Author Topic: Custom Split Grid Keyboard Buildlog [NOW RGB]  (Read 8018 times)
Offline spwath
« on: Fri, 27 May 2016, 17:18:23 »
Come with my on my journey of building my custom split keyboard.
Parts:
Custom plates
Purple Zealios
Granite DSA keycaps
2x teensys
Total price~ $300
Keycaps arrived, and show the layout that the keyboard will be
138237-0
Plates arived, and I started to put zealios in. One thing, the left plates holes are too big, I will have to have it remade
138239-1
Put all switches and keycaps onto the right plate
138241-2
Started to wire top plate
138243-3
More coming soon
« Last Edit: Sun, 28 August 2016, 14:46:27 by spwath »
Offline zefyr
  • Oddforge
Re: Custom Split Grid Keyboard Buildlog
« Reply #1 on: Tue, 31 May 2016, 01:49:57 »
Awesome!
How about produce "switch traces only" PCB?
My first PCB has no diodes or ICs at all, just for switch traces.
It's pretty much simple, not too easy.
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline spwath
« Reply #2 on: Tue, 31 May 2016, 05:19:37 »
Awesome!
Hmm, i havent looked into PCB's at all.
Ill just hand wire this one, but if i ever build a new keyboard, i might look into a PCB
Oh cool, you are behind the VEA keyboard. Its really cool, I would get one, but im doing this keyboard. I love split keyboards ever since I got an Apple Adjustable keyboard.
« Last Edit: Tue, 31 May 2016, 09:18:36 by spwath »
Offline spwath
« Reply #3 on: Tue, 28 June 2016, 17:52:24 »
Did some more soldering, and got my other plate. I can see what the final layout will be and test it.
WOw thoes granite keycaps are sexy.
140937-0
Next to my Apple Adjustable Keyboard
140939-1
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #4 on: Wed, 29 June 2016, 03:50:37 »
Very interesting use of the ISO enter for the spacebars!
Offline spwath
« Reply #5 on: Wed, 29 June 2016, 08:03:31 »
Yeah, seemed like best option to have a bigger space bar. Not sure if there are really any readily avalible bigger keys
Offline spwath
« Reply #6 on: Sat, 27 August 2016, 22:21:11 »
Another update.
Made some wood stuffs.
Think ill make my wrist wrest smaller....
Offline spwath
Re: Custom Split Grid Keyboard Buildlog [NOW RGB]
« Reply #7 on: Sun, 28 August 2016, 14:47:07 »
This is new
Offline spwath
« Reply #8 on: Sun, 28 August 2016, 15:18:37 »
Offline SBJ
  • Tactile pls
« Reply #9 on: Mon, 29 August 2016, 03:39:20 »
Bling bling, baby. :D
Offline zefyr
  • Oddforge
« Reply #10 on: Thu, 08 September 2016, 00:03:29 »
B.E.A.U.T.I.F.U.L!
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #11 on: Thu, 08 September 2016, 13:31:31 »
Really love the look of this, something spartan and really attractive about it, great job.
Kindof a rookie question here but I see you and Zefyr talking about PCBs and see that you are not using one for this build, I didn't know you could create a keyboard without one, are you just daisy-chain soldering the switches to each other to a USB port and then letting whatever you plug it into handle the software side of the keyboard?
Edit: Here's the problem with being new to the community, I don't always know where all the resources are to answer my own questions, haha, I think I just found a few tutorials that might answer my above question, but any insight you guys have would be appreciated!!
« Last Edit: Thu, 08 September 2016, 14:03:32 by dead_pixel_design »
Offline zefyr
  • Oddforge
« Reply #12 on: Mon, 26 September 2016, 01:02:25 »
I believe he is using external controller like Arduino or Teensy :)
Those controllers have lots of software resources out there on public.
And here's one keyboard dedicated external controller made by winkeyless.
http://winkeyless.com/product/u-con-pcb/
This need some additional effort to use RGB otherwise it is pretty easy to build custom keyboard.
I used it with my early designs.
« Last Edit: Mon, 26 September 2016, 01:05:33 by zefyr »
Offline spwath
« Reply #13 on: Sun, 16 July 2017, 12:20:44 »
Do you know if I can buy that in the US?
I'm having some troubles with Teensy.
