Author Topic: Interesting Layouts  (Read 501712 times)
Offline regack
Re: Interesting Layouts
« Reply #100 on: Sun, 04 September 2016, 20:33:23 »
Edit: I renamed them Space Control
'opposites feature'
When my '30% experiment' is finished this might be its (final) successor.
2 more but I don't think I like them as much
So you're mostly playing with different bottom row configurations?  Programming the different layers/keys will probably come from usage, but figuring out where you want your fingers to be, yes, that's harder.
Offline Dwarlorf
« Reply #101 on: Mon, 05 September 2016, 03:31:52 »
'opposites feature'
Yeah, that's right. I try to imagine which button configuration is best suited but in the end practical usage will tell. When I'm ready to make these I'll just make 2 plates and experiment.
E5XKBP10140                 GH60 Iso/Ansi hybrid, cherry mx red
Offline Phenix
« Reply #102 on: Fri, 09 September 2016, 10:39:24 »
Is the 59% keyboard handwired? Looks like a really neat idea!
Winter is coming.
Offline regack
« Reply #103 on: Fri, 09 September 2016, 12:53:25 »
I made a PCB for it, but it could certainly be handwired instead.  I have it posted up on github.
Offline Dwarlorf
« Reply #104 on: Sat, 17 September 2016, 17:11:48 »
This could be very close to my final design. It has actually turned into a 25% (26 keys)
148602-0
« Last Edit: Sat, 17 September 2016, 17:14:22 by Dwarlorf »
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #105 on: Sun, 02 October 2016, 09:37:25 »
Projects
« Reply #106 on: Sun, 02 October 2016, 10:05:29 »
I just really want a TKL but without the 3 columns to the right.
So 75% but with proper F-row spacing to play starcraft and no extra column for pageup/pagedown and all those keys.
I call it 69%, been meaning to build one for a while but I'd want to design a pcb for it and don't have the knowledge. I'll hit you up whenever I get around to it xD
Offline mrbishop
  • Evil Genius
« Reply #107 on: Sun, 02 October 2016, 10:11:34 »
Cool I look forward to it
sent from my chess board
Projects
Offline iFreilicht
« Reply #108 on: Wed, 05 October 2016, 18:02:03 »
Interesting numpad on the 40 long !
And here is my try on the central numpads :
5x15 central numpad matrix
I like that idea, I'll try to make something like that with my Atomic. Right now my layout looks like this:
149813-0
Link.
I thought about making it "winkeyless", removing the bottom right and left keys, but I don't want to eliminate the options a full-grid layout otherwise gives me.
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
Offline dusan
« Reply #109 on: Thu, 06 October 2016, 08:14:01 »
I'm working on this layout.
Specification has been finished. However the function layers are subjected to change.
Implementation is underway.
The layout was presented here on GH a year ago. Keyword: "Plum matrix keyboard".
The idea was presented here on GH two years ago. Keyword: "RealMatrix as an alternative to TypeMatrix".
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
Offline mrbishop
  • Evil Genius
« Reply #110 on: Fri, 07 October 2016, 11:33:15 »
because i've been curious about the Ortho keyboards for awhile now.
Ortho 60 and variants.
149946-0
Projects
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #111 on: Fri, 07 October 2016, 19:45:32 »
I call it the switch180 :)
For when you want an 1800-ish look on a smaller board :p
Legends are just placeholders & the bottom is a split space layout frostytoast did.
Offline decker
« Reply #112 on: Sat, 08 October 2016, 01:24:50 »
If I shorten Backspace and add spaces, that reminds me of one of my layouts (with one extra column)...
40+N
Offline menuhin
« Reply #113 on: Sat, 08 October 2016, 12:03:51 »
Trying to come up with some sensible and HHKB friendly layouts on the Atomic keyboard layout.
Just realized that without 'staggering', our home placement of fingers are 1 row away from the edge for the left hand and 4 rows away from the edge for the right hand.
I tried to make the hand placement more centered on the first one.
This is a comfortable layout however can't be so HHKB, and sadly without the full arrow keys:
150133-0
This one has no attempt to center the hand placement.
This is more holistic but with some short modifier keys on the left and without the gap on the right bottom corner:
150135-1
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #114 on: Sat, 08 October 2016, 14:35:11 »
Yes.
Offline sypl
« Reply #115 on: Sun, 09 October 2016, 15:27:47 »
Where's the escape key...?
Offline iFreilicht
« Reply #116 on: Sun, 09 October 2016, 15:48:37 »
Hm, those 1.5u keys to the left and right just seem to be there for the sake of it, not a fan of those really. Except for the blue layout, all of them would work out perfectly fine with 1u side columns and I'd argue they'd look better, too.
