Author Topic: Found IBM model F for $20, go for it?  (Read 1823 times)
Offline spwath
« on: Sat, 13 August 2016, 12:31:23 »
I found the model F for $20, the XT 83 key one. Should I get one?
They have 4. SHould I get more? seems like a pretty good deal....
Offline sony
  • Formerly ultraidiot
Re: Found IBM model F for $20, go for it?
« Reply #1 on: Sat, 13 August 2016, 12:32:02 »
I would get them all because I'm a hoarder.
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Sat, 13 August 2016, 12:52:40 »
YES!!! a model F for 20$ sounds like a great deal. go for it. I can help you with installing the internal soarers converter if you like. all you need is a teensy to get it up and running.
Offline Aran.E99
« Reply #3 on: Sat, 13 August 2016, 12:53:24 »
there is either something wrong with is or the people selling are incredibly stupid (no offense :p). if it's an F XT, its a BS board and i'm sure you will need a converter. if it is on ebay etc, ask for more pictures to make sure it is in decent condition. i cant tell you to buy it considering i haven't seen it.
SMK 2nd Gen Blue Alps mount <3
Offline spwath
« Reply #4 on: Sat, 13 August 2016, 17:57:53 »
Looks pretty good from the pic, on craigslist. I think ill check them out.
Offline 1391406
« Reply #5 on: Sat, 13 August 2016, 18:24:57 »
I'd buy them all, keep one and sell the least attractive models on eBay.
