Author Topic: [GB][FINISHED] Mekanisk Group Buy / LeandreN round 5  (Read 256018 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][OPEN, ORDER NOW] Mekanisk Group Buy / LeandreN round 5
« Reply #150 on: Mon, 03 October 2016, 06:46:25 »
I was trying to find the info about when will this ship? Thanks.
Now we are trying to hit MOQ. After that is done, we have to wait a couple of months. No clear shipping dates yet, but we are on good way to hit the MOQ :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #151 on: Mon, 03 October 2016, 06:47:16 »
@LeandreN: When is the expiry for your R5 GB?
Sent from my 2013023 using Tapatalk
When we are at 100 total PCBs, I am slowly closing the entries. Everyone that wants to join will get the opportunity though.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #152 on: Mon, 03 October 2016, 06:47:56 »
What is the silkscreen color? Black? Black + Mint would look great.
I'm interested in maybe adding a white PCB... what silkscreen would that be? Any chance you will do black? Stock GON right now is blue, and I don't like how that looks :P
I will try to get the silkscreen to be black on both :)
Offline GoatMaster
  • Formerly Franatic89
« Reply #153 on: Wed, 05 October 2016, 03:07:09 »
How long will it be open ?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #154 on: Thu, 06 October 2016, 15:32:03 »
Around two weeks.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #155 on: Sat, 08 October 2016, 19:32:07 »
And joined! Looking forward to this!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #156 on: Sun, 09 October 2016, 03:55:05 »
Now is the time for the last orders. Get your friends and family in on this one. I have a vendor that will buy some PCBs, so MOQ shouldn´t be a worry.
Offline curvie
« Reply #157 on: Sun, 09 October 2016, 04:02:57 »
Just joined for my first group by on GH!
Offline t8c
« Reply #158 on: Sun, 09 October 2016, 10:49:06 »
In for a plate and some stabs!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #159 on: Sun, 09 October 2016, 10:59:44 »
Great, thanks guys.
Offline GentlemanShark
« Reply #160 on: Sun, 09 October 2016, 11:07:46 »
Great, thanks guys.
Does it supports Tai Hao Alps Dolch? What stabilizers?
Sent from my SM-G925T using Tapatalk
« Reply #161 on: Sun, 09 October 2016, 11:32:40 »
Great, thanks guys.
Offline TalkingTree
    • My projects
« Reply #162 on: Sun, 09 October 2016, 12:22:40 »
These PCBs are for Cherry MX (and clones) only and plates are for PCB mounted Cherry stabilizers.
« Reply #163 on: Sun, 09 October 2016, 13:57:08 »
Great, thanks guys.
I mean the plate
Offline duynguyenle
  • Personal text? What personal text???
« Reply #164 on: Sun, 09 October 2016, 14:12:22 »
Great, thanks guys.
I mean the plate
Cherry stabilisers only AFAIK. Not sure about using Alps switches with it, maybe Leandre can clarify. In any case, probably not a good idea anyway, since you can't use Alps stabiliser for the mods.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline kawasaki161
« Reply #165 on: Sun, 09 October 2016, 14:17:59 »
Of the cutouts are the same the main cluster will fit with ALPS switches, the thing is that everywhere where you have a choice with switch placement, or you have a 2u stabilized key you won't be able to fit ALPS switches, they'll just fall through the plate. Also, as it was already said, ALPS stabilizers won't work.
Offline Brammm87
« Reply #166 on: Sun, 09 October 2016, 14:30:41 »
pls gief bbv2
« Reply #167 on: Sun, 09 October 2016, 14:52:28 »
So it won't work?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #168 on: Tue, 11 October 2016, 13:54:41 »
I will let the orders be open for 1 week from now.
Offline Brammm87
« Reply #169 on: Wed, 12 October 2016, 15:08:04 »
Hey Leandren, sent an email to support, I'd like to add some stuff to my order, but sorta forgot what I ordered in the first place :p
pls gief bbv2
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #170 on: Wed, 12 October 2016, 15:26:19 »
I'll read mails tomorrow. I don't recall getting a mail from you though.
