Author Topic: MagicForce 68: Is it worth it?  (Read 2270 times)
Offline Chris_N64
« on: Sat, 27 August 2016, 21:39:03 »
Hey all! I was hoping for some experienced opinions. I'm looking at getting my second keyboard, 65% looks perfect, going smaller then my razer widow. (can't live without my arrow keys though) Has anyone had any experience with MagicForce 68's? I noticed there's one on amazon with cherry MX browns, at $70 I'm kinda hesitant since it seems too cheap but at the same time, it might be the perfect way to try out MX Browns
Cheers!
Offline SBJ
  • Tactile pls
Re: MagicForce 68: Is it worth it?
« Reply #1 on: Sun, 28 August 2016, 02:37:31 »
LiquidEvilGaming has made a video review of the keyboard, and there's some discussion in the thread that might be worth checking out.
https://geekhack.org/index.php?topic=81991.msg2166944#msg2166944
Offline Leslieann
« Reply #2 on: Sun, 28 August 2016, 04:46:42 »
The backlit models have a weird glitch with forced refresh and both backlit and non-backlit have rather noisy spacebars due to cheap stabilizers.
Other than that, they are quite well made, I use mine daily.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
