Author Topic: M122 case on F122?  (Read 2649 times)
Offline mike52787
  • Alps Aficionado
M122 case on F122?
« on: Sat, 27 August 2016, 23:13:28 »
Considering my f122 is coming in the mail soon, and I am interested in customizing it alot, I want to preserve the original case. Could I swap the top housing from a m122 onto my f122? I would rather not paint the original case if at all possible.
Offline 0100010
  • Not Sure
Re: M122 case on F122?
« Reply #1 on: Sun, 28 August 2016, 14:24:06 »
« Reply #2 on: Sun, 28 August 2016, 21:09:14 »
The first link, the wcass version, is superior to mine (the 2nd link) and he made it happen with a 2nd-generation case, too.
- D Trump 2026-10-24
Offline mike52787
  • Alps Aficionado
« Reply #3 on: Sun, 28 August 2016, 21:16:44 »
If I use a first gen case with 3 step legs can I still use the metal bottom housing?
« Reply #4 on: Mon, 29 August 2016, 07:15:47 »
Yes, but it requires additional fiddling. The "spine" piece gets superseded and the F uses machine screws with actual metal nuts embedded in the case, whereas the M screws tap directly into the plastic.
If your F case is broken, you may need to do it, but it is a kludge to just do it without a good reason.
And also, Cindy and/or Lot_Lizard may have some extra F-122 case shells available for cheap.
Offline mike52787
  • Alps Aficionado
« Reply #5 on: Mon, 29 August 2016, 09:48:22 »
I saw that, but when I looked hey were sold out of top housings. Mayybe when cindy gets another load of f122s I can convince her to sell me a top housing. For now, Ill just order a m122 and try it. its not like there expensive after all.
Offline alh84001
« Reply #6 on: Tue, 30 August 2016, 05:26:50 »
I did this exact thing recently with a 1st gen M122 case. It wasn't complicated, but it pays to have a very sharp scalpel. There are a couple of plastic spacers in the M case that need to be cut off.
I used a couple of those cut spacers from the top part of the case and epoxied them into an F case. I also needed to make the tabs in front of the case thinner with a felt dremel add-on. Some care needs to be taken, but it's not rocket science :). I could then put an M122 into that F case as well to complete the switch.
