Author Topic: Send from my Xxxx phone and the Talktalk application  (Read 13389 times)
Offline Eugene45
« on: Mon, 30 May 2016, 12:00:15 »
Hello, is there a way to just ban the " advertisement " from all the application who are more and more used ?
Or maybe just create a basic tutorial PM to send to the the people so that they can disable this spam.
Its annoying.
Thanks
lmao, cut the French some slack, they gave you a big statue
Offline KatzenKinder
Re: Send from my Xxxx phone and the Talktalk application
« Reply #1 on: Mon, 30 May 2016, 12:31:41 »
Yes
Offline WNovizar
« Reply #2 on: Mon, 30 May 2016, 21:07:16 »
Xxxx phone sounds lewd
Sent from my E5563 using Tapatalk
I like mechanical keyboards
« Reply #3 on: Mon, 30 May 2016, 21:47:11 »
It's the default Tapatalk post signature.  Most people are quite relieved when they find out how to disable it.
It would be nice if Tapatalk would not do it, but I guess it's their prerogative to advertise their own product.
Sent from my iMac using Firefox
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #4 on: Mon, 30 May 2016, 21:53:02 »
It's so weird reading it in a notification.
« Reply #5 on: Mon, 30 May 2016, 21:56:42 »
almost as annoying when viewing hoffman's photos from flickr on gh ^^
Offline appleonama
  • Trollo en USA
« Reply #6 on: Mon, 30 May 2016, 21:57:06 »
What is the issue here?
Sent from my MacbookPro using Opera
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #7 on: Mon, 30 May 2016, 22:00:43 »
But can you send it from a Brita filter?
« Reply #8 on: Mon, 30 May 2016, 22:11:13 »
yes
Sent from my Brita™ filter
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #9 on: Mon, 30 May 2016, 22:16:45 »
yes
But where that Flickr link?
Sent from my shower head
« Reply #10 on: Mon, 30 May 2016, 22:18:04 »
Xxxx
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #11 on: Tue, 31 May 2016, 00:09:58 »
To be fair there aren't that many people who do it, but I agree it is a bit annoying.
Sent from my ****ty thin client at work using IE11
« Reply #12 on: Sun, 19 June 2016, 00:55:42 »
It is a little annoying, but I also think some people put it in just to annoy.
Sent from my Apple Newton MessagePad 2100 using IR
« Reply #13 on: Sun, 19 June 2016, 01:56:21 »
I've seen that.  Hopefully the practice will die down soon, but I'm usually so far behind posts these days that I just skip over them while quickly scanning the threads.
Offline Belfong
« Reply #14 on: Sun, 19 June 2016, 03:35:15 »
I don't get it. I thought you can disable signature?
« Reply #15 on: Sun, 19 June 2016, 06:15:17 »
You can, but it is enabled by default.
Not everyone knows it can be disabled.
And some people are manually typing a fake signature under their posts for some reason.