Support@mekanisk.co
Offline ReverbSlush
  • 16/52 RNG score
« Reply #171 on: Thu, 13 October 2016, 12:47:30 »
joined!
not sure how the orange+mint color combo I selected will be, but that's ok!
I'm relatively new to this... aside from switches and caps.. do I need stabilizers? if so, will these work on the PCB?
https://zealpc.net/collections/accessories/products/zealstabilizers
and as a followup.. when using an HHKB plate and layout... what options should I choose from that site?
Offline TalkingTree
    • My projects
« Reply #172 on: Thu, 13 October 2016, 14:30:44 »
Unique.
Yes, you do and you're looking at a premium product. 50 USD for a stabilizer set is quite a lot. LeandreN is also offering PCB mount stabilizers, in this GB, for a much lower price.
You would need a 7u spacebar wire for the stabilizer.
Offline ReverbSlush
  • 16/52 RNG score
« Reply #173 on: Thu, 13 October 2016, 15:13:37 »
sweet! thanks for the answers.
There is an option for a 7u and four 2u stabilizers for only 30... I can't remember if I picked any up from the form I filled out so I might get those.
So only for the spacebar? nothing needed for enter or shift keys? This is going to be awesome.
Offline TalkingTree
    • My projects
« Reply #174 on: Thu, 13 October 2016, 16:04:05 »
Stabilizers are provided here for a mere 8 USD.
For a HHKB you need at least one 7u for the spacebar and one 2u for the enter key.
Need for other stabilizers really depend on your layout.
Remember you can split both shift keys and the backspace key, just like I did with mine.
Offline graefeln
« Reply #175 on: Thu, 13 October 2016, 16:53:50 »
As TalkingTree said, the ones here are only 8$ - so if you have no particular desire for clear/golden stabs, you really don't need to spend the extra money. Keep in mind also that these are not "pre-clipped" like Zeal's, but that is a simple process if you wanted to.
Also as TalkingTree mentioned, you'll need a 7u (space bar) and a 2u for the enter key - if you want the fourth row to be like an HHKB, you need a 2u for the left shift as well; you can also just split it into two 1u keys like he did.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #176 on: Fri, 14 October 2016, 07:12:49 »
Hi!
I am slowly closing orders from today. If there are anyone that hasn't ordered, need to wait for something or anything similar, please just contact me and we will sort it out. Now is the time to share the link to people who hasn't heard of this GB yet.
GON is ready and will hire a worker than will do the QC for us here.
What do I have to do:
Convert some files for the silk screen and invocing when orders are closed.
I want to work on invoices soon, since this takes a long time. The people that will be invoiced first, are the people that ordered first.
I can be contacted on support@mekanisk.co anytime.
LeandreN
Offline Biggestmac
« Reply #177 on: Fri, 14 October 2016, 07:50:17 »
Was there a sample picture for the green plate?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #178 on: Fri, 14 October 2016, 07:53:26 »
No there wasn't.
Offline Schw4rz
« Reply #179 on: Fri, 14 October 2016, 17:21:44 »
I am interested in ordering a PCB and a carbon plate. I regularly read r/mechanicalkeyboards and recently got ISO-DE DS PBT Keycaps for my almost 10 year old steelkeys 6G (Cherry MX Black). But I am still new to customizing/building keyboards, so I have some basic questions:
1. Will all items be shipped from Norway?
2. Do I have to solder anything else than the Switches (and possibly LEDs) itself?
3. Is it likely that the orders will be shipped until the end of 2016?
Thank you very much!
KR
Sebastian
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #180 on: Fri, 14 October 2016, 17:23:41 »
KR
Sebastian
Yes, they are shipped from Norway.
You only need to solder switches and LEDs.
Yes, it is likely that this GB ships before the end of 2016, but you can never be 100% sure in a GB.
Offline Schw4rz
« Reply #181 on: Sat, 15 October 2016, 08:43:11 »
KR
Sebastian
Thanks. Placed my order :)
Offline FSund
« Reply #182 on: Sat, 15 October 2016, 12:34:53 »
I'm a noob when it comes to custom keyboards (and this is my first GB). I was wondering if anyone could point me in the direction of how I should proceed to build a sandwich style keyboard with floating keys, using the pcb and plate from this GB?
