Author Topic: Anyone heard of "KRGD" MX clones?  (Read 12777 times)
Offline Row009
« on: Sat, 03 September 2016, 17:07:30 »
Hello,
Has anyone heard of the KRGD switch (An MX Series clone)?
There doesn't seem to be much information on the web that I can find...
Re: Anyone heard of "KRGD" MX clones?
« Reply #1 on: Sat, 03 September 2016, 18:14:07 »
Are you sure that it does not say "KBRD", which would look almost similar?
Anyway, I have not..
Kailh often rebrands their switches for their clients, but if it was them then it would have their characteristic snaps for connecting top and bottom housing.
Offline Row009
« Reply #2 on: Sat, 03 September 2016, 19:07:13 »
I'm pretty sure it says "KRGD" on the switch but it's kind of hard to be 100% sure since the switches are clear and so is the marking. I'll upload a photo, maybe you can identify the switch by the build.
Notice the bottom (note the switch is mounted upside-down) right corner of the stem (it has a small square part that is sunken in a bit.
« Reply #3 on: Sun, 04 September 2016, 05:47:57 »
Ah, I think now that it says "K RGB".
That looks like a Lingbao keyboard. Other Lingbao keyboards I have seen (on the 'Net) have had Gaterons but those don't have that slider.
Offline Row009
« Reply #4 on: Sun, 04 September 2016, 22:37:35 »
Yeah, it is indeed a Lingbao. I actually sent the seller on Aliexpress a message, and his reply was that the switch is made by: Lingdu Electronics Co., Ltd (Shenzhen) - still doesn't tell me much.
I ordered this keyboard which was supposed to come with Gateron switches, unfortunately(?) it did not. Since I have never used Gateron switches I have nothing to compare it (KRGD/B) to, other than CHERRY.
« Last Edit: Sun, 04 September 2016, 22:39:54 by Row009 »
