Author Topic: Restoring an OG HHKB Lite (It's done!)  (Read 5918 times)
Offline streetwizzur
  • ok
« on: Fri, 10 June 2016, 17:40:59 »
Okay so I bought this nasty ass  HHKB lite from ebay for 50 US smackers.
It looks like someone tried to eat it or something
Here are the guts
Pretty hefty domes
PCB/plate and daughterboard
Those jerks over at PFU put a screw under the dip switch table.
SO I started by tearing it down. Then I wet sanded all the mangled edges and scrubbed all the stickers off. I also cleaned all the caps.
Now it looks like this.
Since I had to mess up a sticker, I made a new one in illustrator, with a couple personal touches. (Aka a logo and a character that I put on stickers)
What I need help with is converting it to usb with hasu's converter (or something similar.)
Here is whats goin on inside this thing, the pin connector on the right is for ground, power (v?), clock and data
and here's what I made with a teensy pulled from a failed project
The pins are connected to what hasu said to use in this this thread: https://geekhack.org/index.php?topic=14618.0
Do I need to connect the plate to the teensy in some way to get it to work? Unless I have the firmware wrong. I don't really know much of anything when it comes to tmk.
AKA what do i need to do to make a usb cord come out of this thing
« Last Edit: Fri, 10 June 2016, 22:56:58 by streetwizzur »
  • ok
Re: Restoring an OG HHKB Lite (Need help with conversion!)
« Reply #1 on: Fri, 10 June 2016, 17:46:12 »
Also, from the ebay listing
Offline livingspeedbump
    • KeyChatter
« Reply #2 on: Fri, 10 June 2016, 20:53:10 »
Haha love the pic  :thumb:
So to make sure I'm up to speed where you are, did you cut the original cable to attach to the teensy or did you get another clip? and have you flashed the controller yet or not?
The MAIN point is not to swap up the cables, you definitely dont wanna mix up the power cable, and it looks like you are good in that regard.
<- My Collection (so far)
  • ok
« Reply #3 on: Fri, 10 June 2016, 21:19:42 »
I didn't cut anything. I made a new clip with a 4 pin connector from an old power supply and wired the G,V,C and D to the pins on the teensy that hasu said too
I did flash the default ps2_usb firmware to the teensy. Do I need to ground the plate to the teensy? My intention is to have the teensy replace the cable and then put it inside the hhkb.
    • KeyChatter
« Reply #4 on: Fri, 10 June 2016, 21:45:47 »
Gotcha, that's good. Always a good idea not to cut original cables  :thumb:
So you have flashed his firmware and nothing is happening when you plug it in?
  • ok
« Reply #5 on: Fri, 10 June 2016, 21:50:45 »
It's being read as a keyboard in device manager, but yeah nothing works.
« Last Edit: Fri, 10 June 2016, 21:53:00 by streetwizzur »
  • ok
aa
« Reply #6 on: Fri, 10 June 2016, 22:26:37 »
Okay so I just used soarers firmware and it worked fine, I just gotta clean it up now!
EDIT:
yeeeeeee
« Last Edit: Fri, 10 June 2016, 22:54:38 by streetwizzur »
Offline funderburker
Re: Restoring an OG HHKB Lite (It's done!)
« Reply #7 on: Sat, 11 June 2016, 04:13:15 »
Damn, boi! You did a wonderful job on this one. Since the "In the mail" thread started looking for OG Lite but they're hard to find. How is it in the "feels" department?
Keyboard design by Skepur
    • KeyChatter
« Reply #8 on: Sat, 11 June 2016, 10:21:13 »
i wake up and you have it working, excellent!!!
I'll say I enjoyed the Lite I had like yours more than the OG HHKB. It actually is a pretty decent little keyboard  :thumb:
  • ok
« Reply #9 on: Sat, 11 June 2016, 11:39:17 »
It feels like a nice rubber dome, it's pretty loud though. Very snappy up-stroke. I was about to drop a 100 bux on an og hhkb but then I found this, I'm glad I did.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #10 on: Sat, 11 June 2016, 13:14:40 »
Nice job, the old rubber dome hhkbs are cool but by no means should warrant a $100 price tag. Now get a pro 😎
ps your avatar is triggering me
  • ok
« Reply #11 on: Sat, 11 June 2016, 14:04:56 »
I have a pro 2 (I like the usb hub  :eek:)
edups