Join the Mechanical Keyboards Norway Discord server
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #183 on: Sat, 15 October 2016, 12:44:34 »
Hi!
A sandwhich case requires a special plate. I would suggest buying a full kit from 1upkeyboards.com.
http://1upkeyboards.com/index.php?cPath=42 Here is a link to their keyboard kits section.
Offline FSund
« Reply #184 on: Sat, 15 October 2016, 15:22:23 »
Hi!
So the plate from this GB is meant for a Poker style case?
What about standoffs for the pcb, are they universal? Or will I have to get a custom case?
Offline TalkingTree
    • My projects
« Reply #185 on: Sat, 15 October 2016, 16:29:11 »
Both plate and PCB fit a Poker (or 60%) case.
Standoffs are part of the case.
If you wish, or you can get a standard case.
Offline tinyprawn
« Reply #186 on: Sat, 15 October 2016, 21:01:31 »
Is it safe to assume the PCB doesn't have the bluetooth option?
Also, how customizable is the backlight?  I saw there are 3 types: in-switch, on PCB, and side LEDs... but can the in-switch LEDs be addressed individually?
Offline TalkingTree
    • My projects
« Reply #187 on: Sun, 16 October 2016, 01:37:29 »
It has the BT slot but the module is not included, you have to source it yourself.
No.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #188 on: Sun, 16 October 2016, 08:09:20 »
Going to close in a couple of hours now, should have closed it on friday, but I give you a few more hours.
Thanks.
Offline tinyprawn
« Reply #189 on: Sun, 16 October 2016, 13:45:55 »
Thanks.
I appreciate that considering I just signed up last night.
Offline Owntrolf
« Reply #190 on: Tue, 18 October 2016, 00:21:19 »
Now time to hope the GB isnt held back by GON's superdelays
Offline richfiles
« Reply #191 on: Tue, 18 October 2016, 01:54:21 »
Still waiting for a response by email on a detail that was being discussed.
Last response was on the 10th, regarding waiting on a quote. Am I still going to be able to get into this group buy?
Offline Shiftshape
« Reply #192 on: Tue, 18 October 2016, 04:31:01 »
I already have 4 unused Nerds waiting to get buildt, but gawdammit if none of them are mint blue.. Need some plates though, so count me in!
Anybody have opinions about the carbon plates?
Offline TalkingTree
    • My projects
« Reply #193 on: Tue, 18 October 2016, 05:15:05 »
Round 4 was ran with GON's PCB and there were no delay. He hired someone to assist him and he's doing the same this time around.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #194 on: Tue, 18 October 2016, 12:59:45 »
Hello!
A little update.
Now I have placed the order for the steel, aluminium and carbon fibre plates. I am waiting on some confirmation with GON. We are going to have both my "MEKANISK"-logo on the PCBs, along with the 1upkeyboards logo, because they decided to dive in and save our colour MOQ. I really appericate what they do to help all of us, not just me with this group buy.
As many of you know, I only invoice after I have all the quotes and invoices from the factories so the money leave me immediately.
I am going to send out an update mail later.
Thanks for your patience.
If you have any questions about anything, please let me know here, or on support@mekanisk.co.
Thanks,
William
Offline dorf
  • divine creator
« Reply #195 on: Tue, 18 October 2016, 13:03:09 »
Offline polentA
  • Formerly withoutrulers
  • GMK plz
« Reply #196 on: Tue, 18 October 2016, 14:47:32 »
Hello!
A little update.
Thanks,
William
Thank you for the update! Really looking forward to this and (just like with keycap raffles) looking forward to the invoice lol!
Offline duynguyenle
« Reply #197 on: Tue, 18 October 2016, 14:49:06 »
Hello!
A little update.
Thanks,
William
Thanks for the update Leandre, are you going to stock a few extras on your site after the GB like last time? I only ordered 1 at the moment but if my experience goes well I'm thinking of picking up another one or get in on the next round.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #198 on: Tue, 18 October 2016, 14:57:47 »
Hello!
A little update.
Thanks,
William
That is the plan, to stock more on my site :)
Offline Owntrolf
« Reply #199 on: Tue, 18 October 2016, 23:12:02 »
Now its time to hope that I get it in like 2 months in time for muh christmas
