #7 on: Fri, 06 May 2016, 11:37:25 »
Yes, this is what I've read from reviews. I think this is true for every Outemu switch (it feels a bit heavier than it's Cherry mx equivalent), which is not bad thing for the lighter switches, but in case of Black, it can be a bit too much.
« Reply #8 on: Fri, 06 May 2016, 14:11:17 »
Yeah as i had read from someone else i think describing them as super blacks is fairly accurate.