What about using 1u shift on the right? Then you'd have enough space for a full arrow cluster.
That looks pretty damn cool, I'd love to see that being built!
Offline Zorberema
  • IG: @ZorbCaps
« Reply #117 on: Sun, 09 October 2016, 15:58:45 »
Something I've been working on for a while!
Basically kind of similar to a regular 60% but with arrowkeys, split space and some other rearangements. I implemented the arrows kind of similar to the 1800 just like switchnollie did with his ones. Tell me what you think! This is weird for sure, just made it for what I personally would like in a board, so fun to see what others think about it :)
Offline Moistgun
  • Slippery When Wet
« Reply #118 on: Sun, 09 October 2016, 16:01:16 »
Not the most revolutionary layout, but its great if you just want a popout fullsize add-on to your 60% board.
Great for in and out data entry.
Offline mrbishop
  • Evil Genius
« Reply #119 on: Sun, 09 October 2016, 16:02:07 »
I'm partial to this board
Projects
Offline Moistgun
  • Slippery When Wet
« Reply #120 on: Sun, 09 October 2016, 18:17:12 »
Case made by the one and only Mr Bishop
Offline mrbishop
  • Evil Genius
« Reply #121 on: Sun, 09 October 2016, 18:18:14 »
Mad scientist / evil genious extraordinaire
Projects
  • sleever supreme
  • greyhat co-leader
« Reply #122 on: Sun, 09 October 2016, 18:47:56 »
Wherever you want it :rolleyes:
Programmable ofc :)
Offline mrbishop
  • Evil Genius
« Reply #123 on: Mon, 10 October 2016, 15:48:45 »
i have an affinity for this.  :thumb:
Projects
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #124 on: Mon, 10 October 2016, 16:00:40 »
I like that it has exactly zero insert keys
Offline iFreilicht
« Reply #125 on: Mon, 10 October 2016, 16:23:51 »
Nice! My current board does the same thing, but I had to stay inside my 60% PCB, so my arrows are 1.25u wide (uparr is 1.75), which was irritating in the beginning, but it's easy to get used to.
Offline menuhin
« Reply #126 on: Tue, 11 October 2016, 05:46:23 »
Making the Shift key 1u will increase its mistype rate. That's why I try to introduce gaps at the bottom row for easier reaching of the modifier keys.
IBM M13 black
HHKB Pro 2 HasuBT
Offline menuhin
« Reply #127 on: Tue, 11 October 2016, 06:01:25 »
Yes, it reminds me of the TypeMatrix, and also the Maltron.
IBM M13 black
HHKB Pro 2 HasuBT
Offline dusan
« Reply #128 on: Tue, 11 October 2016, 15:58:22 »
The physical layout is somewhat similar to the Maltron. The logical layout isn't. It was inspired by the TypeMatrix. The key difference to the TypeMatrix is location of modifier keys (Ctrl, Shift, Alt) relatively to navigation keys (arrows, Home, End etc) and editation keys (Backspace, Delete, Undo etc).  Location of modifier keys is IMO the major issue in the TypeMatrix, compared to standard PC and laptop keyboards.
Another difference is the symmetry of the physical layout, making it possible to swap parts of the layout between left and right half. For example, if you use the mouse by the right hand, you may want to do all keyboard navigate-select-edit actions by the left hand. This is impossible in the TypeMatrix.
Finally the logical layout separates hands better than the TypeMatrix, given the same physical dimensions.
« Last Edit: Tue, 11 October 2016, 16:26:31 by dusan »
Offline Phenix
« Reply #129 on: Tue, 11 October 2016, 16:42:48 »
Will you design a PCB? I hope so, thats an beautiful layout (which will also fits my need)
Winter is coming.
Offline menuhin
« Reply #130 on: Wed, 12 October 2016, 03:14:29 »
It looks very similar to layout options 4, 5, or 6 on the White Fox Keyboard. Anyways, you can reprogram the keys on the White Fox:
IBM M13 black
HHKB Pro 2 HasuBT
Offline Dwarlorf
« Reply #131 on: Sun, 16 October 2016, 14:46:50 »
5 Way Hat keyboard
150572-0
D = Del
C = CTRL
T = TAB
E = Enter / FN2
The white buttons are 4-directional with center push.
« Last Edit: Sun, 16 October 2016, 14:48:49 by Dwarlorf »
Offline iFreilicht
« Reply #132 on: Sun, 16 October 2016, 14:52:33 »
5 Way Hat keyboard
D = Del
C = CTRL
T = TAB
E = Enter / FN2
How exactly would one activate the secondary/ternary/whatever functions of that board? Chording?
