Author Topic: Recommendations for numberpad?  (Read 3470 times)
Offline shadowku
« on: Wed, 22 June 2016, 21:40:18 »
I want to get a numberpad but I'm not sure which I should get. Any recommendations? I'm considering the Filco number pad to match my Filco TKL.
HHKB Pro2      FC660C
Offline Rad
Re: Recommendations for numberpad?
« Reply #1 on: Wed, 22 June 2016, 22:04:08 »
You answered your own question!
Offline 1391406
« Reply #2 on: Wed, 22 June 2016, 22:38:25 »
Sounds like a perfectly reasonable choice.
Offline shadowku
« Reply #3 on: Wed, 22 June 2016, 22:39:53 »
Yeah but it's the only one I've considered.
The Realforce one seems a tad expensive for what it is.
I guess there really aren't many on the market.
HHKB Pro2      FC660C
Offline 1391406
« Reply #4 on: Wed, 22 June 2016, 23:17:07 »
« Last Edit: Thu, 23 June 2016, 02:08:40 by 1391406 »
Offline 1391406
« Reply #5 on: Wed, 22 June 2016, 23:19:08 »
I don't know where to find the ADESSO at the moment.
Offline Macsmasher
« Reply #6 on: Thu, 23 June 2016, 19:21:44 »
I have the RF 23U and really like it. Yes, it's on the expensive side. If you're an accountant living on your numpad, definitely worth it. I don't use mine that much, but still happy I bought it. I had an Adesso before the 23U that I returned. Didn't like the layout. Note the position of the -, +, =, / keys does vary by manufacturer. Numpads are not standardized like keyboards, so check that out before you buy.
Here's a review comparing the 23U and a Filco. He's the most boring guy you'll ever listen to and you'll want to beat him with a bat before it's over. But at least listen from 5:15 where he talks about n-key rollover. And then hit him with a bat.
Offline Data
« Reply #7 on: Thu, 23 June 2016, 19:23:05 »
+1 vote for Leopold
The newest versions output actual, legitimate numpad scan codes.  Don't let anyone tell you different.
Offline Macsmasher
« Reply #8 on: Thu, 23 June 2016, 20:17:53 »
+1 vote for Leopold
Good to know. Just a year ago, that wasn't the case.
Offline 1391406
« Reply #9 on: Thu, 23 June 2016, 20:29:37 »
I bought an RF 23U to go with an RF 87U and yes, it's expensive, but the quality is second to none. I wouldn't have any reservations about buying a Filco numpad, though.
Offline shadowku
« Reply #10 on: Thu, 23 June 2016, 23:22:18 »
Since I'm looking to get an FC660(C/M) soon the Leopold doesn't sound like a bad idea. I really and probably don't need a numberpad however. I'm a software engineer so I'd only need one when tweaking algorithms or graphics which isn't often enough for the need to spend this much money on it. But with that sentiment I shouldn't be looking at keyboards and keycaps to begin with =P
HHKB Pro2      FC660C
Offline 1391406
« Reply #11 on: Thu, 23 June 2016, 23:42:06 »
There are a lot of cheap number pads to choose from on Amazon.
Offline SKD
« Reply #12 on: Fri, 24 June 2016, 04:36:35 »
I have one of those Jelly Comb numpads some people have recommended. It outputs proper numpad codes and it only cost me £17. It's not the nicest looking thing and it has an odd layout but it's not bad for it's price I guess. I'm in the middle of swapping out the outemu blues to cherry reds at the moment and it has an odd set of caps on it lol.
https://www.amazon.co.uk/Mechanical-Numeric-Jelly-Comb-Braided/dp/B01EFR5KDA/ref=lp_5772308031_1_4?srs=5772308031&ie=UTF8&qid=1466760895&sr=8-4
Offline Data
« Reply #13 on: Fri, 24 June 2016, 09:25:18 »
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1711
$59 really isn't that expensive.
Offline RobotMalcolmX
  • hackerman
« Reply #14 on: Fri, 24 June 2016, 09:55:05 »
You can hold out and get a Ducky Pocket too, if that was interesting to you. Odds are it'll be a bit before it's available though.
Offline QuincyJones
« Reply #15 on: Fri, 24 June 2016, 12:05:02 »
buy one of those cheapo $2 things, then gut it and put in whatever you want - the hardest part - the case - is solved for you
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline 1391406
« Reply #16 on: Fri, 24 June 2016, 12:58:06 »
You don't need a case.
« Reply #17 on: Fri, 24 June 2016, 13:04:38 »
I'm waiting for that new Ducky numpad/calculator to drop. Should be a good time :D.
Offline 1391406
« Reply #18 on: Mon, 27 June 2016, 01:54:46 »
