Author Topic: [GB][FINISHED] Mekanisk Group Buy / LeandreN round 5  (Read 256020 times)
Offline itzmeluigi
  • ПБТ
Re: [GB] Mekanisk Group Buy / LeandreN round 5
« Reply #50 on: Sat, 10 September 2016, 05:57:03 »
Just a may be stupid question. On the layouts it states on both options, Winkeyless and HHKB, that the spacebar is 7u... Why not 6.25? In HHKB makes even more sense, isn't it?
HHKB uses 6u. 7u just makes it look nice and symmetrical.
PCB support for the real layout just isn't there especially with all the universal 60 PCBs.
Symmetry isn't a good thing in my opinion tho. Love the unsymmetrical look of a real hhkb and things to be unsymmetrical in general.
Resist the symmetry.
The FaceW and Nerd60 both support 6.00u spacebars. A plate with the real HHKB layout would be awesome.
https://www.reddit.com/r/MechanicalKeyboards/comments/410nur/photos_6u_spacebar_on_60_custom_endgame_complete/
« Last Edit: Sat, 10 September 2016, 06:03:34 by itzmeluigi »
Offline eddible
Re: [GB][OPEN, ORDER NOW] Mekanisk Group Buy / LeandreN round 5
« Reply #51 on: Sat, 10 September 2016, 06:49:41 »
Ordered a mint PCB and red plate, will look ace with my Jukebox set!
Offline Hydra04
« Reply #52 on: Sat, 10 September 2016, 07:31:30 »
Hey!
The orders are now open.
I made the decision to cut out the switches of this group buy due to multiple reasons, I am very sorry for those that intended to buy these from me. Luckily they are available elsewhere.
Let me know immediately if there are any problems with the order form.
I will update with stats and such later.
Thanks for your patience, if we want this GB to go through, I need as many orders as possible. The MOQ for the PCBs are 120.
LeandreN
I was going to buy some gaterons :(
Where is an "elsewhere" inside the EU (if any)?
Offline duynguyenle
  • Personal text? What personal text???
« Reply #53 on: Sat, 10 September 2016, 09:11:35 »
Hey!
LeandreN
Mechsupply and Caps-unlocked should have a few gateron packs left. If not, you could try aliexpress or use a taobao proxy
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline toneman77
« Reply #54 on: Sat, 10 September 2016, 10:03:22 »
Do I understand that correctly, these are the possible layouts for the plates? (click for KLE)
I wasn't sure about the split backspace.
Offline duynguyenle
« Reply #55 on: Sat, 10 September 2016, 10:07:26 »
Split Backspace is supported. You can see it in the picture, upper left corner.
Offline toneman77
« Reply #56 on: Sat, 10 September 2016, 10:13:50 »
Ah ok. Added it in the KLE layout.
« Reply #57 on: Sat, 10 September 2016, 10:16:41 »
in
Offline Hydra04
« Reply #58 on: Sat, 10 September 2016, 11:00:05 »
Hey!
LeandreN
Actually, I asked for something in the EU lol
Jokes aside, the problem is that GBP prices are too high... I mean, gaterons from mechsupply and caps-unlocked cost ~0.40 (if not 0.50) € per switch. The ~0.27€/switch by LeandreN (if I recall correctly) would have been just perfect (also, the price of shipping is lower with this GB).
« Last Edit: Sat, 10 September 2016, 11:03:29 by Hydra04 »
Offline mrflow3r
    • T
« Reply #59 on: Sat, 10 September 2016, 11:07:03 »
Any recommendation for case for this set?
Offline duynguyenle
« Reply #60 on: Sat, 10 September 2016, 11:18:51 »
Hey!
LeandreN
Get it from widebasketshop on Ebay or search for switches on Aliexpress
Edit: if you're just looking for a small amount of switches (enough to fill a 60%), I've got some spares lying around, can sell them to you if you want. What types and how many are you looking for? I've got some Gateron green, blue and browns
« Last Edit: Sat, 10 September 2016, 13:05:56 by duynguyenle »
Offline eksuen
  • Ambassador of explosions.
« Reply #61 on: Sat, 10 September 2016, 11:41:41 »
How long will you be taking orders and any chance of getting photos of the green plate?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #62 on: Sat, 10 September 2016, 11:52:28 »
About a month, and I am trying my best to get a sample photo.
