Author Topic: [IC] 40% custom keyboard with full-size space bar  (Read 6697 times)
Offline liftylol
« on: Sat, 14 May 2016, 15:11:45 »
Hey guys, first time posting on here~
I designed a 40% keyboard and already have my first pcbs here and i got kind of a good feedback on /r/mk so i thought i'd show you guys :)
The layout i'll be using is this one, just so you get an idea:
Yesterday i soldered the diodes, the switches and the teensy to my board and i think that's a good point to show my project :> I'll make a sandwich case in the next few days, i have 3mm thick acrylic glass for a top and bottom plate here and i'll mill it myself.
Here are the pictures:
http://imgur.com/a/zx8nw
Please tell me if this layout would interest you or not and why! Thanks a ton!
Edit: Everything finished!
http://imgur.com/a/hmgfi
« Last Edit: Mon, 16 May 2016, 06:46:25 by liftylol »
Offline tuco
Re: [IC] 40% custom keyboard with full-size space bar
« Reply #1 on: Sat, 14 May 2016, 15:38:47 »
Looks awesome!
Offline LunarisDream
« Reply #2 on: Sun, 15 May 2016, 08:26:28 »
Looks good! I question the functionality of a full-size spacebar on a keyboard that's literally less than half the usual size, though.
Offline rondg
« Reply #3 on: Mon, 16 May 2016, 03:57:50 »
Looks great! But wouldn't it be better to have options on the spacebar row? Maybe support for multiple layouts.
I'm still interested though..  ;D
Offline liftylol
« Reply #4 on: Mon, 16 May 2016, 06:47:17 »
Updated the original post with my first finished version!
Offline punkpc
« Reply #5 on: Tue, 14 June 2016, 15:22:36 »
This looks pretty good. How much you thinking one of these is going to run for?
