Author Topic: Can't boot with Satan GH60 keyboard connected  (Read 2087 times)
Offline twk
« on: Fri, 19 August 2016, 07:16:41 »
Hi!
I have recently built a keyboard with a Satan GH60 pcb. The keyboard works as intentend when I'm in Windows and I have programmed a layout that I prefer. The firmware is the original firmware. The problem is that if I have the keyboard plugged in and start, or reststart, the computer it will stop the booting process att the boot/bios screen, with the Asrock logo and "Press F2 for menu" etc. Nothing more happens with the keyboard connected. If I disconnect the keyboard at this point the computer will start to Windows. I have updated the motherboard bios to latest version and my POK3R doesn't have this problem.
Do you have any tips on how to solve this?
Thanks in advance!
Offline Leslieann
Re: Can't boot with Satan GH60 keyboard connected
« Reply #1 on: Fri, 19 August 2016, 19:01:38 »
I have a Vortex Race that does the same thing, I used to think it was a stuck key until I ran some tests.
It doesn't do it on all systems, and I never found a fix.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Tactile
« Reply #2 on: Fri, 19 August 2016, 19:09:52 »
If you have N key rollover enabled in your firmware, try going back to 6 key rollover.
REΛLFORCE
Offline twk
« Reply #3 on: Sat, 20 August 2016, 02:07:12 »
OKay, thanks! Will check that out!