Offline eksuen
« Reply #63 on: Sat, 10 September 2016, 11:54:09 »
Thank you!
Offline FoC_Tow
  • Brokehlicious
« Reply #64 on: Sat, 10 September 2016, 14:05:03 »
Good to know.
Soldered a Nerd60 recently and have another one from LeandreN's last GH lying around but never noticed apperantly.
If you compare to an actual hhkb it would still look different.
On the real one it seems like it's slightly shifted to the right to make it look more balanced?!
I think it still wouldn't look right tbh.
1.0,1.5,7.0,1.5,1.0 is still the best bet so guess :D
Offline itzmeluigi
  • ПБТ
« Reply #65 on: Sat, 10 September 2016, 17:11:02 »
Good to know.
The keys align to the same thing as the real HHKB if you remove the outer keys on a Realforce/MX board. It would be just like the HHKB with the same aligned comfortable bottom row the real HHKB has.
For example starting from homerow move both your left&right pinky directly down to hit the 1u Alt keys they are perfectly aligned under them on the real 6.00u HHKB setup. Do the same with your ring finger and they perfectly align to hit 1.5u keys on the real HHKB.  If you try that with a 7u spacebar the left pinky will hit the 1u key and the right will hit the right 1.5u key, your right ring finger would hit the spacebar also. IMO 6u spacebar HHKB is the best as it matches the real thing.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #66 on: Sat, 10 September 2016, 17:39:30 »
Thanks for todays orders, and thanks for the questions and concerns.
Due to demand, I might add switches as an option later, if i manage to find a good and fast way to manage them, but nothing can be confirmed as of now.
Keep the orders and questions coming!
If you need something right now, you can buy it here:
mekanisk.co
LeandreN
Offline Geroximo
« Reply #67 on: Sat, 10 September 2016, 19:16:12 »
I'm in. Looking forward to the new build. Hopefully the MOQ will be reached.
I would've been interested in Gateron switches, too. Sad to hear that hey didn`t make it into the groupbuy.
Offline ideus
  • Björkö.
« Reply #68 on: Sat, 10 September 2016, 19:31:30 »
Just a heads up: The picture of the PCB in the OP does not appear to be a GON, but a WKL's one.
Offline alveeno
« Reply #69 on: Sat, 10 September 2016, 21:25:32 »
The HHKB plates are : covered covered 1.5u- 1u - 1.5u - 7u - 1u - 1.5u - covered 1.5u
Did you mean 1u - 1.5u - 7u - 1.5u - 1u
Offline Hydra04
« Reply #70 on: Sun, 11 September 2016, 03:53:39 »
Hey!
LeandreN
Already did that. Still, customs increase prices too much, I'm in the worst part of eu from that point of view :(
Anyway, thanks very much for your offer! I was going to buy some blacks. I think I'll stick to cheery switches (that at least are shipped from germany).
I'm sorry for the off topic, I was just curious to know if there was another european alternative for gaterons.
Offline TalkingTree
    • My projects
« Reply #71 on: Sun, 11 September 2016, 04:58:08 »
You can ask to underdeclare the wares' value, it's illegal but Aliexpress vendors usually don't care.
Offline Happylomo
« Reply #72 on: Sun, 11 September 2016, 07:00:45 »
Ordered 1 mint and 1 white PCB  ;D
Thanks for the good timing, LeandreN. just received my tax refund  ;D
Offline mrflow3r
    • T
« Reply #73 on: Sun, 11 September 2016, 12:44:59 »
Stupid question: how reliable is untracked shipping to Canada?
« Reply #74 on: Sun, 11 September 2016, 12:50:37 »
garbage tbh
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #75 on: Sun, 11 September 2016, 12:51:43 »
From Norway to Canada, it has been very reliable.
Offline mrflow3r
    • T
« Reply #76 on: Sun, 11 September 2016, 13:08:34 »
As in it goes missing? That is not good.. =(
Offline mrflow3r
    • T
« Reply #77 on: Sun, 11 September 2016, 13:08:58 »
Good to know. I suppose I will take my chances haha
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #78 on: Sun, 11 September 2016, 13:09:17 »
No no. It's been very good.
