Author Topic: Fixing sheared keyswitches on a G81-3000  (Read 3024 times)
Offline sethstorm
« on: Sun, 03 January 2010, 14:16:01 »
On the lower left of this keyboard, I've got 2 Cherry MY switches with the top cross part on the top sheared off and embedded into the keycaps.  The problem is that I don't see a lot of Cherry MY switches being sold to do any sort of direct swap(MY for MY), despite the ease in replacing them.
What would be the best option to do in fixing this?  The keycaps don't seem to have an easy way to remove the white plastic top; I would be open to fixing those with new switches.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline ricercar
  • mostly abides
« Reply #1 on: Sun, 03 January 2010, 14:35:24 »
PM me your mailing address and I'll send you three MY keys from one of my bad boards.
Offline sethstorm
« Reply #2 on: Sun, 03 January 2010, 14:45:49 »
Quote from: ripster;147579
Bummer.  I threw mine away after harvesting double shot keys or I'd  send you one.  Looks like you can just pop them off.
That's what I was thinking.
Yes, I saw that site, but my thought was to see about replacing those with another Cherry switch that would fit (MX?).
This board appears to have double-shot keys; it also helps that it's slightly more pleasing to look at that logo versus the Cherry one.  I'm not going to trash this one just for those 2 bad keys or have it go as a donor.
Update: I do have a source for the switches, thanks going to Ricercar.
« Last Edit: Sun, 03 January 2010, 15:13:52 by sethstorm »
Current:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Sun, 03 January 2010, 19:41:53 »
Depending on the situation, you might be able to super-glue the keycaps back on.
Offline itlnstln
« Reply #4 on: Mon, 04 January 2010, 10:48:40 »
Quote from: microsoft windows;147683
+1.  I would think that if you used a strong enough glue, you could even get the keycaps back off.
Offline itlnstln
« Reply #5 on: Mon, 04 January 2010, 11:02:47 »
He's still out 2 caps unless enough of the stem sheared off that he could pull the stem out of the cap.
Offline sethstorm
« Reply #6 on: Mon, 04 January 2010, 11:47:36 »
Quote from: itlnstln;147810
Quote from: ripster;147815
That's easy.  Drive a tiny screw into broken stem in key.  Pull.
If you have a problem getting a starter hole drive a hot needle into the plastic.
I got the switches out all right, but the stems are indeed embedded in the keycap.  I sheared about the whole cross part of the stem on both.
I'm just hoping the far end of the keycap is enough space to just stack bad stem on working stem + switch.  Otherwise you're right about being out two keycaps as well.
« Last Edit: Mon, 04 January 2010, 11:50:53 by sethstorm »
Current:
Offline itlnstln
« Reply #7 on: Mon, 04 January 2010, 11:52:56 »
What?
Offline ricercar
  • mostly abides
« Reply #8 on: Mon, 04 January 2010, 15:12:53 »
Is rip posting again? I have him blocked.
Offline itlnstln
« Reply #9 on: Mon, 04 January 2010, 15:44:17 »
Huh?
