Author Topic: Do you lube your Topre switches after silencing it?  (Read 6794 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Mon, 15 August 2016, 18:57:32 »
I bought Hypersphere's rings and I plan to install them on my Topre soon.
But I was just thinking, to install it you have to take all the switches apart, do you lube the sliders after you take it apart?  Or just straight pop it back and call it a day?
Offline raymogi
Re: Do you lube your Topre switches after silencing it?
« Reply #1 on: Mon, 15 August 2016, 18:59:01 »
I always end up lubing it anyway cause might as well right?
Please feed my addiction.
Offline quasistellar
« Reply #2 on: Mon, 15 August 2016, 19:37:20 »
I didn't lube all my sliders, but I did grease my stabs for a now-rattle-free Novatouch.
Offline nmur
  • ಠ_ಠ
« Reply #3 on: Mon, 15 August 2016, 19:40:37 »
lubing topre is actually pretty quick and painless, so yeah
Offline khakis1111
« Reply #4 on: Mon, 15 August 2016, 20:53:14 »
I just silenced and lubed my realforce 87U two days ago! When you install the hypersphere rings, you pretty much have to take the entire keyboard apart. So I took this chance to lube everything up, including the stabilizers. It will be worth it if you do.
Offline Hyde
« Reply #5 on: Tue, 16 August 2016, 12:24:14 »
lol yeah that's what I was thinking, though what lube did you guys end up using?
Offline khakis1111
« Reply #6 on: Wed, 17 August 2016, 18:45:32 »
You can check this thread out: https://geekhack.org/index.php?topic=34332.0
Some people seemed to use a mixture of different lubricants.. I'm not sure. But I used Krytox gpl 205 I got from Amazon. It's a thick lubricant that works pretty well on topre switches in general, in my opinion.
Offline Neo.X
« Reply #7 on: Wed, 17 August 2016, 19:29:31 »
For sure, those two should always go together.
All those keyboards will be lost in time....
Offline xondat
  • i'm not a star
« Reply #8 on: Wed, 17 August 2016, 19:31:15 »
/thread
It's so much effort opening the whole board to silence, might as well do it.
Offline derb2k2
  • Something of a Topre ****..
« Reply #9 on: Wed, 17 August 2016, 19:31:29 »
add me to that list. I end up doing both when I take apart a torpe board. Just do it.  ;)
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline mikes41720
    • Ranting & Rambling
« Reply #10 on: Thu, 18 August 2016, 05:49:05 »
I have a type-S. I've already lubed my RF87U before but that was with EK MechLube 2 (red one). I regret adding landing pads though.
Is the Krytox GPL 205 the most recommended?
Offline Hyde
« Reply #11 on: Thu, 18 August 2016, 20:16:48 »
lol I'm wondering about this too, it's a lot easier for me to get EK MechLube 2, and cheaper too.
Anyone know if this will work?
Offline klennkellon
  • I like bottoming out
« Reply #12 on: Fri, 19 August 2016, 01:37:38 »
lubing topre sounds like adding sugar to coke because it's not sweet enough.
Offline derb2k2
« Reply #13 on: Fri, 19 August 2016, 07:31:07 »
i can't recall the Krytox mix but in my experience, using medium-viscosity lube works best. Don't ever use the most viscous mix because it'll make the keypress all mushy and will be hell to remove. Also, unless you're very careful and measured, using the most fluid makes a bit of a mess. I've applied em all and found the medium works fine, producing un-adulterated keystroke  :))
Offline mikes41720
« Reply #14 on: Fri, 19 August 2016, 07:45:46 »
So medium viscosity is the GPL 205 from Krytox? Or is that the reason why people preferred the mixture of the 103 and 205?
Offline Hyde
« Reply #15 on: Wed, 07 September 2016, 20:33:35 »
LOL I second this sentiment, I end up modding it without lubing it because I got lazy.
And it's pretty much as good as it was before (stock is non-lubed).
Though maybe I should've lubed the stabilizer wires but that's about it.
:P