Offline Brammm87
« Reply #79 on: Mon, 12 September 2016, 07:49:14 »
Even though I'm disappointed to see you're not using my 1337 photoshopped new signature image, I've ordered.
pls gief bbv2
Offline robbles
« Reply #80 on: Mon, 12 September 2016, 15:07:33 »
Are the steel plates thicker and less malleable? The aluminum plate for my S60-X was bendy and I'd like something a bit more solid feeling.
How does one become so interested in a thing like keyboards? When you realize you use a keyboard more than any other tool in your life.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #81 on: Mon, 12 September 2016, 15:20:27 »
It's much more solid and less bendable.
Offline chuckdee
« Reply #82 on: Mon, 12 September 2016, 21:07:56 »
With GON being flaky with orders lately, what is the mitigation for his flakiness on the scheduling?  Is he involved in any way with fulfillment of the orders?
Offline TalkingTree
    • My projects
« Reply #83 on: Tue, 13 September 2016, 02:44:23 »
Round 4 was run with GON's NerD 60 and there was no delay.
Offline chuckdee
« Reply #84 on: Tue, 13 September 2016, 06:48:50 »
Was GON being flaky at the time?  I just wanted to ask the question to see if there was any mitigation for that occurrence.
Offline TalkingTree
    • My projects
« Reply #85 on: Tue, 13 September 2016, 06:57:10 »
GON's delays are limited to custom services such as soldering resistors or LEDs. PCBs for Round 4 were simply tested by GON after production, before being shipped to LeandreN.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #86 on: Tue, 13 September 2016, 08:22:16 »
GON also hires a worker to process my order. It shouldn't delay or be delayed by his personal orders.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #87 on: Tue, 13 September 2016, 08:30:06 »
Probably a stupid question, but is the PCB pre soldered? i feel like it is I just wanna calrify  :thumb:
Offline TalkingTree
    • My projects
« Reply #88 on: Tue, 13 September 2016, 08:57:11 »
Controller, USB plug and diodes are. Resistores and back/side LEDs are up to you.
Offline chuckdee
« Reply #89 on: Tue, 13 September 2016, 10:09:02 »
Thanks for the clarification.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #90 on: Tue, 13 September 2016, 12:44:16 »
Ah man. I thought diodes + resistors were pre-soldered ?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline TalkingTree
    • My projects
« Reply #91 on: Tue, 13 September 2016, 14:00:08 »
I thought resistors were pre-soldered ?
I'm fairly certain they are not. But wait for further confirmation.
Offline jmdaly
« Reply #92 on: Tue, 13 September 2016, 20:45:05 »
Ordered a PCB, a plate, and some stabs. Looking forward to it!
Offline DanielT
« Reply #93 on: Wed, 14 September 2016, 07:09:36 »
In the last GB the NerD60 PCB's included also resistors. Here is a photo with the PCB's  https://geekhack.org/index.php?topic=79315.msg2152702#msg2152702 .
I have an orange PCB and it had everything soldered, diodes and resistors.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #94 on: Wed, 14 September 2016, 08:01:57 »
Yes, diodes AND resistors are presoldered. I will make that clearer in the OP. Thanks.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #95 on: Wed, 14 September 2016, 11:27:04 »
Thanks for the clarification  : )
WTB/WTS/WTT ---->
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #96 on: Thu, 15 September 2016, 10:56:38 »
Hey!
We definetily need some more orders to get these PCBs to go through MOQ.
Keep spreading the word about the group buy!
I am talking to some vendors that might help.
Mint is the most popular colour.
LeandreN
Offline Camzel
  • My life is a meme
« Reply #97 on: Thu, 15 September 2016, 10:58:31 »
Is there any difference typing on a Carbon Fiber plate compared to an Aluminium one? It looks sick, but I don't know if the 2x price is really worth it.
Offline jmdaly
« Reply #98 on: Thu, 15 September 2016, 11:38:42 »
Is the MOQ on the PCB a per-colour MOQ, or based on total number of PCBs in both colours? I ordered a white PCB, but would happily switch it to mint if it helps reach the MOQ.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #99 on: Thu, 15 September 2016, 11:40:15 »
We need 50/50 25/75 or similar, so that's not really an issue.
Thanks for the offer though, we might need it.
The moq is based on the total
