Author Topic: Novatouch escape key not working.  (Read 2213 times)
Offline chamton
« on: Sun, 22 May 2016, 15:10:03 »
Hello, I'm new here. As my first mechanical keyboard, I bought a Novatouch TKL. It's been great. However the escape key recently stopped working (luckily, I'm an emacs user). I've checked and it's definitely a hardware thing.
Is this something that I can easily fix myself by ordering a part online, or should I send this to a service center?
Thanks.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Novatouch escape key not working.
« Reply #1 on: Sun, 22 May 2016, 15:34:20 »
Thanks.
Definitely get it checked out if you're still under warranty for it. If you don't want to open it and poke around I would send off and let the technicians poke around.
Offline need
« Reply #2 on: Sun, 22 May 2016, 15:52:56 »
Give it to me, it's that simple.
Offline jcoffin1981
« Reply #3 on: Mon, 23 May 2016, 14:05:48 »
You can download a program like EK Switch Hitter and then try pressing the switch with varying amounts of force and at different points on they keycap.  I would say take it apart and see if there is any debris and that all the parts are intact.  But if this is a new board or you are unsure of you you may just be better off taking advantage of the warranty
« Reply #4 on: Tue, 24 May 2016, 06:04:40 »
Welcome to Geekhack!
Definitely investigate the warranty option if it is still covered BEFORE you open it.