Offline Dwarlorf
« Reply #133 on: Sun, 16 October 2016, 15:00:40 »
5 Way Hat keyboard
D = Del
C = CTRL
T = TAB
E = Enter / FN2
Normal press = top left symbol
Long press  =  top right symbol
FN1 + normal press = bottom left symbol
FN1 + long press = bottom right symbol
FN2 + normal press = Front left symbol
FN2 + long press = Front right symbol
Concepts and partially prototyping
« Last Edit: Sun, 16 October 2016, 15:03:04 by Dwarlorf »
Offline menuhin
« Reply #134 on: Sun, 16 October 2016, 15:41:37 »
5 Way Hat keyboard
D = Del
C = CTRL
T = TAB
E = Enter / FN2
Someone placed a customizable number pad in horizontal position and redefine it as a one-hand pad with a similar layout as yours:
IBM M13 black
HHKB Pro 2 HasuBT
Offline Dwarlorf
« Reply #135 on: Sun, 16 October 2016, 16:21:34 »
5 Way Hat keyboard
D = Del
C = CTRL
T = TAB
E = Enter / FN2
That's actually how I started out as well. I wonder how many functionalities that one has. I want mine to have/keep full keyboard functionality.
Offline menuhin
« Reply #136 on: Sun, 16 October 2016, 16:42:10 »
Perhaps it's good to get inspiration of the layout and layers from Matias Half-Keyboard:
http://www.matias.ca/halfkeyboard/index.php?refID=7
http://www.matias.ca/halfkeyboard/resources/downloads/HK101_RevisedManual.pdf
« Last Edit: Sun, 16 October 2016, 16:54:50 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
Offline Dwarlorf
« Reply #137 on: Sun, 16 October 2016, 16:57:40 »
Interesting concept indeed. Very expensive for just half a keyboard though.  :D
On a side note: I did not intend mine to be a one handed keyboard but many people seem to think so.
Offline replicaJunction
« Reply #138 on: Tue, 25 October 2016, 10:25:14 »
I'm designing a board based around the thought "60% split Atreus" and looking for some feedback on layout options.
Here's a "true" 60% Atreus design - I've tried to stay as close as possible to the original Atreus:
151191-0
Based on my hand size, it looks like I'd benefit from a more aggressive column stagger. I'm not quite sure how many and what sizes of keys I'd like, though. Here are a couple of the ideas I've been playing with:
151193-1
151195-2
151197-3
Here are a couple of my other references and inspirations:
https://geekhack.org/index.php?topic=74518.0
https://geekhack.org/index.php?topic=85164.0
What do you all think? Any of these options look better than the others?
Offline mrbishop
  • Evil Genius
« Reply #139 on: Thu, 27 October 2016, 11:50:14 »
Projects
Offline Phenix
Winter is coming.
Offline mrbishop
  • Evil Genius
Projects
Offline feralfoo
  • Software developer and mech keyboard nut
« Reply #142 on: Wed, 09 November 2016, 21:39:47 »
Have seen some useful and interesting layouts here so far. I've been a fan of the 60% form factor for a while, but can't live without an arrow cluster. So trying my hand at a custom which is still compatible with poker 60 style cases:
152551-0
HHKB Pro JP + Hasu controller, Realforce RF87U55G, G60 Retro, QK65
Offline Phenix
« Reply #143 on: Thu, 10 November 2016, 02:22:10 »
That looks good!
Winter is coming.
Offline menuhin
« Reply #144 on: Thu, 10 November 2016, 04:33:45 »
Nice, the 2.75u R_Shift can go just right in there as the space bar.
Actually following your practice of putting the Up-arrow key right next to the forward-slash key, even a 6u or 6.25u space bar can be achieved, depending on how many functional modifiers you are going to keep.
IBM M13 black
HHKB Pro 2 HasuBT
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #145 on: Thu, 10 November 2016, 14:56:53 »
This reminds me of the HHKB Pro JP. Nice
Offline feralfoo
« Reply #146 on: Fri, 11 November 2016, 20:05:04 »
Yeah the Pro JP has been my everyday keyboard for about a year now. Be nice in ANSI instead of ISO.
Offline feralfoo
« Reply #147 on: Fri, 11 November 2016, 20:12:41 »
Great point, had a few iterations which did exactly that.
Plate is on the way via Swillkb's fantastic builder site, will create another thread after that.
Offline mrbishop
  • Evil Genius
« Reply #148 on: Sun, 13 November 2016, 01:04:29 »
So I've been wanting to try an ortho so here we go
Projects
Offline DeTommie
« Reply #149 on: Mon, 14 November 2016, 06:18:03 »
Too bad you didn't make the keys have a chess-pattern. Then you could really send it from your chessboard...
