Author Topic: Cap Lock LED on custom keyboard  (Read 4125 times)
Offline greenwhite
« on: Tue, 07 June 2016, 18:55:26 »
I want to have an indicator light for Caps Lock on my keyboard.  Do I connect the LED directly into the Teensy that I am using?  If so, do I have to connect each of the LED connectors to a separate pins?
Re: Cap Lock LED on custom keyboard
« Reply #1 on: Wed, 08 June 2016, 02:29:37 »
You also need a resistor - follow any Arduino plus LED tutorial, keyboards are not special electronically :)
« Reply #2 on: Wed, 08 June 2016, 12:23:37 »
Yea, I've always wanted my modifiers to have leds that behave with led momentarily on key down anyone have a quick tutorial?
Sent from my SM-G900T using Tapatalk
Offline QuincyJones
« Reply #3 on: Tue, 14 June 2016, 05:36:02 »
Would you need those crazily small LED's that are smaller than a grain of rice? "chip scale package" or whatever they're called?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline Data
« Reply #4 on: Tue, 14 June 2016, 06:37:38 »
It's a custom so there should be a place to mount a 5mm or 2x3x4 LED in/on the switch, even if the PCB isn't cut for through-hole components.  It's just trickier to wire that way.
