Author Topic: TKL Cherry MX Clear Keyboard Recommendation  (Read 2942 times)
Offline Amarok
« on: Tue, 17 May 2016, 09:55:31 »
I'm trying to find a TKL cherry mx clear keyboard for the set of PBT caps I ordered from the group buy. I've been using a Realforce for the past couple years and wanted to change it up.
So far I'm kind of looking between the KUL ES-87 on Elitekeyboards and the V2 from WASD. Does anyone have any recommendations for other options or have any opinions on which is better?
Realforce 87u 55g
Offline daerid
    • Rossipedia
Re: TKL Cherry MX Clear Keyboard Recommendation
« Reply #1 on: Tue, 17 May 2016, 14:23:12 »
TBH, those were the only two I'd suggest. I haven't personally owned the KUL, but it's very highly regarded.
I have 4 WASD V2 boards, two of them with Clears (my fav MX switch). You can't go wrong with one of those.
Offline Saiph
« Reply #2 on: Tue, 17 May 2016, 14:24:15 »
There's also the Code V2, which is just a WASD V2 with white LEDs.
Offline daerid
    • Rossipedia
« Reply #3 on: Tue, 17 May 2016, 14:28:23 »
Those would be the
Those would be the 2 wasd w/ clears I have. They also have a white plate (vs the black of the regular V2).
Offline Tactile
« Reply #4 on: Tue, 17 May 2016, 14:37:12 »
Another vote for WASD. They have the LEDs in the case instead of under the keycaps. They have some nice controller/dip switch options:
Turn the caps lock into a control key (not swapping the left control & caps lock, but just turning the caps lock into control)
Permanently disable the windows key
Turn the scroll lock into a win key toggle
I also like the sterile, unbranded look. The build quality seems very good, also. And, if you have your own keycaps, you can buy a "barebones" keyboard & save a few bucks.
REΛLFORCE
Offline daerid
    • Rossipedia
« Reply #5 on: Tue, 17 May 2016, 14:49:01 »
This. Such an amazing option, saves usually like $50
Offline Amarok
« Reply #6 on: Tue, 17 May 2016, 14:53:02 »
Okay cool, I think I'll do the WASD V2 then. I owned a WASD years ago before the V2 came out and I remember liking it, aside from the big rounded front edge of the case but it looks like that's been changed in the V2.
Thanks guys.
Realforce 87u 55g
Offline ThoughtArtist
« Reply #7 on: Tue, 17 May 2016, 18:54:05 »
Get a LeoKul. Thank me later.
Leopold PBT Caps and Kul ES-87 with Clears. Total end-game.
« Last Edit: Tue, 17 May 2016, 19:10:33 by ThoughtArtist »
Offline Amarok
« Reply #8 on: Tue, 17 May 2016, 19:12:13 »
Already ordered an EnjoyPBT set from the group buy extras!
Realforce 87u 55g
« Reply #9 on: Tue, 17 May 2016, 19:14:06 »
That's fine, but seriously, these two together are like the Glock of keyboards to me.
